How to find out what biggest tire size is?
If you want a wider tire, you are going to need a wider wheel. Absolute maximum is 265/30/19 on a 19x9.5 wheel with appropriate offset.
eeeeeexcellent, thanks so much man, really, i appreciate it.
btw- any negatives to doing this? Any at all? Or only the added benefit of better traction? Thanks again.
last question, lol, 1. why wouldnt people recommend 235's up front? 2. would it make any difference between going 225/255 or 235/255?
Again, thanks so much for everything.
tototisha, you want to replace your front with 225's or 235's? as it is with 225/255 everything is great? no problems and only positives? do you know if changing the fronts to 235 will be better or worse? thanks for the info.
I'll take two tires as an example:
Michelin PS2 - 225/40/18 - 25.1"
Michelin PS2 - 255/35/18 - 25.2"
Michelin PS2 - 235/40/18 - 25.4"
Michelin PS2 - 265/35/18 - 25.3"
Toyo T1-S - 225/40/18 - 25.1"
Toyo T1-S - 255/35/18 - 25.0"
Toyo T1-S - 235/40/18 - 25.4"
Toyo T1-S - 265/35/18 - 25.4"
I think 225/255 and 235/265 are better matched sizes.
thanks Harris
Essentially when you put the widest tire on a wheel it angles in to fit the smaller wheel, curling up the edges ever so slightly to fit on the wheel. We are only talking about 5mm per side to make it have the same traction as a 245. On the other hand, if you put the narrowest available tire for a wheel on, then you will see the side walls bow out and will have likely even some of the side wall contacting the ground. I have definitely seen both of these things happen.
If you are looking for maximum straightline traction with a wider tire, you need a bigger wheel as I stated before with the best tire compound you can find.
When you go too wide with a tire, you don't get any more straight line traction. When you go with too narrow a tire, you lose cornering traction. Manufacturers don't want to spend anymore than they have to give a wheel maximum traction. If you think about it I am sure that you will see that a 255 Rosso tire is not much more than a 245 Rosso tire and in the face of vehicle development costs and profit margins and vehicle production numbers for the C55, it would have been cost effective for them to choose a 235 or a 255. They took the 245 and have stuck with that decision for years and years. Even my old C43 had 245 tires.
Personally, I recommend you go to 9.5" wheels in back with 265's that match the running diameter of the fronts as perfectly as possible. 235's up front would not hurt and could help, but not fix, the understeer weight balance of the vehicle.
