ESP off, can it cause damage?
It has nothing to do with the F1 safety car, and NO, MBUSA does NOT endorse any form of motorsports including autocross or local drag nights. They are bound to the M&M act for aftermarket modifications but if you participate in any form of motorsports, your warranty is void. If you do a power burnout and destroy your trans, do you think they will blindly cover it?
Furthermore you are not doing a torque braking burnout without Dyno mode. So...
I have resolved that issue though. Trending Topics
I have resolved that issue though. MB designed... I don't know about the C32, but things break at risk are your motor, transmission, diff and half shafts. My car, though not a C32 and having differnt dirveline components, has broken a trans input shaft, 1 pinion, and 1 ring gear.
That being said, no one I know of has broken things doing a couple burnouts.
But I am sure it will have some impact in the long run.
The way I see it, no matter what you do something gotta give.
For example:
1. you have the best suspension out there for track use. The car handle like it rolling on its rail. (The drawback, premature worn on rubber shock mount, suspension bushing, etc).
2. the car has a beefed up tranny, but you drag the car almost everyweek. Soon the clutch will be gone.. (no matter how beefed up the tranny is made from the factory).
In my opinion Benz is not a race car. When you do something excessive (i.e excessive burn out, excessive stress of the car be that engine, or suspension) something gotta give. (Even race cars need to be rebuilt almost after everyrace)
At the end it will damage your wallet off course
PS: Even with normal usage, any part will eventually worn out and need replacing..
Regardz,
I hope I'm just like you when I'm that age. Now we all want to know if you are still listening to rock music???????????
That's truly awesome!
For example:
Regardz,
You will feel this from within the car as something like someone hitting the axle repeatedly, and very, very quickly, with a sledgehammer. It is *not* good, and can turn portions of your driveline into nice, chunky little bits of metal in a big hurry. If you ever feel something like this, do two things: 1) let off of the gas, immediately; 2) never, ever do what you did to cause this to happen again.
Solution is to fit some wider rear tires with better traction. You can get 265/35-18's on stock E55 rims for the rear, which helps a lot, but with these torque monsters you've got to be careful...
Bob
Bob
Bob
