what are these items
Old May 4, 2007 | 05:38 AM
KJI3jflarryfe93's Avatar
hi just want to know what these items mean and where they are located on the engine.I know what ignition coils are.
Coilpacks?=
Coilends?=
Old May 4, 2007 | 07:04 AM
StapleGun's Avatar
1967 Morris Cooper "S", 1983 911SC, 1997 Toyota Tacoma, 1999 HD FXSTB, 1998 C43
Coilpacks sit atop your valvecovers, there will be four on each side with two high tension leads out of each coilpack. Each of these leads will have a metal housing at each end that fits over each individual spark plug.
Old May 5, 2007 | 05:15 AM
Exclamation what is the flexdisc i've been reading about
is it inside the gearbox or is it on the cars transmission beetwen the rear axle and gearbox?what happens if this goes bad? cheers mates
Old May 5, 2007 | 11:33 PM
SDR's Avatar
SDR
'99 C43, '12 C63, '13 E350, '14 Sprinter
The flex disk is basically a rubber coupler at the ends of the drive shaft. It can be a pain in the rear to replace. Had to replace the front one on my 190.
Old May 6, 2007 | 09:08 AM
StapleGun's Avatar
I'm not sure what a flex disk is, but I do know what a BMW guibo is...which is what was described by SDR - a rubber donut w/holes for the driveshaft/propeller shaft flanges. Yes, a pain...but not too bad to replace. I replaced the guibo on my old 325es Look for large cracks, and or symptoms akin to when you have a bad universal u-joint. I need to inspect mine, in fact...
Old May 6, 2007 | 04:00 PM
MarcusF's Avatar
2002 CLK430
Originally Posted by StapleGun
I'm not sure what a flex disk is, I do what a BMW guibo is...which is what was discribed by SDR - a rubber donut w/holes for the driveshaft/propeller shaft flanges. Yes, a pain...but not too bad to replace. I replaced the guibo on my old 325es Look for large cracks, and or symptoms akin to when you have a bad universal u-joint. I need to inspect mine, in fact...
That's it exactly. Here's a photo of one
Old May 7, 2007 | 06:03 AM
StapleGun's Avatar
Voila! Just type in BMW guibo in google image search
Old May 7, 2007 | 07:27 AM
Smile
hey buddy thanks for sharing this picture,here in Sweden we call this HARDY skiva= hardy disc. I could not had figured out that this was called a flex disc cuz I thought it was something inside the transmission.thanks again
Old May 7, 2007 | 09:49 PM
StapleGun's Avatar
No prob - it's what we're all here for. Had 'fun' at least replacing one of these on my ol' BMW
Old May 10, 2007 | 01:54 AM
Post what's the flywheel=?
and where is the fly wheel located>? What are the symptoms of WHEN SOMeTHING GOES BAD is it rust or what>?
I bouhgt a new crannk shaft sensor though the one on the car isn't busted yet,my car is still firing up perfectly,should i put the new sensor on and avoid future problems=?
cheers mates
Old May 10, 2007 | 05:21 PM
SDR's Avatar
SDR
http://en.wikipedia.org/wiki/Flywheel
The flywheel attaches to the end of the crankshaft.
Old May 10, 2007 | 09:27 PM
StapleGun's Avatar
cheers mates
That's a good item to replace to avoid problems - the flywheel is located on the opposite side of that bell housing (contained within) where that CPS fits in. It's basically a large wheel with a gear ring on its periphery, it's attached at the end of your crankshaft. The starter engages the gears, thus spinning your crankshaft to start your engine.
