Info needed for c55 install?
Old Mar 16, 2008 | 05:46 PM
cya l8a's Avatar
c43
Fellow c43ers,
I drive a 99 c43 and I love the car .I now will like to do the engine swap and then install the hps2,But I don't know exactly what extrs parts and what mods.eg{ecu}and engine mounts I know a few have already done the change I will like to do it and post it in detail for others.Also any particular model to get the engine from 1999 to 2002 cl55 ml55 s55 and so on? of are they all the same? even if someone has contact for the engine will be greatly appriceated.
Old Mar 16, 2008 | 10:08 PM
mertd93's Avatar
04 E55 B07, 11 CL63, 17 GLE63S
Originally Posted by cya l8a
Fellow c43ers,
ProjectC55 is a member who's done the upgrade, he knows everything about it, try contacting him.
Old Mar 16, 2008 | 10:49 PM
silence's Avatar
sounds like airplane
i know you don't want to install the hps gen II
Old Mar 17, 2008 | 01:47 AM
SeeKlasse's Avatar
'98 C43 AMG. Obsidian Blk w/2 tone slvr/blk interior
ive been asking the very same question and proj55 claims that i need to dig around the forum and read up, stating that all of these discussions were already covered in the past. ive yet to find the thread. someone please link me!
Old Mar 17, 2008 | 09:37 AM
ProjectC55's Avatar
C43/55,2k11 Volvo S60 T6AWD,2k Audi B5 S4,95 Eagle Talon Tsi AWD 500+awhp
L-A-Z-Y!!! Search my threads started perhaps!
https://mbworld.org/forums/showthrea...t=#post1149263
Old Mar 17, 2008 | 09:40 AM
ProjectC55's Avatar
Mertd93 and TechTune are having great success and putting out higher hp #'s with the HPS II kit vs the HPS I kit believe it or not. And I like the fact that the kit is quieter and more undercover.
Old Mar 17, 2008 | 10:51 AM
cya l8a's Avatar
c43
Thanks for the info.I also spoke to mark at HPS and the unit is the second gen so all the bug are supposed to be gone and is a much more silent sleeker unit that is why I need to do the swap before rather than installing the HPS in the 4.3 engine.I alerady located alot of 5.5s the site is car parts.com there are lots.I'll make some calls and I will keep the update as I go.
Last edited by cya l8a; Mar 17, 2008 at 11:12 AM. Reason: just some correction on yhe info
Old Mar 17, 2008 | 03:40 PM
silence's Avatar
just go custom SC-
do some searching about HPS and particularly the Gen II.
there may be some kits out there that are working... so?
Old Mar 17, 2008 | 05:45 PM
mertd93's Avatar
The bugs are still there, trust me .
Old Mar 17, 2008 | 07:11 PM
svt ricco's Avatar
1999 C43 AMG
from what i've read before, hps gen 1 is safer than gen 2. i just can't remember where i read it. do more research bro.
Old Mar 17, 2008 | 07:41 PM
silence's Avatar
it's not that gen I is "safer" it's that the gen II kit is the biggest debacle of all time.
Old Mar 17, 2008 | 10:23 PM
ProjectC55's Avatar
Mike why don't you at least mention in a pm or something how you have improved the HPS II kit? It's obvious these guys don't know. We both know that it is the only kit that is going to work for the 5.5L motors as well.
Old Mar 17, 2008 | 10:51 PM
silence's Avatar
seriously though-
if i had to start over (or hadn't gotten the gen I for a song) i'd just build it custom with a centrifugal... I recently sold a guy the gen I sc bracket so he could do this himself.
My gen I kit will have me on the right track when i want to swap to a centrifugal and/or the "55" (not sure which will come first)
Old Mar 17, 2008 | 10:55 PM
silence's Avatar
if you're referring to me not knowing how he has made his gen II kit work? who cares, unless the op will have the same improvements...
Old Mar 17, 2008 | 11:36 PM
mertd93's Avatar
Carl, because nobody really cares, look at the attitude on some of these guys, they think they know it all, same like the one who took the kit off his car, plus you're the ONLY one who believes that the kit works. I would help other people but nobody shows any interest. If anybody was to try to touch this Gen 2 it will be you, and I hope you find a used kit for a good price one day because I want to see that little monster in the 11's one day.
