ASR OFF????
Old 05-27-2008, 01:29 PM
kinghais's Avatar
1999 W210 E300 Turbodiesel
Exclamation ASR OFF????
Does anyone knows how to turn off ASR?????
i like to spin the tires and go side ways but this ASR stop me. even when it's off it's on when i try to drift with it.
Please help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!
Old 05-27-2008, 02:23 PM
NitrogenBalance's Avatar
none
It could just be me but I find the 202's to be a handfull when drifting. I've gotten into trouble a few times and almost couldn't correct. Be careful and what you want to do is either unplug the ASR "brains" within the engine bay or pull the fuse. Keep in mind this disables your ABS along with stability control. I wouldn't drive the car like this on the road. I've done this in a wet parking lot which was pretty fun I'd just be careful as it may surprise you a couple times.
Old 05-27-2008, 03:07 PM
silence's Avatar
sounds like airplane
you can wire a switch in that allows you to "pull" the fuse by flipping the switch
once you flip the switch you have to shut the car off and restart in order to regain abs/esp control
i wouldn't recommend doing this with a stock vehicle- what are you going to gain? you probably shouldn't be doing too much drifting anyways
Old 05-27-2008, 03:39 PM
Z06EATER's Avatar
1997 C36AMG
these babies aren't import tuners
i think you been lookin at too much fast and the furious lol....it's a benz, treat it like one....u wanna drift buy a honda...don't wanna bash u...but i'm just telling you, these cars are rare, and expensive to maintain.
Old 05-27-2008, 04:42 PM
kinghais's Avatar
I don't really wanna drift, i just want spin my tires and go side ways on the corners. like BMW , it let u turn the traction control %100 off.
Old 05-27-2008, 05:39 PM
Z06EATER's Avatar
1997 C36AMG
well in that case
wat i do that is very simple is just press the ASR button, and make the ! mark light up on the speedo, i can light my tires around a turn, and it won't bother me
Old 05-27-2008, 06:12 PM
silence's Avatar
it's still on hwen you do that
Old 05-27-2008, 06:16 PM
Z06EATER's Avatar
1997 C36AMG
true
but it will let you do donuts and spinout with out cutting the acceleration
Old 05-27-2008, 10:34 PM
kinghais's Avatar
it does but still i want to be more free. i feels better when it's %100 off.
Old 05-27-2008, 10:36 PM
kinghais's Avatar
Question
Can anyone tell me where is that ASR Fuse please???
Old 05-27-2008, 11:13 PM
silence's Avatar
as soon as you stop posting a picture in every post?
your car looks fine- but we all own them (or nicer ones) and know what they look like
Old 05-27-2008, 11:28 PM
Z06EATER's Avatar
1997 C36AMG
wat
silence really means is, make the pic smaller. it's really big man ok?
Old 05-28-2008, 12:10 AM
kinghais's Avatar
Talking oops
sorry guys, i did not recognize that. i see it now it is big. i'll try to put a smaller pic now.
Old 05-28-2008, 01:04 AM
silence's Avatar
on my car is it fuse #16- should be listed on the underside of the fuse cover as well
Old 05-28-2008, 01:29 AM
SeeKlasse's Avatar
'98 C43 AMG. Obsidian Blk w/2 tone slvr/blk interior
ha, pic in every post.
yo z06. you cant drift with honda's theyre garbage front wheel drive cars. s2000 practically has a motorcycle engine which is all high revving and terrible for drifting, the nsx would be the closest thing to a driftable car that honda makes, and they only released a japanese honda nsx.
theres a guy who did a motor swap on the 350z with the 5.6 titan motor.... pretty good drift car
Old 05-28-2008, 02:00 AM
silence's Avatar
the swapped car makes less power than a ton of the stock motors are with boost though- of course tq is great, but the 3.5 is relatively well off in that respect too.
give the car in my sig about 4 years...
silence's Avatar
if anyone really must do a pic in every post it needs to be a topless girl
Old 05-28-2008, 11:18 AM
kinghais's Avatar
Is the fuse is in front fuse box on right side(driver side)? or the one in trunk?
Old 05-28-2008, 12:22 PM
Z06EATER's Avatar
1997 C36AMG
i think under the
hood, there is a label on the cover that tells you wat fuse is wat..
Old 05-28-2008, 12:38 PM
kinghais's Avatar
have u done it?????
Old 05-28-2008, 01:51 PM
Z06EATER's Avatar
1997 C36AMG
lol hell
naw man, i care too much bout my car too do anything like that. but hey it's your car, just be careful!
Old 05-28-2008, 02:44 PM
kchristos's Avatar
Don't have a Mercedes right now...
Do a search on dyno mode, you should be able to find the sequence of keys to use to disable the traction that way but as the other people told here those cars are not meant for drifting and if you haven't done it before you better attempt it ina safe place or be prepared to smash the car.
Old 05-28-2008, 06:19 PM
Dr. C36's Avatar
1996 C36 AMG
if you disable ASR you will disable ABS brakes, be careful what you wish for. I've driven my car without both and its straight up scary, I HIGHLY recommend you reconsider otherwise your C36 ownership may be cut short once the car is cut in half wrapped around a telephone pole.
Just drive the car in "ASR off" mode and get much better (and wider) rear tires, that will sove most of your issues.
Old 05-28-2008, 09:43 PM
silence's Avatar
i dont' recommend or suggest anyone else turns their abs off- but i've pushed my car very hard in autocross type situations (informal) and did not find it dangerous if one is aware.
Old 05-29-2008, 01:35 AM
kinghais's Avatar
i have looked in my fuse box for to find that ASR fuse but i could not find it!!!!!
i hate that!!!!
anyone can where that fuse located at,please ????
. i have checked many times my fuse box but there is no ASR fuse in there.
Quick Reply: ASR OFF????
