solid rear axle
Also you might like to note that MB's have been using independant rear suspension for a very very long time now, even the W201 was using a 5 link rear suspension which is only just appering on some cheaper rwd cars now. A 9" is a live rear axle, not really great for going round corners.
I discussed swapping to another MB rear end with Cory from kleemann and he explained that the ASR/ESP system relies heavily on the rear end as well so it would trigger things downstream if you were to change it. The last promising detail I got was from mbenzman stating that he "may" be able to modify the W202 rear for a quaife LSD.
as far as the "just get a camaro" comment- i don't think a properly done solid rear would be nearly the detriment to the car that you think it would be. I would put money on me out running a similarly equipped car with the stock rear diff with a 9" equipped car (with the gears and diff. of my choosing) in an autocross or track environment- and at a potentially much reduced cost.
Just wait until i start trying to figure out how to swap a chevy 6 speed in... dont' want to waste your barbs now.
I'm a fan of what your doing and like the fact that your not affraid to be different in terms of MB modifications. I must admit that my MB's have been the most challanging to mess around with.. my experience with the 5 link rears has been better than my experience with solid ones is all I really needed to say. I know you understand the two.
Why don't you do us all a favor and work out the details to fit a quaife LSD in there, then you can keep the dynamics of the 5 link. Just a thought.
Also, I think the 6-spd manual sounds like a great idea if you can get it to work. This car absolutely needs a manual trans to reach its full potential...esp if it were being driven by a 5.4L m113
I don't think many folks would object to using a Tremec or ZF trans for this application....hell, Renntech used a ZF 6-spd in both the w124 500e 6.0 conversion, as well as the CLK60
I have no qualms with suspension design and fabrication though (see my explorer
)You're probably right that would be the best solution though.
btw- i picked up a terminator heat exchanger and will be test fitting that in a couple weeks in my moving towards my self styled air-water set-up.
-drew
MB 5 link suspension is used upto engines giving 1250NM of flywheel torque so power capacity isn't an issue either.
The only downside is the cost of a LSD which is still considerably lower than the retrofit cost of a solid axle and LSD
additionally, i would be interested in regearing.
maybe you know something i don't know about what lsd would work (and would really WORK)?
i'll keep the stock suspension and figure out an lsd until i figure out how to go over 500 whp or so... at that point i'm going to do whatever it takes to get traction.
i deliberately blew the esp/bas fuse and then ran fuse taps off of both leads (fused on the hot side) to a switch. Flip the switch for full-off dyno/play mode. I may go in and do it the right way (pulled fuse, find the wire colors and install the switch there down the road- but wanted to make sure it worked first).
will a w201 lsd work? no one has mentioned this option before?
300e 5spd is a direct swap manual tranny and I heard both the old e & W201 diff internals can be transplanted over. its a bit of work but could be worthwhile investment. If you don't want to go to all that trouble just get a set of really wide sticky rear tires and roll your fenders a bit, much simpler & easier solution
i doubt any streetable set of tires is going to make my car hook for long with the power i hope to make after a few more years of ownership. I could do a widebody (just finished one for a friend's a4 btw) but that just isn't the solution to the problem. the solution is to spin both tires at the same time.
i'm very interested in any more information anyone has about swapping in w201 lsd or parts...
-drew
