Air conditioning issues...
Old Feb 19, 2008 | 06:19 PM
Back2Benz's Avatar
Gone but not forgotten C36
my 95 C36 has 85k miles...just got the a/c recharged a few months ago...a/c is cool, but not cold..no problem, I can accept that for a 13 year old car
Recently, I've been having a few issues with the a/c...
1. The direction for the vents for the a/c is not accurate. When I push the button with a top AND down arrow, cold air doesn't always come out.
2. When there is air coming from the center vents (on top of the stereo), the air from the side vents (next to the doors) disappear..?
3. Air is always blowing to the front windshield, regardless of which button I push.
4. At times, I can't get cold air to the feet when it's hot outside, but I can get hot air to the feet when it's cold outside...really weird...
Summary... a/c direction buttons usually don't correlate with the vents, air always blowing into the front windshield (robbing air from front, side, and feet), difficult to control cold/hot air to feet
Thanks for any advice!
Old Feb 19, 2008 | 10:12 PM
StapleGun's Avatar
1967 Morris Cooper "S", 1983 911SC, 1997 Toyota Tacoma, 1999 HD FXSTB, 1998 C43
Check for a gray plastic line (pax side) along the firewall, it taps into a vacuum source - it may have slipped off. You can see the elbow in the lowermost arrow, the top arrow points to the location along the firewall - this line being disconnected my be the source of your problems...
Old Feb 20, 2008 | 08:59 AM
cfourthree's Avatar
98 c43
I had the issue of no air blowing in my upper vents. Staplegun guided me through and it works perfect!!
Old Feb 20, 2008 | 07:08 PM
C43AMG's Avatar
Veteran: Army
98 Black C43 , 12’ ML 350 Blutec
That's why he's the man..........
Old Feb 21, 2008 | 10:19 AM
Back2Benz's Avatar
thanks (again ) for the advice, I'll definitely take a look at it!
Old Feb 23, 2008 | 10:25 PM
Back2Benz's Avatar
took a look at this gray plastic line...it was on there and you can twist the elbow....probably not the source of my problem. I was not sure as to what to do with it...unplug and plug it in again (it is twistable)?
Old Feb 24, 2008 | 09:29 AM
StapleGun's Avatar
Follow that gray vacuum line along the firewall towards the engine - it usually slips off there, not at the elbow. Don't tamper with the elbow it's plastic and it's just a ninety degree T.
Old Feb 24, 2008 | 10:33 AM
cfourthree's Avatar
98 c43
mine slipped off on the drivers side firewall.
Old Apr 29, 2008 | 10:13 PM
Back2Benz's Avatar
Finally had the guts to feel around and discovered the sections of the hose (close to the rubber "L" shaped connector) was burnt which caused a leak in the hose...(you guys were right!)
I had no luck trying to find this line in the AC & Heat - Climate Control section at autohauzaz http://www.autohausaz.com/search/gro...mate%20Control
-where can I find this line?
-is it hard to replace/remove and install?
Thanks!
Old Apr 30, 2008 | 01:32 AM
Z06EATER's Avatar
1997 C36AMG
your best
bet is the dealer bro
Old Apr 30, 2008 | 02:56 AM
silence's Avatar
sounds like airplane
you can patch with rubber vacuum line
Old Apr 30, 2008 | 08:00 AM
StapleGun's Avatar
Just clean up the end (make a clean cut) and add some rubber tubing - any vacuum line will work, no need to buy MB line for that, it's just a vacuum hose. Come on guys get a little imaginative here, otherwise your MB ownership is gonna be a costly one.
Old Apr 30, 2008 | 10:25 AM
Back2Benz's Avatar
thanks for the great ideas fellas! I'll keep you guys posted!
Old Apr 30, 2008 | 11:40 PM
Back2Benz's Avatar
I bought a foot of some rubber vacuum lines at Kragen....also thought about getting some 'heat shrinks' to provide more protection as well as possibly looking for some 'heat resistance' metal material/wire to wrap around the area that burned so it won't happen again...
well...I'm off to try the fitment and to see if my ac vent selector will work...wish me luck!
Old May 1, 2008 | 12:09 AM
Back2Benz's Avatar
UPDATE****
IT WORKED!!!! For the first time after I bought this car, I finally have control of the vents!!!
THANK YOU StapleGun (and others for your input and encouragement) !!!
The way the line sits 'appears' (from feel cuz there's no way to see down there) to be away from any surfaces that might burn it...so it should be alright...but I'm wondering why it burned??
Old Jul 2, 2008 | 11:41 PM
squirrelonfire's Avatar
1998 E 320
Could you zoom out of the picture so I know where is that gray line located. cause by looking at your picture, I have no idea where to look.
Old Jul 3, 2008 | 12:44 AM
steve s's Avatar
1996 C36 AMG, 1995 Volvo 850 Turbowagon
my 95 C36 has 85k miles...just got the a/c recharged a few months ago...a/c is cool, but not cold..no problem...
on our barely driven c36, a/c was recharged but still wasn't cold. turns out it had 6 seals that failed or cracked or something. might be something worth looking into. my wagon had two o-rings around the condenser that cracked and let out the freon or whatever they use now.
Old Jul 3, 2008 | 10:52 AM
SeeKlasse's Avatar
'98 C43 AMG. Obsidian Blk w/2 tone slvr/blk interior
those high engine temps can really weather alot of the items in our motors. i have wires that run along my fuel rail to the fuel injectors, one of which has an area on its protective jacket that has been eaten away. the two wires inside are pristine, but i think im going to wrap 'em before they get damaged... we should all keep an eye out for these weatherable items as they could be a future source of hard to diagnose problems.
Old Jul 3, 2008 | 01:40 PM
ohlord's Avatar
squirrelonfire
Your car has a different system.Come downTo the w210 section and run the dual climate control onboard climate control diagnostics program.If you have issues with your A/C.
ohlord
Old Aug 16, 2008 | 12:44 AM
Back2Benz's Avatar
Thought I'd just continue this thread to ask about my a/c "problems"...
The a/c did not blow cool or cold air when I got it last November. But it did get a little cooler after I got it recharged at a local indy shop, the thing is, there was no freon in the system prior to recharging it so it was a 'freon issue'. It's been many months and I've lived with the a/c being a little cooler when I set it at "Low"...it's been pretty hot here in Socal and would like to enjoy some nice a/c (I'm not expecting blowing snow, but something much cooler than now would be nice)
I'm interested in recharging the freon myself...what advice do you guys have and what brand/type do I need to get (from the local Pep Boys, Kragen, Autozone, Super Autobachs, etc...)...
Thanks in advance!
Old Aug 16, 2008 | 12:55 AM
Back2Benz's Avatar
I guess I'd better leave it to the stealerships and indys then...
