fuel injectors
In my case, although my ECU has been reprogrammed by Kleemann, it carries a program for a stock injector setup and stock boost, but I run a smaller SC pulley and C32 injectors (40lb) so the Unichip gives me the ability to tune the car for optimum A/F which is around 12.5.
i run 6*42 pound injectors on my c280 so im thinking that your 30s will be on the small side,
another option would be run an additional injector or two, and run them off a seperate controller with a map sensor,'
such as a split-second additional injector controller, theres a guy round here, rbycc that does that on his turbo 300ce
