cant decide
thanks!!
mark
You think it's that easy to put the 5.5L motor in a non V8 C class? It's been done but it's a lot more challenging than you think.The drive train,harness,Tranny ECU,engine contol ECU ,driveshaft,exhaust system and diferentials are different.Have you done it?
Obviously not because the 98 C43 and the 99-2001 E55 use the same harness so I didnt have to do anything else but swap the motor.
Not worth it.Too much $$$ and a waste of time.Engine and tranny alone could run you easily over 15k combimed.Exhaust unless the car had a 4.3L motor is totally different.Hey!
Where are you gonna get the ECU and EFI harness from?
Who told you that all the tranny's on the W202's are the same?
You need to stop giving misinformation.Your car for example has a totally different transmission than mine.You feel that the C180,220,280,36 have the same trannies as a C43?
Do your research man b4 you post this kind of info.You are truly misinformed.
I'm just stating the facts!!
from.
