Transmission fluid done!
Old Oct 10, 2005 | 02:02 PM
Jon R's Avatar
1999 C43
Well, I waited about half a day in the service area. I was "helping" the mechanic so I could learn something as well as take pictures.
I was planning to "flush" the transmission, but since the dealer did not have a machine I just had it replaced. We not only drained and replaced the fluid at the bottom of the transmission, but eventually found the drain plug for the torque converter (after a lot of searching) and drained it as well. That was a good thing, because most all of the fluid was in it!
It cost $200 and my car has 41,000 miles on the clock. You can see for your self what came out of my C43. What went in dark red came out like this with tiny flakes of metal in it.
Attached Thumbnails Transmission fluid done!-ca250004.jpg   Transmission fluid done!-ca250005.jpg
Old Oct 10, 2005 | 02:16 PM
C43AMG's Avatar
Veteran: Army
98 Black C43 , 12’ ML 350 Blutec
Nice pics. Thanx for the info about the drain plug for the torque converter .So, how does it drive?
Old Oct 10, 2005 | 02:25 PM
Jon R's Avatar
1999 C43
At first it did not drive so well. I think it needed time to pull some liquid around. Right now, I am a little concerned about a low idle I am getting, but it is getting better.
I drove around for about 30 minutes on the highway and then turned around. On the other on-ramp, I punched it. I broke all traction control and spun my tires for a while. Now, the shifts keep pulling and I feel like I have a new car.
Still idling at about 550 though...
Old Oct 10, 2005 | 06:17 PM
Clk&Slk's Avatar
06' Clk 500 Cabriolet, 01' CL 55, 00' Clk 430
I pay the dealer $450 to service my tranny and rear diff, since my CL 55 was in the dealer to have the tranny ECU reset after installed HPS sc. What the mechanic told me that they have to reset the tranny ecu to re-adapt again after every tranny service due to the new fluid. New fluid will have difference pressure, on the pressure torque converter. I don't know what exactly does that mean. It might be true since you have a drop in idling after you service your tranny. The said that my tranny pressure print-out was above then normal but it still within spec.
Old Oct 10, 2005 | 06:26 PM
Jon R's Avatar
1999 C43
Thank you for the information. I will try to see if things improve. If not, I will try to take it back and talk with the mechanic.
Old Oct 10, 2005 | 08:49 PM
StapleGun's Avatar
1967 Morris Cooper "S", 1983 911SC, 1997 Toyota Tacoma, 1999 HD FXSTB, 1998 C43
Tranny
Thanks for the posting....ANY info is good to have!
Old Oct 10, 2005 | 11:27 PM
VAamg's Avatar
1998 C43, White over two tone
My car idles around 550 as well, sounds normal to me though, should it be higher?
Old Oct 11, 2005 | 08:36 AM
C43AMG's Avatar
Veteran: Army
Mine idles at 550 as well , seems to be the norm.
Old Oct 11, 2005 | 12:03 PM
Jon R's Avatar
1999 C43
Hmmm. Thank you for the info. I must have been mistaken. Somehow I thought differently.
Old Oct 11, 2005 | 01:27 PM
StapleGun's Avatar
C43 Idle
My 'whitey' tends to be a 'weekend' auto - I'll warm her up this afternoon and see what her idle sits at.
Old Oct 11, 2005 | 03:44 PM
slvrstar's Avatar
clk
yeah, the dealer needs to reset the chip after the tranny change
Old Oct 11, 2005 | 03:53 PM
C43AMG's Avatar
Veteran: Army
For other than maintenance notification - why would the chip have to be reset ?
Old Oct 11, 2005 | 05:30 PM
StapleGun's Avatar
Idle
Due to the graduations, or lack thereof on the tachometer, I would say that mine is at that range maybe 560 +/- 10 and steady...so i would say that your idle sounds about right.
Old Oct 12, 2005 | 12:35 AM
Jon R's Avatar
1999 C43
Great. I am glad that things are how they should be.
Old Oct 12, 2005 | 12:49 AM
King320's Avatar
03 C32 AMG
Did you have this done at a dealer? You're in NC so im wondering if its within driving range. im getting ready to do the same to my CLK and my dealer wants $400.
Old Oct 12, 2005 | 01:43 AM
Jon R's Avatar
1999 C43
Yes it is! I am wondering why you were quoted $400 since I went to Bob Neil. You see, I live in Winston-Salem as well.
Old Oct 16, 2005 | 08:19 AM
ProjectC55's Avatar
C43/55,2k11 Volvo S60 T6AWD,2k Audi B5 S4,95 Eagle Talon Tsi AWD 500+awhp
Is that the image of the drain plug for the TQ converter in the pic? You did not give a clear depiction of where it is located! The other thing is to completely drain the TQ converter they should have had the plug built on the TQ converter.
Old Oct 18, 2005 | 11:12 AM
Jon R's Avatar
1999 C43
Yeah, it is hard to see. There is a drain plug build on the torque converter. It is located in the open hole just behind the exhaust (as in the picture). It requires a TORX screwdriver.
Old Nov 11, 2005 | 11:26 PM
lenwood's Avatar
had a certified mb shop do mine for $200. 8qts of mb trans fluid,filter kit. the cars tranny seems like new! fyi, c43s trannies go out around 65k if they are not serviced. this is what i'm told. well worth the money.
