supercharge m104
-no one is going to win this arguement-
give up and leave it to whipple to keep us updated about his build
I agree that there have been some pretty amazing claims of power on some other threads, but until I try I have no real reason to claim bs. I do know that the early m104 and the m103 have some pretty robust parts in them. The rods and crank are the same as the 3.2l m104, but the pistons on the m104 are a little less beefy. Mainly the skirts are smaller. Ring lands and such are the same. I also do not believe that any inline mercedes 6 can handle more than 7500 rpm sustained. Mainly there is no reason as they stop making any more power much lower.
The 722 needs a higher stall converter, and I too would question the remainder of the drive train.
High RPM is useless as these motors are designed for torque...just look at the stock specifications.
Forget about horsepower and look at the torque you can produce...probably 10%-20% more then the horsepower and down around 4000 rpm.
It's interesting to read about the various mounting points you've converted to solid. What did you use for material? Did you just clone the mount at hand with say aluminum or something? I've seen solid motor mounts before that were what I believe to be aluminum. This is a very curious area for me because I've found nothing in the MB community where someone has address chassis/engine torque issues. I toyed around with the idea of mounting a robust engine dampener arm to the drivers side but haven't found any structure I'm comfortable bolting it to on the motor. My luck it would shear off a head bolt if I mounted it there.
The problem is that I have brand new motor mounts and it moves alot under load. Every spring I find myself grinding and whacking new clearances in the engine bay. Would switching out the passenger side motormount with a solid piece still retain some drivability or would it shake and break things? I'm thinking that if I haulted movement on the passenger side the driver's side mount would be motionless and offer no damening or flex? Does a I-6 motor mount differently where this can be done? I feel like the M113 needs be limiteded in movement but still retain some....
..stiffening up the rest of the chassis is a future need also.
I started off with the rear diff mounts with aluminum, but then I discovered delrin and uhmw. UHMW is great as it is cheap and easy to machine and as long as it is not a wear position. like a control arm bushing it is perfect. My engine mount and subframe mounts are made out of this. Any bushings for sway bars and suspension arms are made from delrin. I have to warn that the delrin bushings can be very squeaky sometimes.
This will limit the chassis flexing.
As far as the motor what I used on factory race hemis was a strap from the frame to the engine which would prevent the engine from trying to turn sideways under torque.
You could fabricate as a solid bracket or use a stainless steel aircraft cable.
Very effective method of keeping the engine straight
The eyelet is then bolted to the chassis and the other end to the engine block.
If the cable has enough length you could include a turnbuckle to pull the cable tight after it is bolted.
..would the trans mount have a large effect on keeping the motor still? Mine is the original mount.
The way to make the bushing for the c class though is really not hard. There will just be two pieces. A top piece that bolts to the engine arm. And a lower that bolts to the chassis. Then a bushing with a bolt through it that mounts the two. You could really just use a lower control arm bushing set.
I could make something like this if anyone is interested.
I should be able to do it for less than $200. Maybe less, I do not know how long it would take to make the first one.
Is this what you kinda mean using a bolt with bushings? Roughly...
[IMG]
[/IMG]The V12TT mount sounds like a great design, I'll check on fitment but have a feeling it wouldn't.
In all seriousness you're right the guy does seem like a big douche but he's probably going to be around for many years to come.Just this once out of respect for your badass C43 I'll go sig free
He's the future "Billy Mays" that was pushing oxyclean, mighty putty, weed devil thing, insurance, you name it...LOL...and lastly, each of them could buy me and sell me for less than they bought $me$ for. So jokes on me I guess!LOL
I would lean away from making the motor mounts rigid to limit the motor movement under torque as you could in time strain and stretch the motor mount bolts.
Much more labor to change/modify mounts compared to a simple bolt on strap/wire.
I first used the SS wire assembly successfully in a very high torque motor almost forty years ago !.
A strut to connect the shock towers as I previously mentioned will limit the torque applied to the front chassis rails.
What's being discussed now in this thread is very important...
You need to control the power you're making and get it to the road without breaking stuff..
Something that many forget when looking for big power gains !
So here we go again. The mount is basically a hinge point like a lower control arm bushing. Instead of hooking the lower control arm, there is a bolt on each piece of the hinge. The bushing is pressed in to the sleeve and provides dampening. The reason for the hinge is to provide the angle between the two bolting points. You cannot use one straight through bolt.
The Merc mounts are basically almost liquid filled and not what I would call a solid biscuit mount like a Chevy.
Should work...keep us posted !
