Leaking Oil Cooler
W208.474 ///AMG
Ive appreciated this thread and hope to add my $.02 to Nitrogenbalances' "to do" post. Nitro- please feel free to jump in and comment on my answers to Kowalski.
[quote=kowalski;4435453] "...when you removed the hoses I noticed you have removed the oil filter, ..."
R: Im currently putting the cooling system radiator & hoses into a CLK55 W208 chassis. To reach 1 of the 3 gaskets that seal the oil filter, its necessary to extract the oil filter & assembly. Upon removal, access to the oil filter housing fastner/interface. Its about a 5" tube with a large "nut" at the end. I used a 1 13/16" socket to remove the piece. upon removal of the piece and oil filter housing, you will find a seal underneath. I will try to attach a pic or two of what I have done.
See additional notes
Q: Did you have to drain the (oil from the) engine?:
R: No.
However, to remove the radiator the oil cooling lines must be detached. I dont know the collar nut/fastner size. I fould it easy to plug each line with rubber stoppers.
Q: Did you also change the front squared timing case gasket?
R: ? I did not?
*Additional Notes
Per oil filter & drain Q: As Nitro-ballance points out "After taking this cooler off the engine I am definitely going to replace both gaskets. I removed everything,fan,radiator,it just makes the job that much more easier for you to spray and clean ALL the gunk off the motor ,especially in hidden places like behind the steering pump pulley and areas like that."
I dont think you have to go thru this to access the 3 gaskets however, I followed Nitro-B's lead and pulled the Radiator, mount, grill guard, etc., Its a bit of a pain to leave it in and by the time you realize the leak- chances are oils everywhere on the front end of your block.
Were I to do it again, I would plan to do the oil, filters, Radiator flush, belt, and what ever else can benefit from service.
Wish me luck- Im about to finish this up. I also noticed... it wouldnt be too difficult to drop the 2 radiators and add larger- straighter intake manifolds... but I should probably put it back together first? Hope this helps- Angelboy
R: No.
R: ? I did not?
*Additional Notes
Rue-Sant Angel6 thanks for your info dude.
Above you mention 3 gaskets for upper oil cooler?
http://www.autohausaz.com/search/ima...1121849961.jpg
Both these are on upper oil cooler sidewall
1 round small sized gasket
1 oval round larger sized gasket
Where is the 3rd gasket located? Largest sized gasket
These are the # parts numbers
Upper oil cooler seal kit, 3 gaskets: 1121849961
Timing case gasket version 1 old style: 1121840161
Timing case gaskeet version 2 new style: 1121840280
Do you know if there are more gaskets going bad?
Thanx
Thanx
none
Only replaced the two gaskets at the time, no timing cover gaskets.
This was done a long time ago and from what I remember I changed the oil/filter while I was at it.
W208.474 ///AMG
Thanx
Thanx
If you look under my profile and photos you will find pics with exp's. I dont know how to connect them to this thread. if anyone does, please advise.
RS-angel
W208.474 ///AMG
Heres a link to my photos... I hopehttps://mbworld.org/forums/members/rue-sant-angel6-albums-oil-cooler-seals-fix-radiator-removal-clk-amg-5-5l-n-w208-w210-picture16169-dscf7380.jpg
#32
I just viewed your pics in your sig, now I know where the 3rd gasket is.
At the bottom of Crystal lake oil filter housing
So the oilfilter housing needs to be removed to axxess this gasket.
How often does it leak from that bottom gasket?
great pictures thanx alot.
you da man.
you da man.
#33
W208.474 ///AMG
Kowalski,
how did things go? have more pic's and more mmm...problems to fix. IE idle pulley bearing seems to be going bad along with the belt. so if your still or have yet to get into this, Id recommend do these as well. let me know how its going!
peace-angelboy
peace-angelboy
#34
he only changed the belt tensioner, belt and harmonic balancer for me.
he didn't change the idler pulley, he said it's still cool!
I guess he didn't change it because of the loooooooong bolt!
You need to remove alot of parts to change this idler pulley, he thought it was unecessary to change it yet.
However I checked with the stealership and they couldn't find the 3 seal gasket kit in their computer even if I gave them the correct parts number.
I have to buy this kit from USA.
That's strange not being able to find a specific # - number?
I'm still lucky I don't have any leaks, but I will buy this kit to have it ready at home when the day comes for replacement.
Thanx man
#36
1 Post
C43 AMG 5.5 - 396.4HP
Concerning the oil cooler...
If you are located in frosty regions, check also the oil cooler for gear shift that is located intront of the right front wheel. It gets damaged by the salt. If not yet damaged, you can clean and paint it before it is totally destroyed.
