My HPS Gen. I/custom SUPERCHARGER thread-
The knock sensor thing is bad. I've been told our cars are set up well for this issue but its still very scary. I've actually never even heard them. Just heard stories. Then again, if any setup would activate them, it would be our supercharged ovens. I was thinking about starting to install the H20/meth this week...we will see.
Please post any questions you have as well- we can help much better than the directions
1) Did you buy a new or used kit? If it was used did you get it from HPS or another party? Did all the parts come? If not how much more did you pay?
I might pick up a used HPS kit from Mech-Tech for peanuts. They promised me a before/after dyno with air/fuel ratio. So I'm not worried about fuel. Just want to make sure I don't have to spend more $$$ on parts.
Good luck!
my kit was missing many parts and had duplicates of many others- but i worked through it.
also- let me highly recommend a larger fuel pump. i'm running optimal afr's after swapping.
my afr's are 11.3-11.9 under wot with that and the "stock HPS" fmu... woot!
I have a lot of fuel "added" above voltages of 3.9 or so (maf readings)- would be very lean yet without it.
I will definitely be upgrading my fmu down the road- what model number are you running? unless i do actually get the ecu tuned. i was planning on an ecu tune very soon, but the success with this pump has postponed that. I think i will wait to do ecu tuning when i do "stage II" (centri blower and more boost and hopefully 5.4 litre)
-drew
