supercharge m104
Old 01-30-2009, 11:16 PM
  #126
Ortolan's Avatar
1989 Turbo Technics AMG 300CE 3.6
Originally Posted by RBYCC
I wish that someone who claims to have a Merc I6 with 500HP-1000HP and turns 10K rpm ( yes many claims are out there ) would post real world performance figures.
I've posted my meager dyno chart which shows about 225rwp...but yet I can document 0-60 in the low to mid five seconds and with traction mid to high 13 quarters in the low 100's.
I would think even a 400rwp 124 would run low 4 second 60's and low to mid 12's and 115+....
The higher claims of mega power would be in the high 10's at 125+...
So why not back up claims ??????
Hi Ed, here's some evidence a modest W124 can run 10s at 125:
http://ca.youtube.com/watch?v=S31vCdcW1QY
Incidentally, I think it's the 2nd fastest Mercedes 1/4 mile recorded:
DragTimes Mercedes <=11.0sec
I would love to see what 0-60 and 1/4 mile times the two C36 turbo owners were able to achieve, since I have a similar car and have never taken it to the track.
Old 02-05-2009, 12:23 AM
  #127
whipplem104's Avatar
1990 300ce supercharged and intercooled
Finally got it all together today. I have to button up some wiring and then drive it for a couple of weeks before I switch to the ported head on the stand. Then we will go to the dyno for a new baseline before I do the exhaust. New headers and complete exhaust on the way.
Old 02-08-2009, 09:48 PM
  #128
pics
Old 07-29-2010, 01:46 AM
  #129
Went to the track tonight and ran a 12.8 at 110 with a 2.1 60'. Still a little more in her but best I could muster tonight.
Old 07-29-2010, 07:47 AM
  #130
NitrogenBalance's Avatar
none
Nice! I ran similar times with my 43 when is was SC'd. My 60's were a little worse closer to 2.4-2.5. best ET was 13.1 and 112mph. That said if weight is similar to the W202 your hp and tq should be in the 300's I would think.
Good work.
Old 10-03-2010, 06:19 PM
  #131
NEW DYNO
Well finally got to the dyno and dialed in. 398.7whp and 383 whtq. Again the cam advance on made more power up untill around 5,000 rpm. New exhaust is working well as I am making power all the way up through the rpm. This is on e85 at around 15 degrees of timing. More timing made no more hp. Boost is still between 11.5-12.5 psi. No ice in the intercooler, so basically this is street hp. It is around 62-65 degrees today with high humidity.
File Type: pdf
Old 10-04-2010, 02:48 AM
  #132
svt ricco's Avatar
1999 C43 AMG
Good work.
"WAS" supercharged? did you take it off? i knew something happened to your car.. did you do a swap?
sorry if this was ... just wanted to know
Old 10-04-2010, 03:06 AM
  #133
Former Vendor of MBWorld
AMS Performance's Avatar
AMG
what compression ratio are you running again? is it still on stock compression?
Old 10-04-2010, 09:31 AM
  #134
My engine is completely stock except I opened up the intake port a little at the flange. I have found some literature at work that suggests that the later m104 engines were 9.2:1 but I had always thought they were all 10:1 as everyone else. I have been meaning to do a compression test and find out. There is a slight dish in the pistons. There early motors definitely had flat top pistons.
Old 12-11-2010, 03:51 AM
  #135
Achtung69!'s Avatar
w124 coupe
Hello Everybody,
I'm a new member but have read quite a few threads here. Good to see some excellent knowledge being shared. I have a M103 (12V) and want to slap a turbo on it. What is the maximum boost the stock CIS can support ?. I'm led to believe 6-7 psi is a safe bet. Thanks evryone for your input.
Old 07-30-2011, 02:23 AM
  #136
12.5 at 111.--
Ran a 12.511 and best trap was 113mph tonight. Maybe could have gotten in the 12.4- range but ran out of time and did not want to keep hotlapping.
Old 08-13-2011, 04:33 PM
  #137
12.38 at 114 mph. other car is a cts-v
Old 08-13-2011, 04:45 PM
  #138
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
CONGRATS!!! I WISH I was running 12.38
Old 08-13-2011, 08:44 PM
  #139
Thank you I am pretty pleased.
Old 11-19-2014, 04:18 PM
  #140
c280m104amg's Avatar
c280 amg spec
Thought maybe some of the c36 guys might be interested.
https://mbworld.org/forums/e-class-w...ml#post3202195
Hi are you still a making these bolt ons and would it work om my 280 cheers
Quick Reply: supercharge m104