#37
Location: Land of mountains, cheese, chocolate and watches
12' W204 C63 AMG coupe "T-Rex", 12' W451 Smart Fortwo Pulse (99' W202 C43 AMG sold)
I think if you remove the front bumber, you have an easy access to the gear box cooler. Guess I'll be doing a check, clean and paint.
#38
1 Post
Yes if you remove the bumper, you have good access. You need to remove the cooler to see the result. Especially on the top (what you can not see if mounted) and close to the tubes the salt burned deep holes.
The screws of the cooler where no more removable on my car. So I removed the cooler together with the mounting plate (2 screws) and cutted out the screws to the mounting plate.
My windings of the cooler where to connect the tubes were totally damaged. So I ordered a new cooler + tubes & pipes.
#39
Sorry to bring this thread back from the dead, I'm about to change all 3 gaskets (2-cooler, 1-filter housing) and before I separate the cooler from the housing, I need to know if I need to drain the coolant? It doesn't look like any coolant flows beyond the inlet/outlet pipes, and the holes are solely for oil flow, hence the cooling of the oil, but I wanted to make sure first.
I'd rather not have coolant all over the garage floor.
Thanks!
Thanks!
#40
Better late then never. If you replace all 3 seals it's easier. No draining coolant or oil or anything. Just unbolt heat exchanger leaving it connected with the coolant lines then remove oil filter. Then unbolt filter housing (big bolt/nut inside) then lift it out. You have access to all 3 seals. Then just reinstall reverse order.
#43
What is leaking from the oil cooler? Engine oil, coolant, or both?
Reason for asking is that it would seem logical to me, that coolant is circulating through the oil cooler, especially the OP mentioning disconnecting coolant hoses... And also that I recently had the oil cooler and filter housing gaskets replaced at an Indie mechanic, using non-OEM (Elring) gaskets, and since not only the leaking has not stopped, but I also started loosing coolant, and was curious whether coolant could be leaking from the oil cooler gaskets.
Torque specs for the oil cooler: http://www.benzworld.org/forums/atta...oil-cooler.pdf
Torque specs for the filter housing: http://www.benzworld.org/forums/atta...er-housing.pdf
#44
#45
1999 C43 AMG, 2005 E55 Wagon
Yes, two coolant lines straight from the water pump connect to the oil cooler. However, the coolant does not pass from the oil cooler to the oil filter housing, it remains in the one-piece oil cooler. Only the engine oil passes between the filter housing and the cooler. The coolant feeds into two small pipes on the same side and circulate through just like in a tiny radiator. If it is leaking, you have a hole in this area that likely can't be repaired, or a faulty connection where the hoses connect to the cooler.
http://c1552172.r72.cf0.rackcdn.com/308145_x800.jpg
#46
#47
Looks like the easiest way to replace this is buying the oil cooler with the filter housing attached? does this part come with all 3 seals installed already or do i need to buy the oil filter seal separately?
EDIT:
ok sorry, i see the answer now. there is a kit with all three seals. im just a little confused why the cooler/filter housing doesnt come with the seals already installed.. thats a bit weird. so i have to disassemble the part, insert the seals and reassemble the part? thats crazy. has anyone bought this part already?
guessing this is the easiest, just clip those hoses, drop some towels over your belt and clip in the new part. sounds like a lot less work than draining and disassemble the fan to get down there and unscrew the cooler alone (which probably wont sit flush anyway...)
so on the new kit, just seals and no sealant since it is new and flush?
#48
so you dont need the seal kit if you buy the entire cooler with housing (from FCP Euro at least anyway) im going to clean it up nice and seal the outer edge with MB sealant. give me a few minutes to find the sealant. you will need the seal for the housing only, not sure if the only way to get that is in the three seal kit. anyway the kit was only 10 bucks.
i notice they grinded off a part number, probably the MB part number. so make sure you clean it up very very very good cause you will get metal shavings in your oil. BTW does anyone know the torque amount for these screws? they came off pretty easy so not much im guessing.
#49
cant find the sealant. i have a new one that i dont want to open, i have half a tube open somewhere if it didnt dry out. will check the storage tomorrow.
looking for torque specs on the oil cooler and nut for filter housing. looks like a 10 minute job cant believe some indy asked me for $500 plus cost of new oil cooler/housing
#50
70Nm or 55 lb-ft is the correct torque spec. Just did two of these in the fall. Be prepared, I had to use a 3' extension pipe over my breaker bar handle to crack that hollow 46mm bolt loose. The cooler-filter bolts did not have torque specs that I could find; I snugged them up with a 2.5" driver handle and they did not strip nor does it leak.
