c36 seats
Old Jan 13, 2009 | 01:09 PM
96AMG's Avatar
96AMG 100k miles black/black
c36 seats
Can the front seats be switch around with out mods?
Old Jan 13, 2009 | 02:49 PM
96AMG's Avatar
Oh c'mon guys, I'm not the guy in the avatar
do they interchange?
Old Jan 14, 2009 | 01:54 PM
Z06EATER's Avatar
1997 C36AMG
i'm not quiet sure what your asking there buddy,
Old Jan 14, 2009 | 09:25 PM
bagelsjustbagel's Avatar
In search of W222
i dont think so they are already wired with each side and are probably coded according so...
Old Jan 14, 2009 | 10:17 PM
kinghais's Avatar
1999 W210 E300 Turbodiesel
speak english man
Old Jan 14, 2009 | 11:54 PM
In search of W222
Originally Posted by kinghais
speak english man
i think he's asking if he can switch the front dirver seat with the front passanger seat..
He wants to know if they're interchangeable
Old Jan 16, 2009 | 02:21 PM
FLi GLi's Avatar
C36, M3, Jetta GLi, 525i
Somewhat related to this topic...
Can you swap in more comfortable seats from another MB model? Anyone done this?
Old Jan 16, 2009 | 10:15 PM
onewhippedpuppy's Avatar
Plays With Cars
I'd bet money you could fit standard W202 seats into your C36. The mounting points in the chassis are identical, they wouldn't change them for the C36. Not to mention you'd probably get other W202 owners lining up to trade for your sport seats.
Old Jan 19, 2009 | 11:40 AM
96AMG's Avatar
Now we talking.
do anyone know if c36 track/rail is bolted to seat or welded?
if welded chances of succeed by quick swapping are slim, bolted give more options ..I think
le chofeur butaque to le passange e vicerverse
Old Jan 19, 2009 | 12:54 PM
Plays With Cars
Odds are very good it's bolted so the different seat styles could share a common base/track and for replacement purposes. It's easy enough to check, there's only two bolts front and two bolts rear to remove the seat.
Old Jan 19, 2009 | 03:23 PM
MarcusF's Avatar
2002 CLK430
The seat is bolted to the cage/track. The cage/track is bolted to the floor. The cage/track part numbers for the W202 are 2029104385 or 2029109185 for the left, and 2029106485 or 2029109285 for the right. Those part numbers include the motors. 2029109785 and 2029109685 are sans motors. However, this doesn't answer the question as to whether the left seat can be bolted to the right cage, and whether the right seat can be bolted to the left cage.
Old Jan 20, 2009 | 05:23 AM
MASTERBENZ's Avatar
Mercedes-Benzes: 2005 ML500, 2002 E320 4-Matic, 1993 300E, 1994 E320, AND 1999 C230 KOMPRESSOR
SOMEONE HAS A "BIG" PROBLEM (LOL)!!!!!!!
-MAR-
Old Jan 22, 2009 | 12:15 PM
96AMG's Avatar
-MAR-
not really, as stated before avatar is not me; the fact is interior is so pristine including driver seat...but 100k tell the tale so I'll like to drive in the pass. seat (not literally) to even up wear and still wonder if someone know how challenging this can be for a guy with "walmart" tools and no welding capabilities/desire..seat belt attachment will not be a problem (I think) since a new hole drilled down there will not be visible..any ideas?..beside reconstructive surgery LOL
Old Jan 22, 2009 | 02:34 PM
crjs's Avatar
C36 AMG
Regarding the wiring part their shouldn't be a problem. It's the same on both sides. The tricky part might be the belt attachment. I woludent rekomend drilling a new hole. Not when it involves saftey stuff.
