brakes
Old Aug 11, 2005 | 02:19 PM
steve s's Avatar
1996 C36 AMG, 1995 Volvo 850 Turbowagon
brakes
so much for this story
Braking: Power vented discs; ABS; Front - 12.75 inch diameter vented rotors (from MB SL600 V12 coupe) with AMG-modified 4 piston calipers,; Rear; 11.5 inch diameter vented rotors (from MB E500) with 2 piston calipers. 60-0 mph in 107 feet.
got some new pads by saying it was 96 c36.
came back, took of rims. wait a minute, those are single piston sliding ate calipers...not some 4 pots.
anyway, even after looking up vin, it came back with some what looks like pads for opposing 2 or 4 piston pads. not this sliding crap.
oh well. time for some bbk
Old Aug 11, 2005 | 03:31 PM
J Irwan's Avatar
1997 C36 AMG
Steve..
could you take a pic..
on Mine I have 4 pot fixed piston caliper on the front
and 2 pot fixed piston caliper on the rear...
no sliding caliper anywhere...
Regardz,
J Irwan
Old Aug 11, 2005 | 05:08 PM
steve s's Avatar
aw man, i just put everything back...
but i'll use the volvo 850 setup..which is identical..down to the manufacturer.. ate front sliding calipers..these are smaller than the ones on the c36, but similar design and concept..
Old Aug 11, 2005 | 05:10 PM
steve s's Avatar
part #: 004-420-02-20-67
Old Aug 11, 2005 | 05:52 PM
J Irwan's Avatar
1997 C36 AMG
Steve,
Did you own the car the car since it was new ?
All C36 should have front caliper like this
96-97 has the same brake component, the 95 one although the same setup (4 pot fixed caliper front and 2 pot fixed caliper rear) it has different part number and the front caliper on 95 C36 has ///AMG pinted on them.
Take a look at this site to http://www.2phast.com/C36/c36.htm
Regardz,
J Irwan
Old Aug 11, 2005 | 07:35 PM
steve s's Avatar
yeah, it's since new.
i feel gypped..
Old Aug 11, 2005 | 07:38 PM
steve s's Avatar
and the rear are solid rotor instead of vented. calipers look the same
no wonder i always felt the brakes to be a little mushy
Old Aug 11, 2005 | 08:37 PM
J Irwan's Avatar
1997 C36 AMG
steve
you're correct the rear brake disc for 96-97 is solid rotor not vented (it also uses W210 part number).
where on 95 C36 all the brake component (f & r) has HWA part number on them. Hence for 95 C36 it is quite a ***** to find any aftermarket brake disc or brake pad (next to the impossible if you know what I mean).
Brake mushy could be attribute to a lot of thing. such as you need to do brake flush, and possible running ss brake line might help.
But something definitely not right on your front brake..
Excuse me, but I am also in disbelieve why your C36 front caliper is floating caliper not 4 pot fixed caliper.
Could you just take a snapshot...of your C36, I am a bit skeptical..
Regardz,
Old Aug 11, 2005 | 08:58 PM
steve s's Avatar
yeah, stainless steel lines will help.. fluids are flushed every 2 years...service guy was ecstatic when he heard my request.
i'll take a few pics tomorrow..don't feel like taking off the wheel right now..
