My 1995 c36 amg will not start in P
Old Dec 12, 2007 | 01:21 PM
croatia28's Avatar
1995 Mercedes c36 amg
It only starts in N, anyone have any suggestions??
Old Dec 12, 2007 | 02:15 PM
Militant-Grunt's Avatar
95 Audi urS6 Quattro
Sounds to me like the Ecu doesn't see the tranny in park.
Old Dec 12, 2007 | 02:27 PM
croatia28's Avatar
Is the ECU expensive to change? Could it not be the neutral safetly switch?
Old Dec 12, 2007 | 02:44 PM
UCF202's Avatar
1999 C280 Sport
I'd say neutral safety switch.
Old Dec 12, 2007 | 08:01 PM
m a x i m u s's Avatar
C63 AMG P30 *EuroCharged*| Porsche Cayenne | Buell XB9SX
+1 on the neutral safety switch. i had a similar problem on my C43.
Old Dec 12, 2007 | 11:30 PM
98C43AMG's Avatar
1998 M/B C43 AMG
++1 Neutral safety switch, common problem on many cars
Old Dec 13, 2007 | 03:05 PM
OPTIONII's Avatar
98 c43, 2004 e55, 1997 toyota supra turbo, 1994 rx7 LS6/T56
try to put the gear in neutral then see if it starts.
Old Dec 13, 2007 | 03:56 PM
croatia28's Avatar
yea it does start in N
Old Dec 13, 2007 | 08:10 PM
Jons95c36amg's Avatar
02 CLK 55 AMG,09 C63 loaded with P30
Weird whats the cause of that?
Old Dec 14, 2007 | 12:50 PM
croatia28's Avatar
Is it not supposd to start in N, if its the neutral safety switch?
Old Dec 14, 2007 | 01:39 PM
MBHustla858's Avatar
probrably your neutral switch, you may want to check and see if both your shifter bushings are there and acutally putting the switch into park.
Old Dec 14, 2007 | 01:45 PM
croatia28's Avatar
ok thanks for the replys
Old Dec 14, 2007 | 01:49 PM
ohlord's Avatar
On
a 95 the nss may also incorporate the back up light so with the car on and the back clear of objects put it in reverse and have someone off to the side see if you have back up lights.If not the nss is faulty.Some of the older ones can be adjusted.Although it may be shot and just as easy to replace as to adjust.
http://www.autohausaz.com/search/pro...afety%20Switch
from the picture it does seem to be adjustable so give yours a try before you write it off,it may have just vibrated off its proper spot.
ohlord
Old Dec 14, 2007 | 04:51 PM
croatia28's Avatar
alright thanks buddy, i will check it out
Old Dec 19, 2007 | 05:47 AM
DamonAnthony's Avatar
2003 Ford F350-gone 2002 Mercedes C200 Kompressor 1998 Suzuki Vitara 1995 Mercedes C180-sold
I'm driving a 95 c36 at the moment too, same problem, have heard its the switch too. can you keep me posted on what it actually is, its lower on the list of things to do but does need attention.
Thanks, Phil
P.S. How good is the look on peoples faces when you pass them!!!!
