Another Big Brake question
I am thinking to switch to a big brake kit since my rotors are on their final leg. I was thinking to get a kit from Stoptech. I have heard good things from them and like their prices.
Question:
1. What can the stock C43 17" rims clear?
- I think the stock ATEs are 13" rotors. There are two options for the C43:
- 332 mm (13") or 355 mm (14")
2. If the bigger rotor can fit, will there be any problem having such a large bias between the front and back brakes?
Thanks as always!
Jon R
Where did you find the information and pricing on the StopTek kit?
http://www.porterfield-brakes.com/
and yeah, StapleGun the cryo-treated rotors are worth the extra money for the treatment - last way, way longer than same rotor non-treated.
Plus they flat stop you and will save you some 30lbs of brake wt. Their rotors are double heat treated and don't seem to wear hardly at all. I had them double heat treat the rear rotors and slot them, so now they are not wearing away and look very nice with the slots and porterfield pads in the rear.
Jeff
