Saw a C32 today with 18" Babraus rims 235/265 tires
Old Jan 18, 2005 | 02:16 PM
cntlaw's Avatar
C55AMG W203; 330i E90
Would like to know if C55 can do the same with no mod or would the size be too big that can rub the sides?
Old Jan 18, 2005 | 03:38 PM
nk789's Avatar
2003 c32
Even if you put 19's on it wont rub you just might have to roll abit of fender. With 18 its far from rubbing.
Old Jan 19, 2005 | 04:42 AM
sire's Avatar
i have the mb camber kit on with the 18"s are you sure they wont rub at 235/265?
Old Jan 19, 2005 | 02:31 PM
nk789's Avatar
2003 c32
You just might have to roll in some fenders thats just minor mods. Im running 19's 235/265 brabus monoblock 6 and I dont see any problem.
Old Jan 19, 2005 | 02:50 PM
x-tian-230k's Avatar
CLK500/Range Rover HSE/E55 AMG/Bmw 328Xi coupe/BMW 4.8x/Bmw 335i/GS350/Audi S5/E350
You shouldn't have a problem....on my C230k ss i had 19 brabus mono V's with 235/35 front and 265/30 rear with out mods.
Old Jan 20, 2005 | 06:43 PM
Harris's Avatar
The fenders on all AMG cars are pre-rolled. It really depends on what tire you use. Some tire with a more rounded sidewall will be okay, tires with a more squared sidewall will cause problems.
You should be fine with 19" Monoblock VI and 235/265 combo. I had them on my car a couple of years ago and there's no rubbing.
Old Jan 21, 2005 | 11:33 PM
smgC32's Avatar
I'm sorry Harris. What do you mean by this? "The fenders on all AMG cars are pre-rolled."
Old Jan 22, 2005 | 02:17 AM
BlackC230Coupe's Avatar
Former Vendor of MBWorld
Fast Cars!
I too would like to know, i have had rubbing issues with my C55. And i know other people with AMG cars that needed their fenders rolled.
Old Jan 22, 2005 | 07:57 AM
noka's Avatar
'24 Porsche Macan
I have not checked my C55 yet. However, if it's like my M5 (for example) the rear fenders were factory pre-rolled compared to the regular 5-Series with same body style.
Update: Not sure about other C-class but my C55 rear fenders appear to be rolled.
Rgds,
Norm
Old Jan 22, 2005 | 12:06 PM
Harris's Avatar
Fenders on all AMG cars are pre-rolled from AMG factory, not on regular C-class. I dont know how much simpler I can explain, sorry.
Old Jan 22, 2005 | 01:52 PM
smgC32's Avatar
All fenders have a 90 degree or U channel bend to them to provide additonal strength to the fender's edge. Simple engineering. The rear of a C32 has an upward bend of about 30 degrees in a U channel design. The front has a simple 90 degree bend without the U channel, which is inherently weaker. The C32 has the same shape front fender as the other W203 sedans. Fender rolling is not done by MB on AMG stock cars. There is no need given the stock wheel/tire fitment. The standard fender can accomodate the wheel/tire size.
Fender rolling is required when you want to fit a much larger wheel/tire combo. The fender lip is pounded or rolled tight against itself reducing the U channel gap or bending the 90 degree edge up. In the process, the rolled area may also be pulled out towards the outside providing more interior space within the wheel well, effectively altering the shape of the fender itself.
There is a difference between factory rolling (which doesn't exist) or rolling that is done by a special division of a manufacturer, like AMG in Germany, who will customize a car to an owners desires. If a customer wants huge wheels/tires on their AMG car, as delivered or modified by AMG at their Germany location, AMG may "roll" their fenders to accomodate the request. The same with Brabus and any other aftermarket tuner wanting to provide much larger rolling stock.
Here is some proof that rolling does not exist on AMG cars delivered stock here in the States, and the poor design and quality of a MB front fender:
Attached Thumbnails Saw a C32 today with 18" Babraus rims 235/265 tires-dscn0538.jpg
Old Jan 22, 2005 | 02:11 PM
noka's Avatar
'24 Porsche Macan
It's not clear who smgC32 or Harris are replying to. It doesn't much matter. I'll let you guys argue the fender rolling and whether MB/AMG do it at the factory or not and what other C-class fenders are like. I simply related what I observed on my C55 to what I know about the previous BMW 5-series (E39) platform.
Rgds,
Norm
Old Jan 22, 2005 | 04:54 PM
Fast Cars!
ouch, i have a feeling my tires and fenders are gonna look like that if i ever go to the track without having them rolled.
Old Jan 22, 2005 | 08:32 PM
smgC32's Avatar
The tolerances of the W203 are not as good as other european or Japanese marques. The passenger side of my car is .125" off compared to the driver's side from the hub mounting surface to the outer fender. Only happened to the passenger side. 8.5" front wheel, ET32, 235/40, 1.75" drop. 13.25" is just too low during 100% compression on my car.
With a broom stick, hold the stick vertical against the lower tire with your foot and the upper fender lip with your hand at the center of the wheel. Measure both sides of the vehicle and report if you'd like for comparison. With 8.5" wheels and an offset of 30 or 32, you may find that the tire's sidewall sticks out beyond the fender. This damage won't happen with the stock 15" ride height. Note how wimpy the angle material is. You can pull on the fender and move it considerably due to thin metal as well. As for the stock paint quality, although sprayed very well, consistant and little orange peel, just show your paint a rock and it will chip much easier than earlier MB or other manufacturer's paint. Same for the density of the windshield.
Old Jan 22, 2005 | 08:36 PM
DbleNckel's Avatar
05' MB C-dblenckel
Neal,
aren't you able to adjust either the ride height or spring rate to prevent the rubbing problem being that you have c/o's??
T.
Old Jan 22, 2005 | 09:28 PM
Fast Cars!
I am gonna try to measure for the fun of it tonight or tomorrow.
Old Jan 22, 2005 | 09:32 PM
Fast Cars!
Originally Posted by DbleNckel
Neal,
T.
Tony,
Yeah, i can prevent my rubbing if i was to raise the car a little bit. But i love the height its at now! :p I have my coilovers on the stiffest setting, i think if i was to have it a little softer it would rub even more at this height on some bumps. My rubbing seems to not be doing any damage, and its the rear only as far as i know. All i hear is a LOUD griding sound when i am going fast around a turn or a very large dip in the road.
The other day i was driving on some emptly back roads near an airport that had lots of curves and turns, i was going about 75+ mph threw on of the cuves and it sounded like my car was rubbing against a concreate wall!
Old Jan 23, 2005 | 03:24 AM
DbleNckel's Avatar
05' MB C-dblenckel
Tony,
gotcha! hey, so when are you getting your wheel back from HRE so we can see some "outdoor" pics???
Old Jan 23, 2005 | 04:14 AM
Fast Cars!
Oh i got that back about a week ago maybe. I just washed and zainoed the car today, if the weather is good tomorrow i will take some good outdoor pics!
Old Jan 24, 2005 | 06:46 PM
noka's Avatar
'24 Porsche Macan
... The passenger side of my car is .125" off compared to the driver's side from the hub mounting surface to the outer fender. ...
I would not be surprised if 0.125" is within MB spec.
Rgds,
Norm
