Attempting to lower intake temps...
Old Feb 7, 2005 | 07:56 PM
BenzoAMGpower's Avatar
Cars and boats!
Since our intercoolers are air/water intercoolers and share the same fluid used as radiator fluid, i was thinking of trying this stuff...
http://www.designengineering.com/pro...p&pid=35&tid=1
supposed to lower temps up to 30 degrees.... im going to go get some this week... ill let you all know how it works!!! Heat soak is a ***** here in Florida.. i can use all hte help i need.
Old Feb 7, 2005 | 10:40 PM
OneFastZ's Avatar
02 Corvette Z06, 02 C32 AMG
It's just like water wetter... Save your money. I'm trying to see if we can bolt on a new heat exchanger from a 03+ cobra to help with outlet temps.
Old Feb 7, 2005 | 11:26 PM
Cars and boats!
so im guessin water wetter didnt work? I read that this has anticorrosive properties though!!!
Old Feb 7, 2005 | 11:30 PM
AaronC's Avatar
C32
I think the best coolant for this purpose is Engine Ice. I plan to put it in my car's AWIC system soon. Motorcycle guys swear by the stuff. http://www.engineice.cc/products.html
BTW, it really is a coolant, not a coolant additive.
Old Feb 7, 2005 | 11:38 PM
prof.griff's Avatar
E430,S500
check out http://www.m-p-c.demon.co.uk/problend/40below1.html
Which ever you choose, they work best with distilled water only. No antifreeze.
Old Feb 8, 2005 | 12:08 PM
jhw's Avatar
jhw
Insulate AirBoxes?
Not exactly on topic but has anyone tried to insulate the air boxes? I've heard this old trick works very well on these cars because of the airbox location - right on the engine. In most cars this is not the case.
Old Feb 8, 2005 | 12:30 PM
430's Avatar
430
SLK32
I have used water wetter in the past and it does make a difference. The products work by reducing the surface tension of the water in your coolinng system (at least that is my understanding) allowing for more efficient transfer of heat.
One note is that the compounds break down in ~12 months and become more corrosive than your normal cooling mix.
Old Feb 8, 2005 | 01:09 PM
psk145's Avatar
2006 E55
I dont think the intercooler gets hot enough for water wetter to work. Its my understanding that the water needs to be at boiling temperatures for water wetter to work.
Old Feb 8, 2005 | 03:45 PM
Zeppelin's Avatar
C32
How do you plan on using this product in the Intercooler System without changing out the radiator coolant since the two are interconnected?
Old Feb 8, 2005 | 04:59 PM
AaronC's Avatar
C32
Actually, I am seperating the two systems. I will run the MB coolant in the engine, and Engine Ice in the IC. Here is a diagram of what I am doing:
Old Feb 10, 2005 | 11:48 PM
Cars and boats!
let us know how it works out... i plan on doing something similar myself if RENNTech doesnt have time to work on one for me!!!
Old Feb 11, 2005 | 01:26 PM
N.M.M.'s Avatar
I already tried the intercooler fogger on the heat exhanger a while ago. It didnt really do much. The ammount of Co2 required was not efficient to cool the fluid in the intercooler system
Old Feb 11, 2005 | 02:17 PM
AaronC's Avatar
C32
Yeah, I kinda figured that the sprayer by itself would not do a great deal, especially once you are moving. That is why I included a coil. We will see...
