Srs Please Help!
Old Feb 23, 2006 | 10:05 AM
Vardar's Avatar
1999 C43
Srs Please Help!
Hey guys! right now my only problem is SRS light. Dealer said they would check it, but they will charge me for checking it ($96.50 an hour), I read it here in the forums that it is a common problem. Isn't there someone, some C43 owner or somebody fixed it DIY? I just need an input on how to detect the problem. There must be someone fixed this without the dealer.....
Thank you
Old Feb 23, 2006 | 11:07 AM
RobertG's Avatar
things with and without wheels
SRS is a supplemental restraint system usually it's controlled by a module with few sensors, wireing and the air bags.It sounds simple but you must be carefull with diagnostics because if the system goes off it causes damage to the interior and a big mess.If you dont know anything about electronics leave it alone and seek professional help.If you are capable then you will need a scanner to comunicate with the module and service manual find out what is causing the light to come on and how to fix it.
Old Feb 23, 2006 | 11:29 AM
Vardar's Avatar
1999 C43
Thank you sir. I ordered a nice scanner from EBAY, waiting for it. I already knew most of you said, I was wondering maybe someone got brave and tried to fix it himself, and took pictures while doing it. I belonged to the saab forum before here ( i swapped my Saab with this C43). In saab forum people were taking pictures of everthing they fixed. So I saved thousands of dollars like that. I don't wanna be DEALER-DEPENDENT..
Thank you again for your help sir
Old Feb 23, 2006 | 12:26 PM
RobertG's Avatar
you're welcome,btw you don't have to call me sir.Some people do a nice write up on the repairs here ,but without knowing what failed it's pretty hard to pin point the cause.Once you get a code from the scanner then try the search tab , good luck
Old Feb 23, 2006 | 12:59 PM
Vardar's Avatar
1999 C43
Thank you
Old Feb 23, 2006 | 09:03 PM
stox's Avatar
'95 S500C, '96 C36, '86 190E, '72 280SEL
It is unlikely that the scanner you are getting from eBay will help, as it is probably an ODBII scanner. As far as I know, the only way to get codes from the SRS system is with a MB STAR diagnosis scanner, or clone such as WinSTAR. These are $$$$$. These are also the only things that will clear a code stored in the SRS system. So, in other words, you are stuck with the dealer, or a well equipped independant mechanic.
Old Feb 23, 2006 | 09:29 PM
StapleGun's Avatar
1967 Morris Cooper "S", 1983 911SC, 1997 Toyota Tacoma, 1999 HD FXSTB, 1998 C43
I have an Assenmacher tool that WILL reset the SRS, it however will not read the codes that caused the fault. Swing by monday and we'll try it Buddy...see the link, this is what I have -----> LINK
Old Feb 24, 2006 | 12:30 AM
benztec's Avatar
02 c32 89 300e 99 c43(sold)
your going to need to scan the car(MB labtop). the srs tool might reset the light but if you have a problem in the srs system the light will come right back on. the light is not just on its on because your having a problem with the srs.
could be a seatbelt, brake light switch, airbag, ecu, and so much more!!! good luck
Old Feb 24, 2006 | 08:25 AM
Vardar's Avatar
1999 C43
Thank you all guys It is nice to be a member of this group. You all are pretty helpful. Now... My SRS light is on as well as the AIRBAG OFF light on the console. Does that change the situatuion?
Old Feb 24, 2006 | 08:35 AM
StapleGun's Avatar
Buddy - check all the electrical fittings for the pax seat. These are at the end of the footwell carpet just before you get to the rear seat's ductwork for the heater. I think, the SRS one is orange - I could be wrong. Unplug and reseat those connectors and see if that helps. Apparently the SRS thinks there's a child in the seat (weight < 30LBS) or connection is bad. Also, do a thread search for more ideas too...I'm off to work so talk to ya later!
Old Feb 25, 2006 | 12:45 AM
linuxfoo's Avatar
i would follow staples suggestion, on certain year of c43's, there was a common problem with wires being too short on the front seats, so when someone moves the seat all the forward or all the backwards, the wires get unplugged. good luck.
Old Feb 25, 2006 | 01:14 AM
steve s's Avatar
1996 C36 AMG, 1995 Volvo 850 Turbowagon
funny. the srs just went on for the c36 too.
Old Feb 25, 2006 | 02:54 AM
e320newbie's Avatar
91' 300e // 99 300e TD // 00' ML55 AMG
haha sir :P
Old Mar 9, 2006 | 10:18 AM
Vardar's Avatar
1999 C43
I might meet you at lunch time today my friend for reseting it, ok with you? (date is 03/09/06)
Old Mar 9, 2006 | 10:20 AM
Vardar's Avatar
1999 C43
Will try that, and will give you an update on this. I can't afford $800 for a new sensor
Old Mar 13, 2006 | 09:00 AM
Vardar's Avatar
1999 C43
Have you seen the documentation for this? I would love to take a look at it.
Old Mar 13, 2006 | 09:05 AM
Vardar's Avatar
1999 C43
Hello Staplegun, are these fittings close to the rear of the seat or close to the front? Or, right in the middle? I am gonna do this today.
Thank you
Old Apr 20, 2006 | 10:05 AM
Vardar's Avatar
1999 C43
SRS reset tool
I bought my C43 2 months ago with SRS light on, does anyone have SRS reset tool? I am thinking about buying one. I wonder if it really works or light comes back up again later?
Also second question, since %90 chance the child sensor is the problem of SRS light being on, would it be ok to totally disable the sensor(take it out) and bypass wires to make the SRS light go off instead of paying $750 to replace the sensor?
I hope i was clear, if not please ask me questions...
Thank you
Old May 4, 2006 | 11:15 AM
Vardar's Avatar
1999 C43
Sick Of Srs Light!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I wonder if any of you guys tried to bypass this sensor. I do not have baby or child seat, and I want that light off. Instead of paying $750 for the sensor, there must be a way to bypass the child seat sensor. Let me know if i am wrong please...
Thank you
Old May 14, 2006 | 03:25 PM
MBHustla858's Avatar
passenger seat occupancy sensor seems to be a common code. i just ship it out to the upholstry shop and let them slam it in and i reset it once they do that.
Old Jul 28, 2006 | 08:58 PM
Vardar's Avatar
1999 C43
The light is still on, and i am sick of it. You told me that there was a yellow cable underneath the pax seat, i can slide the frame, but can not unplug it..... Do you think we can still get together at lunch next week and use ur srs reset tool?
Thank you
Buddy
Old Jul 29, 2006 | 02:21 PM
RobertG's Avatar
I'd pm him if I were you.
I'm in the NY area.
Old Aug 1, 2006 | 01:47 AM
SMARTSSUCK's Avatar
Dude, you cant bypass the sensor, the control unit will always look for it upon the self test. Your stuck with it until you replace the faulty unit, or remove the cluster and take the light out.
Old Aug 1, 2006 | 05:34 PM
benztec's Avatar
fyi the air bags wont work if the light is on
Old Aug 2, 2006 | 08:01 AM
Vardar's Avatar
1999 C43
Just the pax or all of them?
