Are Koni Adjustable Shocks Rough?
After installation, I noticed that the shocks were on the softest setting, but I am feeling EVERY bump in the road. I am actually popping out of my seat at times.
Is this usual? I was told that the soft setting on the Konis would be similar to the feel I had with the original AMG shocks. This is obviously not so.
What is the problem (if there is one). What should I do?
I think that for some reason my rear suspension is much harder. They return the energy much quicker.
The front is rubbing a little when I do U-turns and there is a little popping sound in my right front when turning at all. I am beginning to regret my setup a little bit.
good luck
Maybe I should turn it to the firm side and see what it does.
/just rode it on the most firm. Oddly, it does not seem to change anything. I think it might have something to do with putting the shocks in a vise and turning them before installing them (as in the instructions). I might have manually adjusted them stiff.
/RocketR: Actually, I seem to be the only one experiencing problems (probably because I messed with them myself). I don't think it would give you the same problems.
Did you use the stock bump stop..
I am assuming you're aware that you will need to cut the stock rubber bump stop since the car is sitting lower now.
Other wise when the suspension compressed the shock have got a chance to its job and the shock boddy and the car body squeeze the bump stock in between in which might explain the rough bumpy ride..
Regardz,
J Irwan
I was not advised about trimming the bump stop. I was told that they would keep my car from bottoming out and possibly doing damage to my already lowered car.
If trimmed, how much should they be trimmed?
i use bilstein sport and brabus springs on my setup and not sure if this may apply to your situtaion, however when you vise clamped your shocks during adjusting, you didn't clamp it too tight perhaps seizing the rod from travelling up and down? not too sure how thin or thick the valve tubing is, but any small nick in the tub channelling may cause the internal valve from travelling hence why you maybe experiencing the very harsh ride as you explained. my suggestion is to remove the rear shock and see if the rod will travel freely. to do this, after you have removed the shock, flip the shock over and press it down as far as it can go against a piece fo wood on concrete and see if it slowly and smoothly moves back up. if you have a very hard time pushing it down or it doesn't come up smothly, it may be damaged. anyone else, please fill in or correct my comment
KONI shocks come from the factory at their full soft setting. The adjustment method will vary depending which model shock you have. The W202 comes available with internally adjustable or externally adjustable shocks and their adjusting methods are completely different.
In both cases, you should notice an immediate difference when pushing then extending the shock shaft. Extending the shaft should be considerably more difficult the stiffer the shock is set.
I needed more education before getting everything installed. Hopefully the future will be different. As of now, I have invested too much money.
/From the box, the shocks were difficult to compress and took a long time to extend. Also, the soft adjustment and firm adjustment were no different.
I don't really have a formule for this.
But Here is what I did for my car. The H&R lowered the front of car about 2.2" from stock form.
And the bump stop is 3.3" long. So I cut 1.5" from it.
Look at it this way, the bump stop is design to prevent the shock from bottoming, but that was with stock height, once the stock height is dropped you will also need to make necessary adjustment to your factory bump stop to allow the new sport sport to travel.. Other wise the dampening system on your car doesn't work properly and you might have a harsh ride...due to nothing could absorb those shocks and vibration from the road.
Regardz,
but again its all user preference
