C43 Recovery from Storage
My thoughts are a Service B plus all fluids (brakes, coolant, ATF). Grateful for any other suggestions you might have plus things to look out for based on your collective experience. Thanks in advance,
Mike
Good gasoline is volatile, meaning it vaporizes quickly (one reason for the charcoal canister). This allows it to mix well with the intake air. Unfortunately, it’s volatility means it evaporates quickly too, but not all at once. It separates then evaporates. What’s left doesn’t burn very well in a high compression engine. I’d drain it and use it in a lawnmower.
Hey Marcus, how do fuel stabilizers stack up? and how long is "too long" for a tank of gas to sit?
I store with a full tank and additive each winter and burn that tank before I do anything spirited.
I agree you need to drain that gas
I found the gas tank access pie caps (2) under the rear seat , got the special Spanner wrench & opened up the tank fuel and removed the passenger side fuel pump & canister. What a Pain. . Ther was only 2 gallons left on the passenger side & the Drivers side had a pint. . So for grins I stuck a hose down the filler ? gas cap neck.only to see if I could siphon out the remaining 2 gallons. The hose didn';t come close to the bottom of the tank. BTW the gas was pretty bad. UCK! and the pumps were lock up with varnish. Thats another story for another Thread.
Ok , whats this really about. From My experience from winter storage of marine engines. Fuel stabilizers are good for about 6 months on an open vent system & 8 months on a closed system. Starting the car once a month & bringing it up to operating temp Is a very good thing. But after 2 years of storage, siphon as much old gas out as you can . Add fresh gas , Change the gas filter ( THATS A MUST), Change the engine oil & Filter, get the brake system flushed , The brake fluid is HYDROscopic . , Just absorbes moisture . This is not good for the ABS. Your tires are probably flat spoted from sitting in one spot on Cement., Add some more air ,5lbs more that spec.. Also look at your engine belt. It may be weather checked. Hope this helps _PTEngineering
You've got it right. That’s part of the vapor recovery system and a basic part of OBDII. The gas vapors are routed to the storage canister. Occasionally while running in closed loop mode, the engine consumes the canister's contents (gas vapors) in a purge cycle. It does this with intake vacuum. Every now and then, the purge cycle is suspended while the vapor recovery system is under vacuum. The ECU then waits to see if the vacuum holds. If that leakdown test fails, the check engine light comes on. That’s why the gas cap has to be on and tight – it’ll cause te vacuum test to fail
Mike
which is non-refundable. Anything over 2 litres is asking for a big bill in this part of the world
