Kleeman headers Arrived W202 W208 55's
Fire away!
how much will install be approximately?
-O
Like you said we'll see on the dyno and the track that is!
I'm crossing my fingers for some impressive gains and easy install. Would love enough temptation to spring for some myself. Heck... lie to me if you have to
at least the damn bolts!I will keep everyone posted as promised!
I have installed those on CLK430 with Shrick cams there was a 35RWHP gain. Since C43 has hotter cams already, my guess you will somewhere in the vicinity.
. You may find studs instead of bolts. You are going to see a major difference in performance . Just show them a stock log style exhaust , next to those really nice headers. Don't worry about the 7-8 exhaust reversion pulse thing. Yes they are right next to each other in the Firing order & that is something you cann't change. In your case , the stock ,very restrictive log style manifold. and They were very close! . It looks like with the Kleemann header system ,they doubled that distance ,between 7-8 and did a major tube diameter increase. All in all . It all adds up (so to speak)
Vadim and Patrick then I'll take your wrd for it. Thanx to you both! Yes I guess Vadim did not know my C43 has a 5.5l motor in it!
Well we'll see what the results say.
The downpipes I have to admit are nice pieces measuring 2.5" and SS. If the stck exhaust mani gaskets are bigger than the flange openings I will have my turbo manifold fabricator open the header flanges up to match the gaskets.
Pat I know about the studs in the head! They just did not send me the bolts for the 2 down pipe exhaust flanges. My friend received the bold flanges with his Kleeman E55k headers. Oh well. My car is 9yrs old after all I guess!
hopefully i'll have the suspension,headers everything done within these next two weeks and finally post a dyno. B4 and aft!
Finally ,is heat coating these babies necessary?
