My first real mod =)
Old Dec 15, 2004 | 04:03 AM
Psychoburn's Avatar
2005 White C55
Well, here it is!:
Will be installed and done next week!!
Old Dec 15, 2004 | 04:07 AM
neoprufrok's Avatar
Whoa.. NICE - you'll have to let us know how it works out. Can I ask you when, where and how much for the isntall?
Old Dec 15, 2004 | 04:44 AM
Wiedermann's Avatar
NA
Lightbulb LSD Pics
Mr. Psychoburn:
Where are the pics of the kit???... I even looked under my desk...
If you can, besides the beautiful pic of your invoice, see if you can post pics of the entire kit plus installation pics as well
Wiedermann
Old Dec 15, 2004 | 04:51 AM
Psychoburn's Avatar
2005 White C55
neoprufrok:
got it from bergwerks in van nuys
2300+ for the lsd
1100 for install
Apparently the install isn't all that easy. Instead of just switching the diff.. it has to be modded. The gears have to be grinded or something and then the LSD put on.
Wiedermann:
The LSD is coming in on monday. When I bring my car in, i'll be sure to take some pics!
Old Dec 15, 2004 | 10:10 AM
marcC55miami's Avatar
I thought i had lost all sanity after dumping 15k in to my 996 but it seems I am sane, my C55 will stay bone stock. I love the car the way it is.
Old Dec 15, 2004 | 10:42 AM
DbleNckel's Avatar
05' MB C-dblenckel
Originally Posted by Psychoburn
neoprufrok:
2300+ for the lsd
1100 for install
Wiedermann:
modded and grinded???? I think I'll live w/ OEM on mine :p
Old Dec 15, 2004 | 11:49 AM
neoprufrok's Avatar
Well, I think its well worth the investment. Trying to accelerate out of turns is a major limitation of the C55. Plus, an LSD will allow better traction on launch. I like this mod first.
It does seem a ilttle scary about the grinding and gear switching - but not all mods can be bolt on.
Old Dec 15, 2004 | 12:52 PM
BenzoBoi's Avatar
Super Moderator
W221
Awesome...I look foward to pics...
Old Dec 15, 2004 | 03:40 PM
Brandon @ Kleemann's Avatar
Former Vendor of MBWorld
The planetary gears have to be ground (as in precision ground, like as in cylinder head) on a flat face to accomodate the locking mechanism. In the past we have included the gears with the kits, pre-machined. MB has made the planetary gears unavailable as a spare part so one has to machine the existing gears in the diff you are modifying.
Old Dec 15, 2004 | 03:42 PM
E320Star's Avatar
2000 E320 Sedan
sho wme the pics please.
Old Dec 20, 2004 | 06:44 PM
Psychoburn's Avatar
2005 White C55
Well, i took my shop into the car today, and here are the pics!
Attached Thumbnails My first real mod =)-dsc00375.jpg   My first real mod =)-dsc00382.jpg   My first real mod =)-dsc00380.jpg   My first real mod =)-dsc00381.jpg
Old Dec 20, 2004 | 07:56 PM
vdubpower's Avatar
i drive them all, fast and hard
sorry but whats a LSD do, hows it work, hows it diff. than stock, thanks
Old Dec 21, 2004 | 11:31 AM
Psychoburn's Avatar
2005 White C55
From kleemann's website:
Overflow of engine-power is no good if it cannot be transferred into wheel traction. Therefore KLEEMANN has developed a Limited Slip Differential (LSD) with a 60 percent locking mechanism, which means that the mechanical devise applies a 60 percent lock-up ratio between the two drive wheels. In contrast to a standard ESP-system a Limited Slip Differential (LSD) is a very sporty and high-performance approach to control wheel spin thereby improving the cars traction.
At no time will only one wheel receive all the engines´power and by powering both drive wheels at the same time, the engine power is distributed more evenly, hence reducing wheel spin and in the end lowering accelerations times significantly.
Basically, it helps by making sure both of your wheels are spinning instead of only one spinning. Hope that helps
Old Dec 21, 2004 | 12:24 PM
setUout's Avatar
let me know how it works out for you. im also in the san fernando valley and would be intrested in checking it out after you get it installed. i may end up also going with the lsd.
Old Dec 21, 2004 | 12:59 PM
JasonC32amg's Avatar
2002 C-32 AMG Renntech
Do they modify/reprogram your ESP?
Old Dec 21, 2004 | 01:20 PM
Psychoburn's Avatar
2005 White C55
Nope, they just modify the planetary gears in your existing diff to use the locking mechanism.
Old Dec 22, 2004 | 01:50 AM
Dave OH's Avatar
R170
That part kinda looks like a phantom grip device like this: http://www.phantomgrip.com/products.htm.... am I wrong? just curious.....
Old Dec 23, 2004 | 06:21 PM
Psychoburn's Avatar
2005 White C55
Yea, it looks something like that. AND i got my car back!!!! Some things noticed:
I've tested out the LSD, when I floor my car, the ESP will go off but my car will wiggle back and forth, showing the that LSD is in effect. Kleemann's LSD is only 60% locking.
I'll try to check my 0-60 times someday to see if the LSD helps the launch, which it's supposed to
Old Dec 23, 2004 | 08:27 PM
noka's Avatar
'24 Porsche Macan
Any comparisons with the AMG LSD that Harris sells would be good info if someone has any to share. I'm particularly interested if the AMG unit just drops in or if gears need to be modified like your unit did.
Rgds,
Norm
