C36 miss fire
i've had that happen to me in the past, they even replaced coil packs with no luck, and then i found it was an oxygen sensor that was on the way out, not fully bad, but getting close that was creating the missfire, once replaced no problems at all, might want to check that before spending any money on expensive stuff gl
This is assuming, of course, that your compression test is OK.
