Kleemann LSD Nosie
Old Oct 12, 2008 | 01:18 AM
Ausmbtech's Avatar
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
Kleemann LSD Noise
Hey all,
Finally have my C43 back on the road after installing Comand and a Kleemann LSD
Went for a quick drive and found that the LSD is noisy on tight corners (roundabouts and tight LH and RH corners). It's loud enough to hear with the radio on low and windows up, sounds like more like rubbing than grinding. No noise when straight or sweeping corners. I'm giving minimum throttle so the lsd isn't under a huge load.
I had the gears machined down as per the installation instructions (VERY pissed off because they charged full price and then told me they no longer supplied the gears), the entire installation was done by a very reputatble diff/trans shop with inhouse machining.
Has anyone else had noise with a new LSD? Did it settle down later?
I really wish Quaife did a LSD for a C43, I installed one on a W210 E55 and it really changed the car but you can't tell it was even there. Cost half the price too!
Thanks.
Old Oct 12, 2008 | 01:56 AM
SLiK 350's Avatar
slk350
Using Royal Purple in the diff will quiet it down a bit and that may help out, Just put some in my SLK and the whine was cut down by about 75-80%, but that is just a bandaid solution in your case. Anytime you use a spring based LSD kit you are putting a substantial amount of stress on the spider gears & the case housing itself.
Old Oct 12, 2008 | 08:48 AM
Ausmbtech's Avatar
Interestingly I drove slowly around a roundabout for about 5mins clockwise, 5 mins anti-clockwise and I've only heard the noise briefly once since.
I'm starting to think it's a bit like new brakes, they need time to bed-in. I guess because I installed it myself I've heard the noises that a customer wouldn't hear by the time the car is ready to be returned to them.
I've still sent an email to Kleemann to confirm (I REALLY don't want to damage the diff if there is a problem). I'm going to change the diff oil after about 100-200km anyway so I've very sure there isn't a problem.
Old Oct 12, 2008 | 07:30 PM
suicidal4life's Avatar
2001 E430
I seem to remember reading some posts on the W211 page talking about the Kleemann LSD making noises in corners. You may want to ask around over there.
Old Oct 14, 2008 | 03:04 AM
Ausmbtech's Avatar
I've now been told by Kleemann that there will be some noise and jerkyness during the break-in period, this will disappear soon.
Asking first is much cheaper than a new diff and LSD..............
