New guy needs help
Old Jun 20, 2006 | 12:56 AM
Corban Dallas's Avatar
New guy needs help
Ok so I am gonna be picking up a 95 c36 here in the near future. I dont know where to go online to find aftermarket parts(i.e. suspension stuff, ECU, etc). I am also looking to find out what parts will give me some decent power increases. Suspension will most likely be the first area I address. Thanks for the help guys.
Old Jun 20, 2006 | 01:32 AM
SDR's Avatar
SDR
'99 C43, '12 C63, '13 E350, '14 Sprinter
Welcome to the forums. As with any forum membership it's important you learn your way around. Here's the first place to start:
https://mbworld.org/forums/search.php
Old Jun 20, 2006 | 03:38 PM
So after some searching it seems like the car is pretty good as is. Sounds like some H&R's or Vogtlands w/ #4 pads works pretty well with the stock wheels. Do I need to replace the factory AMG/Bilstein shocks to run those springs?
Old Jun 20, 2006 | 03:43 PM
c55m8o's Avatar
'98 C43/55 AMG Speedybenz Susp. & MBenzNL On Board -- '88 560SL -- '09 JCW MINI -- '97 Jeep TJ Sport
Nice Handle! Welcome. Keep the rubber side down.
Old Jun 21, 2006 | 09:23 PM
Thanks Ok so I am set on getting some H&R springs and running #4 pads. Might get a new ECU if someone tells me it it actually worth it. Possibly some new rotors and brake pads too.
I am going to look at the c36 tomorrow, anything I should look out for? I has 121k btw.
Old Jun 22, 2006 | 12:45 AM
SDR's Avatar
SDR
There are some inexpensive (from $300 to $900) ECU tuners that claim amazing results. Then the are the real Benz tuners (RENNtech, Kleeman) who charge an arm and a leg and claim much more conservative results. It might be worth testing one of the low priced options. Worst case you're out a couple hundred bucks.
If you are a tinkerer it may be worth buying a spring compressor so you can test different setups. I went through many combos before settling on what I now run. Having to pay someone for the labor would have been huge.
Old Jun 22, 2006 | 01:05 AM
Not much of a tinkerer but I do have a buddy that work at a alignment shop, so that comes in handy. Its just seems like most people are pretty happy with their stock 17" wheels, H&R spring and #4 pads.
Old Jun 22, 2006 | 11:33 PM
midasmike's Avatar
'93 300CE
i have a box stock '98 c43. works just fine. i can't drive it 10/10ths yet. when i can, i'll start to mod it.
