Hood Emblem
Old Nov 27, 2004 | 04:40 PM
Psychoburn's Avatar
2005 White C55
Hood Emblem
How much is a typical hood emblem change? the one that sticks down onto the grill? thanks!
Old Nov 27, 2004 | 05:01 PM
xxbenzc230kxx's Avatar
is not yet completed
you can go to evosport.com they sell it for like 50 i think... and you can get it at the dealer for the same price.. or you can get it at formymercedes.com for i think 25...
Old Nov 27, 2004 | 06:39 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
I assume you are asking for replacing the raised hood star? if so, formymercedes.com has'em for $25.
if you are talking about changing the entire grille for your C55, then I'm not sure who does sell them, but if you search around on the forum you'll see ppl already got'em done. They would run you around $4-500 tho.
Old Nov 28, 2004 | 05:42 AM
Psychoburn's Avatar
2005 White C55
cool! thanks for your help guys, i just got it at formymercedes for 24 dollars!
Old Nov 28, 2004 | 08:45 AM
noka's Avatar
'24 Porsche Macan
I am curious what it looks like (will visit the site and see if there is a pic or perhaps you would post a pic after the install). When at the dealer I noticed all the coupes come with the flat badge and sedans with raised star. The sales rep said two things about it: 1) the sedan may look a bit odd with the flat badge since it was intended to complement the coupe look -- but beauty is in the eye of the beholder and b) more importantly, the flat badge and raised star attach differently and he heard about some problems with people making the switch. I don't know if that's true or not. Anyway, let us know how it turns out.
Rgds,
Norm
Old Nov 28, 2004 | 11:35 AM
MerlinMc's Avatar
2005 C55
While the raised star and flat badge do attach differently, the flat badge uses the same hole in the hood as the raised star.
Old Dec 10, 2004 | 10:16 PM
noka's Avatar
'24 Porsche Macan
Do you know why ForMyMercedes.com site says: "Add a little silicone adhesive under the hood emblem", if it uses the same mounting? I'd rather not glue it down.
Rgds,
Norm
Old Dec 11, 2004 | 12:25 AM
Psychoburn's Avatar
2005 White C55
Oh btw, i got it (hood emblem) and i put it on. IT'S REALLLY EASY. I have pictures! HERE you go
Old Dec 12, 2004 | 01:59 PM
Darba's Avatar
BMW E60 M5 / C55 AMG
white is soo nice I like it a lot!
Old Dec 17, 2004 | 08:42 AM
Ultraman's Avatar
2019 E450 Coupe 4Matic; 2018 Audi Q5; 2019 Toyota Corolla Hatchback
I got this flat hood emblem kit last night. Before I do the installation, is it true that the size of the flat hood emblem (logo) is larger than the original one? Also, how can you ensure the 2 plastic tips (white) are secure? Do you apply any silicone under the badge to ensure the water will not run to the metal bracket under the hood?
Please advise and thanks.
Old Dec 17, 2004 | 10:33 AM
noka's Avatar
'24 Porsche Macan
Originally Posted by Ultraman
... Do you apply any silicone under the badge to ensure the water will not run to the metal bracket under the hood?
My post above indicates that the web site mentions use of silicone. Not sure I like that.
Rgds,
Norm
Old Dec 17, 2004 | 11:21 AM
Psychoburn's Avatar
2005 White C55
I didn't apply any silicone under the badge, but I can test to see if water goes under the hood.
As for the emblem being larger than the original one.. i'm not sure
Old Dec 17, 2004 | 12:05 PM
Ultraman's Avatar
Just read the other forums and it seems the flat emblem is larger than the raised hook emblem (diameter). The flat emblem will cover the recess on the hood.
I believe I will use some silcone to dip at the end of the white plastic tips and the emblem on the hood for double secure. I don't think the silicone will damage the paint. However, what I worry about is the permenant marking of the emblem on the hood after it is tighted.
