c43 sway bar
Old Jan 23, 2003 | 05:16 PM
eurorides420's Avatar
1999 c43 w/lots of mods
c43 sway bar
im wondering if any companys make sway bars for the c43? im looking to reduce some of the body roll in the corners...also im on eibach springs...would there be a big difference if i went to h&r springs?
Old Jan 23, 2003 | 10:08 PM
DougandhisC280's Avatar
2008 SLK-280
You already have stiffer sway bars than regular W202's. H&R is about the same as Eibach. The only thing I can think of is this.
http://www.modacar.com/mercedes/fram...s_mercedes.htm
Old Jan 24, 2003 | 12:11 AM
do these braces do much, some people i have talked to say it is just for looks, while others think it helps....i am looking to remove almost all understeer from the car, will this simple brace do this??
Old Jan 24, 2003 | 01:03 AM
2008 SLK-280
It should do something. The only other option is maybe an H&R Cup kit. The lower sway bar keeps the lower part of the suspension in place and this is supposed to keep the upper part in place.
Old Jan 25, 2003 | 12:39 PM
Mercedes Tuner's Avatar
99 C43 AMG & 2008 Corvette 1LT Z51 LS3
Strut Braces don't serve any purpose on a W202. First off the cars dont' have struts. They have upper and lower control arms, with a seperate spring and shock. The location of the springs are pretty low in the body and are mounted off of the frame rail and the inner fender well. For a strut brace to serve any purpose the load carrying part of the body needs to be at the top of the fenderwell where some flex could happen, as in a strut type suspension where the upper mounting point of the spring is located. The only way you could reduce some body flex would be to make the upper spring mount stiffer on the W202 by added a second brace that would come off the inner fender well and brace the upper spring mount from the top.
Here is the theory as to how strut braces work: http://www.e30m3performance.com/myth...bar_theory.htm
If you want to reduce understeer, one of the easiest ways is to eliminate the Tire Stagger. Get another set of wheels that are either 8.0 or 8.5 wide and use 245/40 17 front and rear.
Old Jan 25, 2003 | 05:04 PM
2008 SLK-280
I retract my previous statement.
Old Jan 25, 2003 | 06:11 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Not to mention, those Weichers "strut braces" just attach to the sheet metal in the engine compartment using some of the electrical accessory attaching studs, and nutserts.
Imagine all the force those are going to take!
-s-
Old Jan 25, 2003 | 06:39 PM
2008 SLK-280
Good point scorchie! After reading Mercedes Tuner's physics project and realizing where this strut brace attaches to, I would imagine this would do more harm than good.
Mercedes Tuner: Where can we get the braces you're talking about? Why aren't there any Bilstien Sport shocks for the C43? What's so different in the suspension between the Mercedes sedan and the AMG cars?
Old Jan 26, 2003 | 02:44 AM
steve s's Avatar
1996 C36 AMG, 1995 Volvo 850 Turbowagon
u should be able to use them...perhaps they were simply not entered. i thought mb used bilstein as oem suppliers...anybody wanna back me up? amg did some tuning and made the shocks on the c36 "degressive" to take the harsh impact of potholes and stuff out..
i know JamE55 has some bilsteins before he switched (forgot to which, think it was kleeman)...bilsteins r not listed on their website for e55 either
Old Jan 26, 2003 | 09:23 AM
The braces would need to be custom made. As far as I know there aren't any that are made like what I am talking about. I am only mentioning it due to how the upper spring mounts are on the W202. The mounts come up off the frame rail and hold the force of the spring from the bottom. If there was a second brace that came from above it, there is the possibility that it could make a difference. How much or if any I don't know?
There are Bilstein Sport Shocks Available! A friend of mine has them on his C55
As far as the Suspension goes, The Upper Control Arm, Lower Control Arm, Spindle, Springs, Shocks, and Sway Bars all have different Part #'s from the standard W202. The Upper Control Arms are from a W210 and have a different type of bushings. The Lower Control Arms have different bushings in them. The spindles have a different part # but I'm not sure of the exact difference. The Spring rates are Stiffer on the AMG's and the Shock Rates need to be stiffer to compensate for the Stiffer Springs. The sway bars are larger to reduce body roll.
All these parts are transferable from one model to the next.
Old Jan 26, 2003 | 10:56 AM
2008 SLK-280
So you're saying I can use a C43 Sway bar on my C280?
Old Jan 26, 2003 | 12:39 PM
Yep, all you would need is the sway bar bushings to go with them. Since the bar is larger the stock bushings won't fit over the bar.
Old Jan 26, 2003 | 04:13 PM
ya the sways will fit, if i find a bigger sway ill sell the c43 sway for CHEAP!!.....now somone find me a fat sway bar set!
Old Jan 26, 2003 | 04:21 PM
2008 SLK-280
OK, I'm on a mission. DON'T SELL YOUR SWAY BAR TO ANYONE ELSE!!! I'll try to find you a sway bar.
Old Jan 26, 2003 | 10:34 PM
Denlasoul's Avatar
1998 C43
Euro:
I know H&R is working on anti-sway bars, but they dont list applications on their site yet. It's worth a shot though.
DLS
Old Jan 26, 2003 | 11:13 PM
Eibach has a set of sway bars for the W202, I'm not sure of the size of the bars, but I know they sell for about $500 for the set.
Old Jan 27, 2003 | 12:39 AM
2008 SLK-280
I already checked that Eibach set for the C43 but there isn't one for it.
Old Jan 29, 2003 | 12:07 AM
what if i went with h&R springs or maybe a tower brace??
Old Jan 29, 2003 | 12:23 AM
2008 SLK-280
Read the the post earlier in this thread about strut bars (tower braces). They don't do anything for the car. Tighter springs will help drastically.
Old Jan 29, 2003 | 01:36 AM
scorchie's Avatar
They're 28mm/18mm, but I think the back has spherical rod ends so that its action is used more efficiently.
I believe they are under $450 from TireRack.
-s-
