SAT radio mounting
Old Jan 3, 2005 | 04:27 PM
mrkbbd's Avatar
'05 MB CLK 320A; '06 BMW X5 4.8is
SAT radio mounting
I have asked a similar question before about mounting sat antennas, but when i went to the dealer they said the only way to mount the sat antenna is on the trunk lid, no way to put it in the spoiler or in the car, was this a mistake?
Old Jan 3, 2005 | 05:10 PM
dcfsf's Avatar
2003 E55
sat antennas
In my C43 I had the XM antenna mounted on the back deck (inside) and it worked great 95% id the time. My wife has the same antenna mounted outside and hers works 99% of the time.
I will probably choose to go inside with it on my new C32.
Terk makes a good small antenna for XM.
Old Jan 3, 2005 | 06:00 PM
srknutson's Avatar
2004 S500 & 2011 Mini JCW
Dude I had the dealer install the Sirrius and I bought a small antenna and mounted it next to the GPS antenna. It's about 1.5 inches square and plugged right in to one of the two inputs that go to the stupid antenna that mounts on your trunk. Whoever came up with that trunk mounted antenna should be shot at dawn. On the MB cars with fiberglass trunk lids the antenna is OEM mounted in the trunk. Good luck.
Old Jan 3, 2005 | 09:26 PM
C55NJ's Avatar
My XM antenna is inside on the back parcel shelf. I've had no reception problems.
Old Jan 3, 2005 | 09:28 PM
JD5000's Avatar
99 C280 sport
i have my sirius antena mounted on the roof. its small and black and you don't really notice it on the black paint. the guy who put it on is sort of slow i'd guess because he put it in the front right corner but its not to bad.
Old Jan 3, 2005 | 09:41 PM
dcfsf's Avatar
2003 E55
what kind of xm antenna do you have?
Old Jan 3, 2005 | 09:45 PM
C55NJ's Avatar
The box for my XM Commander says its a "Low-Profile Micro Antenna."
Old Jan 4, 2005 | 10:24 AM
AaronC's Avatar
C32
Same here. It works 95+% of the time.