Old Dec 17, 2004 | 06:23 PM
rguy's Avatar
I siliconed the badge instinctively. Silicone is inert and will not damage your paint. Silicone prevents your logo from twisting while driving and prevents water from leaking down into the hood star cap on the underside of the hood.
Silicone is temporary and can be pulled off and taken off with the appropriate solvent. I tried it without silicon first and then noticed my amg logo would be twisted 45 degrees or so when I would get done driving some place.
That kind of stuff scratches paint, so I adhesed it down with two beads of silicone for indoor/outdoor use from home depot. The cost is cheap, the seal is flexible, and the stuff works. I have been using it for three months now with no problems.
Hope this helps.
Old Dec 19, 2004 | 12:20 AM
Ultraman's Avatar
Just installed the emblem last night. The only problem that I found is the emblem (MB caP) kept loose when I tightened the metal nut under the hood, even I did not push the 2 plastic caps all the way in (note: I followed the manufacturer instructions). As a result, I applied the silicone between the cap and the hood.
Old Dec 19, 2004 | 01:43 AM
rguy's Avatar
good man. silicone is the best way.
Old Dec 19, 2004 | 08:54 AM
noka's Avatar
'24 Porsche Macan
The silicone I have used aorund the house (inside and outside) typically says "glue & seal" on it and it really is like glue. I would think removing it late if you ever wanted to would be a real challenge.
Rgds,
Norm
Old Dec 19, 2004 | 01:52 PM
rguy's Avatar
The stuff I used, from GE I think, looked extremely easy to pull off, kind of like rubber cement.
Maybe you use different stuff and shouldn't use that for a car.
There are infinite variations of silicone adhesive depending on the job, just like there are tons of variations of loktite and similar. Some are permanent, some are temporary, some are to be used transiently.
I guess I should have done a better job of explaining the use of the adhesive. You know, anyone who does this should take a moment at the hardware store and decide how permanent or temporary they would like the seal to be. For me, I don't plan on taking the hood badge off at any point because I don't like the huge tri-star on the hood. Plus, I get 5 more miles to the gallon and a .03 reduction in drag coefficient (just kidding). I decided I wanted to get the most gentle stuff possible that could be used outdoors because I didn't want to take a chance that any top secret additives to the silicone adhesive to make it stickier would chemically etch the paint. Even if I am never going to see some paint again, I still like to protect it. (I know that it is sealed by the silicone, but I can get **** when it comes to the amg)
Old Dec 19, 2004 | 03:23 PM
Ultraman's Avatar
So again, did you guys find the kit is not perfect fit to the hood (i.e. if not apply silicone)? I strongly believe the 2 plastic legs from the OEM flat emblem are too short for the kit.
Old Feb 7, 2005 | 02:46 PM
HaLfPaSt2's Avatar
'05 C230 K Sport Sedan
i just purchased a flat hood emblem from ebay... but cant figure out how to get out the raised star... anyone can help?
Old Feb 7, 2005 | 02:57 PM
Ultraman's Avatar
This is what I did:
Open the hood and you will see 2 dull color metal legs below the emblem. Use a screwdriver or long plier hold tight and turn these two metal legs counter clockwise (about 90 degree), and the hood emblem will come out. Make sure you do the captioned procedures either with your left or right hand and the other hand to catch the hood star from above.
Old Feb 8, 2005 | 10:31 PM
rockintunes23's Avatar
From: Delaware, United States. (First ~little~ state)
Mercedes-Benz
Stick your ***** in it and it comes out with a DEEP red mark LOSER
Old Feb 9, 2005 | 12:13 PM
DbleNckel's Avatar
05' MB C-dblenckel
haha trying to start some static/excitement in the forum this guy/gal...what a martha focker! :p
Old Feb 10, 2005 | 12:14 PM
BklynBenz's Avatar
CL500
haha looks like youve tried it before. how about stickin your **** in a real pu$$y next time LOSER
Old Feb 10, 2005 | 07:23 PM
Robbie's c32's Avatar
funny
this kind of stuff normally pisses me off, but this was worth a good laugh!!