Old Mar 18, 2008 | 12:45 PM
silence's Avatar
wow, guess i'm really missing out on something.
maybe i should be recommending the op purchases something where the only person i've heard of having success with it- won't share how... why not just say what you changed?
i'll gladly list and chronicle the changes i've made and plan to make to the gen I kit to help others...
Old Mar 18, 2008 | 05:59 PM
ProjectC55's Avatar
You'd be surprised!!
Perhaps you don't care but what Mike does to the Gen II kit BLOWs the Gen I kit away. It's a superior setup in theory also vs the Gen I kit. Not to mention that this is the only kit that can work well on a 5.5L motored car. So if you go 5.5L in the future,either consult Mike if you go with a positive displ setup. If I were to go centrifugal I would consult with Greg C(CLK55) for a centrifugal setup.
Your setup will only wrk well on the 4.3L which does seem to give very good results, but not great on the 5.5L without further modding the Gen I as was proved by E55cent.
Go HPS gen II modded/consulted by Mike and you'll see even more of an improvement.
Old Mar 18, 2008 | 06:24 PM
silence's Avatar
i don't get what makes you think i'm so dumb?
obviously, the gen II is a better idea in theory (hence virtually every other charger on any other car EVER being done that way)
that said, the gen II kit had bugs beyond belief and it's been well documented- unless he cares to share how he fixed the kit the kit is basically useless to the op.
after all that- he has his dyno numbers in his sig. I'll race his SL with my Gen I kit this year after my tweaks and be suprised if i lose... It won't be because the Gen I kit is a better idea though.
Old Mar 18, 2008 | 06:52 PM
ProjectC55's Avatar
Boy you're a testy one. Relax! Who called you a dummy?
Here is a statement from you:
And all I'm doing is addressing your statement and mentioning how Mike has improved the HPS Gen II kit which makes it live up to the hype!
By the way here is the thread and dyno of Josk k's CLK430 centrifugal kit:
https://mbworld.org/forums/showthrea...769&highlight=
Greg C (CLK55 centrifugal dyno) and thread:
https://mbworld.org/forums/showthrea...955&highlight=
Gen II HPS modded by Mike on 5.0L motor 398whp 384wtq vs 380whp on Greg's 5.5l motor wuth the powerdyne setup on Greg C's CLK55.
Sorry to get off topic some but I really psoted this also for my purposes.
Silence I would love to see how all three setups compare as soon as u can post a dyno. I think this would all be interesting to see.
Mike I hope I find a gen 2 kit quick!!
Old Mar 18, 2008 | 06:58 PM
ProjectC55's Avatar
Well hurry up and let's see. When r u gonna track her and take her to the dyno? Would love to see the results.
Unfortunately the Gen I kit kills the 5.5L motor as seen in Greg C's HPS example on the graph. Josh K is making more HP with the CLK430 vs Greg with the HPS Gen I setup.
Old Mar 18, 2008 | 06:59 PM
mertd93's Avatar
All the parts were changed with the exception of the plenum, runners and fuel rails, I think you know which parts were changed now.
Old Mar 18, 2008 | 07:01 PM
mertd93's Avatar
I hope so too
Old Mar 18, 2008 | 07:02 PM
ProjectC55's Avatar
Mike 398whp and 401whp(Alex) on your setup with the 5.0L is damn good. I'm only trying to imagine what the kit will do on a 5.5L motor!
Old Mar 18, 2008 | 07:08 PM
mertd93's Avatar
It will do wonders, plus you have headers on top of that, add the 80mm TB and you're done. We're working on getting headers and cams this year so we should make a little more power.
My car is going back to the tuner tomorrow, it's getting retuned with 1 more lb of boost, so my dyno should look different by next week.
Old Mar 18, 2008 | 07:17 PM
mertd93's Avatar
Your car is about 700lb lighter than mine, I hope you know that. Btw how fast is your car in the 1/4 mile?
