started tear down for paint
The mechanics asked me to bring my old pump in, he's already disassembled the $40 pump, and will make one good pump with the good bits of both pumps. Just waiting now for my ever suffering wife to grab the pump from the garage, pick me up, and then we'll head to the shop.
Fingers crossed everything back to normal tomorrow.
I'm sure the dealer would have told me to just buy a new pump from them. Only the independent shops would suggest ripping apart the pumps themselves. I'm fortunate in that this shop is staffed by ex-dealer guys, who jumped ship when a large conglomerate purchased the dealership. I think they own over a dozen dealerships in town, all of various marques and such.
When I win the lottery, I will build a huge garage and equip it with an alignment rack, wheel mounting and balancing tools and maybe a dyno too.
It'll do for now, as I don't have any car available at the moment to have time to muck around with the AMG for an extended period of time. Maybe later when the S2000 is back for the season. At that point I think I will get some custom lines done up, or may just figure something out with off the shelf components and adaptors, then get the correct piston orientation.
I also installed the new, 5mm longer caliper mounting bolts too. Still nice and shiny! For now.
Also a pic of the storage bin that eliminates the ashtray. Much more space! I think at some point I will also eliminate the smaller storage bin and replace it with a custom triple gauge holder.
what did you do with your blue colored adaptors you had mounted to your calipers/SS lines?
are these adaptors necessary to use for brakelines threaded nozzle to reach the backside of the c32 caliper?
you made me worried here if my Goodridge SS lines without any adaptors will be long enuff to bolt the backside of caliper?
where can I buy these adaptors if they are necessary?
local hardware store?
Now with the calipers reversed, ie. left caliper on right side, the a) bleed screw is pointed upwards and b) the brakeline orifice is pointed upwards. Because of the latter, there is no need for the adaptor.
I haven't been able to find that adaptor anywhere. When I get a chance to remount the calipers with the proper piston orientation, I will investigate and acquire different adaptors or fabricate up a custom brakeline. However, as it stands right now, the Stoptech stainless lines are long enough.
At the rear, the C43/32/55 use the same disc and I believe caliper as well.
I wanted the 4 piston calipers for better pedal feel. And also because I have multi piston caliper envy.
It's a bonus that the parts are cheaper too - not that I intend to burn through discs every year though.
Yesterday I decided to begin the grille repaint project. It began with a can of paint stripper and some time with my pressure washer. This is the end result.
Next I'm going to blast it with black Plasti-Dip.
And after that...I noticed a bit of rust already on my driver's door! WTF. That's what I get for a cheap paint job I guess. It's started bubbling a bit on the lower most edge, just above the weather stripping. I think I'm going to remove the inner door trim, clean up as much of it as I can, hit the exposed rust with rust converter, and then do a thin line of Plasti-Dip on the outside of the door. Naturally, I'll have to do the other doors to match, but that's fine. On a black car I don't think it'll be too noticeable.
Next weekend I'm going to install the supercharger kit on my S2000. Then I'm picking up some seals for the 55 motor next month when I head to the US. Plan is to remove the 43 engine on a weekend in August, take a week to tidy up the engine bay, and then put it all back together a weekend after that. Should be fun!
already rust on black beauty?
that sux man!
you need to go back to the bodyshop and complain about their lousy paintjob.
whip their lazy booties!
slap them around and tell them you're going to badmouth their reputation.
With the Sharks battling it out with Canucks for WCF, I cheer for the Canucks.
All because hockey is Canada's game.
I'll be in Edmonton next week for my yearly visit to my Mom.
I do hope to get some time to meet and greet with you + to check out your S2k and your AMG.
