C36 Twin Turbo
Anyone else have this done? I would need a general parts list, and how to go about getting them. any experience would be nice, and also what are my risks of ruining my engine or tranny at this point... car has 148k
THANKS
1. need to change engine harnes PERIOD!
2. Only wheels that make sense are the 18's E55's
3. Throtle is tempermental and bogs when it wants to. Computer issue.
4. Hand crafted rocket from hell on good days!
5. I want it to go faster and get ultra parts for this thing!!!
This is a well built vehical, that was before it's time, and of course the c63 is the power stroked, steroided, gran daddy of them all..But they are still the same!!! the smell the flavor, it's AMG...The OG's of the industry!
My 95 is extra rare, especially with those $300 front rotors, that i got cheap in Marin, only because Sam said f**kit, these have been here forever!!! 1/2 price. Made my day! Only on the 95 1st year. You don't have that worry on the 97. But I'm hoping the Turbo kits are the same???
Do what whippleman did. Throw a kenne bell on the side of it. It would probably feel like a big V8 if you did.
The reason I said only 4lbs before is that the 3.6 has higher compression and at 4lbs of boost they make quite a bit of horsepower. You can go higher it just starts costing quite a bit of money.
thx
As far as where to get the stuff to build a kit, it has to be made. I only know of a couple of ways to do this. One is to go with myself. I can make almost anything. The other is to go with solo36. He is building the turbo c36 an I think is selling the old twin kit from his car.
I have been interested in building a turbo kit for the m104 for a long time but have been focused on the supercharger for myself. If anyone is interested for
real please pm me.
I know these are not "run of the mill" bmws hence why I think these motors can take MUCH more than 4psi in stock form, in fact I think 6-7psi is way to conservative for a cast iron block C36 motor with extremely strong internals. With that said, all it takes is for something to see just how far these C36 motors can go.
According to the C36TT article in street power magazine (april 97), they got 561HP on stock 10.5:1 compression ratio with built heads, p&P and a few other things, but essentially stock-block & compression ratio was used. And they were running 8psi (which is right in line with what a 10.5:1 can run, just as the E36 M3s do). So obviously I'm right in this regard.
if anyones gonna truely turbo the C36 could they please getrag swap it first.
or just go my route and buy a getrag cossie and do an efi conversion and turbo build(and gonna be able to actually have fun with the power because of an LSD
From my experience the weakest link is the cylinder head and how it's attached to the block - this goes for any engine, assuming the internals are good.
The gasket / studs will normally let go long before the block does (cast or alloy) - again assuming the bottom end is good.
In fact it's actually better to have the head and block made of the same material - ie aluminum to avoid dissimilar rates of expansion and related problems.
Plus we'd normally O ring the cylinder for extra sealing when running high levels of boost.
Got to love the extra push as the turbos spool - in my 911 the faster it goes in 3rd the harder it accelerates as the turbos do their thing !
I'm a believer of additional injectors controlled by a stand alone controller.
A manual boost controller is important to synchronize the turbo waste gate opening.
The I6's if set up properly become real torque monsters.
My M103-12V with twin Garrett T2's was at 302 torque at the rear wheels on it's last pull on a mustang load dyno at .48bar.
