Pictures of my HRE 547R's on the car
2006 E55
Rain cleared our for a few hours so I snapped some quick pics.
Played out or not, I love the way it looks!
Cars and boats!
dont care what anyone says about the 547R being played out... they are simply BEAUTIFUL!!! The are the only wheels I'd ever trade my Monolites for!!!!
2006 E55
Fronts: 19x8.5 offset is 36, lip is 1.5"
Rears: 19x9.5 offset is 38, lip is 2.5"
I forgot the exact numbers of the tires, but the rears are 265 and front is 235. Used Toyo T1S (or something) courtesy of Vader13
also, H&R springs with #2 pad in the rear. I might go #4 in the future to even it out a little
01 clk55 cpe
psk145:
What pads do you have on the front?
The front seems to have a larger gap than the rear.
I have #2 pads F&R and I have an even drop.
I'll post pics soon.
Nice ride though!!
Nice ride though!!
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
is not yet completed
LOOKS great man... love the choice... how much did you get the tires for? i am lookn for tires also.. did you have to roll the fender? bcuz just wondering cuz i have H&R springs and #1 sprring pad on rear.... but neways it looks great man...
2006 E55
CLK55fan: there are no pads on the front. The rear was always a little lower even with the factory springs
z1co: not sure what percentage, but its a medium all the way around
benzx230: I bought vaders used old toyos when he switched to to his falkens. No rolling of the fenders at all. No rubbing at all, even when going off steep inclines
2006 E55
Originally Posted by JamE55
Looks tight! I also have the same HRE wheel sticker on your window! ![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
W211 E55 AMG, ML63 AMG, Past 996GT3,ZCPM3,Brabus C32,ML 500
[QUOTE=psk145]Fronts: 19x8.5 offset is 36, lip is 1.5"
The rear offset is good. The front offset is interesting in that it is a higher number than most 8.5" width wheels for this car. I wonder if HRE is limited to this high of an offset number in accomodating the 1.5" front lip? Do you know the pad thickness? HRE can shave in 1mm increments. At an ET of 36 and running T1-S's, I will bet that you have close to no clearance between the wheel/tire and the strut housing. Is this true? You can turn the wheel full lock and jack up the car and look at the spacing. How many business cards/other hard material like cardboard, etc. fit and what is the width of the gap? A squarer side wall tire may rub on the inside. You may also have a problem with future coilover fitment as the strut tube is 3mm wider at the point of contact. How much clearance between the inner spokes and the outer brake caliper? Just curious in creating a database of various wheel fitments for the W203. Most front offset numbers are 30 or 32 with some wheels at 28 (which is too far out in my opinion and will rub on a lowered car). If I didn't have RENNtech Monolites, I would own the 547R's! Drop the rear with the thinest spring pad.
2006 E55
SMG: I dont know the thinking of HRE on why they did things like they did. Im not that familiar with offsets and stuff, so thats why Im glad HRE spec'ed things out.
I dont plan on going coilover in the future. I dont use my car on the track, and dont plan to. If I was into that, I would use my BMW. This car is just for cruising, so I would prefer to keep the "comfort". Im not happy with the harsher ride now just from springs, so I may try some Koni adjustibles in the future.
Peter from Wheel Experts also told me that the wheels would rub with coilovers, and if I were to do that, he suggested a 8" width.
The space between the outer caliper and inside spoke is actually larger than the stock 17's. I can try and get a measurement later if you'd like.
You think the rears should be dropped MORE???? I would think it would look even more uneven.
Former Vendor of MBWorld
Figures. Peter is so conservative when it comes to fitmetns on a C-class. He only specs the wheels to have a 2.5" rear lip and not a 3" which fits perfect with no rubbing. Also, you should not rub with coilovers.
psk145, thank for the reply. Peter is a great guy and very knowledgable about fitment. As for the rear spring pads, lower not for looks, but for weight distribution under heavy braking. As you state, this is not a race car for you, so the current rear ride height is fine and I agree you could raise it for better proportions to the front if you so desire. 19's fill the well out more and make it look lower even with the same pad.
I am glad HRE got the spoke spacing correct. If it is the same or greater than stock, no need to measure as this is enough info for me and it is very difficult to measure accurately. You should be able to stick a finger between the caliper and spoke if you have the space you say.
blackc320coupe, the wheels will rub with coilovers, guarenteed unless a spacer is used especially at very low ride heights. The stock strut housing is 55mm in width that tappers to 50mm at the point of wheel/tire contact. Coilovers are a minimum of 53mm consistant vertical width, therefore there is a 3mm reduction in clearance. The ET36 offset is 4-8mm closer to the strut tube than the other wheel offsets I mentioned. With my ET32 wheels and 235 40 18 Goodyear GSD3's I had .5mm clearance and they rubbed the coilovers under load. When I switched to Toyo T1-S, the more rounded shoulders and different profile and measurements provided an additional 2mm of clearance, but the gap is still very small. If I was to fit an ET34 wheel on the front it would be back to almost touching with the Toyo's and an ET36 would absolutely rub. Forget about running the Goodyears or the S03's or any other "wide" 235 tire. Just for argument's sake, if we look at my clearance of 2.5mm with the Toyo's with coilovers and a wheel of ET32, if I was to go with a ET36 wheel, I would be 1.5mm too short to clear. But if I had the stock strut housings that gave me an additional 3mm of clearance, I would be at 1.5mm of clearance between a ET36 wheel, Toyo's and stock strut. Peter knows what he is talking about.
2006 E55
smg: whats your take on the tire choice? The shop that mounted my rims and tires are pretty firm believers on the PS2. Peter has had bad luck with them quality wise, and possibly fitment because of the more square profile.
I don't know about that. I have sold a set of HREs to someone with a C32 with the same front offset as that but a different rear, and I did not spec it out with coilovers and he is fine with his H&R coilovers installed. No rubbing. I even think my HRE's have that front offset and I did not spec mine for coilovers and I am not rubbing AT ALL on the front with mine set pretty low. Peter is a nice guy, only much to conservative with Mercedes fitments, it shows on every wheel he sells. To me it looks like he is more knowledgable in Porsche applications.
