Anybody have any problems with traction control when upgrading to 19s?
Edit: I just reread your post, and I misread your question. You wanted to know aout traction control. Since the diameter is increased on all 4 wheels there should be no problems at all.
The overall rolling circumference of the tires has nothing to do with ESP intervention. You could put tires on the car that had a 3.0" diameter difference from stock and the car would not sense that anything was wrong if the front to rear relationship in diameter remains constant.
The only thing that an increase or decrease in diameter will do is affect acceleration times and speedo error. No different than changing to a taller or shorter final drive gear.
In your example, yes there is a 1/2" difference between the suggested 19" staggered set up, but compared to the stock 17" sizes, there is only a 3/64" difference in the front to rear tire diameter relationship. This is much closer of a tolerance than a 18" set up utilizing 235 40/ 265 35's which is almost double that number.
The C32 favors a front tire that has a larger diameter tire compared with the rear, as is the case with all these examples. When you reverse this order, that is when you will have a problem with ESP, as I have proved on the track running 10/32" rear tread and 2/32" front tread in the 18" sizes stated above, reversing the relationship by 5/32", which had ESP in a state of continuous confusion and smoking brake pads to prove it.
Good luck with your 19's. Make sure you buy light weight ones.
The stock 17" are like 26-27 lbs?
BTW, how much does it actually throw off the speedo?
I am not sure what the weights are exactly, but 28lbs pops in my head for the rear wheels.
I could not find the exact diameter of the Conti Sports, so here are the differences in a "standard" tire of our size. I am not sure if our car reads the speed displayed on the Speedo from the front or rear tires, or averages them, so I am posting the speedo difference for both:
Front:
225/45-17
Overall Diameter - 25"
Revs per mile - 808
235/35-19
Overall Diameter - 25.5"
Revs per mile - 792
Speedo reading with 19s is 2.0% lower then with 17s.
When running on 19s, and the speedo is reading 60MPH you are actually going 61.2MPH
Rear:
245/40-17
Overall Diameter - 24.7"
Revs per mile - 816
265/30-19
Overall Diameter - 25.3"
Revs per mile - 798
Speedo reading with 19s is 2.2% lower then with 17s.
When running on 19s, and the speedo is reading 60MPH you are actually going 61.3MPH
Also, it could be that his ESP learned that he had different tire sizes and "adapted" to the new speeds.
But seriously, maybe the addition of the suspension, wheel/tire, and brake upgrades, which allow higher levels of cornering forces to occur, are the reason my computer takes a holiday during these extreme sessions. Maybe, the thresholds I am producing are out of the computers range.
Did you not have this problem running CCW at Streets? Maybe this has something to do with it. I have never run the C32 CCW only the Honda. CCW causes some odd behavior from my car coming out of the bowl in that direction. Maybe I am just running out of talent
