started tear down for paint
Old Jan 21, 2011 | 03:21 PM
  #151
Saaboteur's Avatar
eclectic assortment of cars
Nah, I bought them from bimmerspecialist.com. No HWA stamp, just the Mercedes start and part number.
No engine builder plaque either. I was under the impression that only started in '03 or '04? The engine I have is from an '02, so it should have that slightly higher compression ratio I believe.
I have just a stock crank pulley, just going to put that on. Currently assessing what other new parts to throw onto the motor. With the relatively low miles, it probably doesn't need the oil cooler seals or the timing cover gasket, but I will probably do them anyway. They are relatively cheap (if you buy them from the right place, ie. NOT the dealer!), and as you said, they are much easier to replace with the engine out of the car. Probably get a new idler pulley at the minimum, I'm going to double check the other pulleys first. The idler seems a bit rough to spin.
Old Jan 21, 2011 | 04:03 PM
  #152
KJI3jflarryfe93's Avatar
these c32 rotors are not as sexy as the c43 rotors with the HWA stamp!
c32 rotors feels like they are cheaper in quality not only the price being cheaper!
Yeah, do some of the replacements on certain parts when your engine is out of the car, not inside in the bay.
Old Jan 22, 2011 | 05:40 PM
  #153
DRBC43AMG's Avatar
Don't like them. I prefer the real two piece rotor with the hat even if they cost double or triple the cost of the C32's
Old Jan 22, 2011 | 05:43 PM
  #154
DRBC43AMG's Avatar
Hi Saab,
On the first engine picture, what is the think bolted on the top front of the engine (round holding bracket and electric wires coming out on the left side?? It don't exist on the 43 motor.... only the round alu bracket
Old Jan 22, 2011 | 06:07 PM
  #155
Originally Posted by DRBC43AMG
Hi Saab,
vee don't have that part on our european c43's.
upper round bracket is empty on my car.
part got something to do with US import regulations.
Old Jan 22, 2011 | 11:43 PM
  #156
MarcusF's Avatar
2002 CLK430
Great project. When you're swapping motors, could you compare the exhaust ports between the 43 and the 55? Doesn't have to be exact, a ruler will do.
thanks
Old Jan 23, 2011 | 12:37 AM
  #157
Saaboteur's Avatar
The 'thingy' at the top of the motor, near the front of the car in the V-bank, I believe it's the secondary air pump or some sort of emissions crap. Well, at least now I have two...
Marcus, I will measure the ports when i start taking things apart. I don't plan to do any work on the car until spring/summer at least, as I will need my S2000 on the road before I tear into the C43. But I may tear into the 55 motor before then. I did note that the exhaust manifold gaskets are the same part number (on AutohausAZ at least) for the C43 and E55.
Aiming to get the motor onto a stand tomorrow. I bought (for half price!) a different rolling type of engine stand today, meant for small block Chevs I think. Hopefully I can adapt it sufficiently for the 55.
Old Jan 23, 2011 | 01:44 PM
  #158
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
Enjoy that S2000 for the time being because something tells me you wont want to drive anything but your C55 after the spring/summer
Old Jan 23, 2011 | 03:59 PM
  #159
DRBC43AMG's Avatar
So if this is a secondary air pump it could be for US (N. American) cars only Thanks for the info
Old Jan 23, 2011 | 11:39 PM
  #160
Saaboteur's Avatar
Managed to mount the engine onto my stand today, and after that spent a bit of time removing the wiring harness and a few other melted pieces of plastic. Unfortunately, also managed to stupidly break off one of the vacuum line fittings off the valve cover, so I'll either have to have it repaired or more likely, reuse the valve cover off the 4.3.
Marcus - I measured the exhaust ports, as I also took the exhaust manifold off, and it shows a 36mm diameter. Doesn't Nitrogen Balance have his C43 heads off? Perhaps he can be asked to measure the ports on his heads, unless they've been modified.
I was under the impression that the coils were different due to ME2.8 vs. ME2.0 (or whatever) between the E55 and the C43, and thus different connector plugs. While I didn't physically check the connectors, the Mercedes part numbers are the same on the coil packs, but the Bosch part number is different.
The Mercedes number is A 000 158 78 03 on both the E55 and C43 coils. The Bosch number on the E55 coil is 0 221 503 035.
The Bosch number on the C43 coil is 0 221 503 012.
And that's all I managed to do today, other than installing the SLK pedal covers.
Old Jan 24, 2011 | 03:45 AM
  #161
now you need a good interior clean up to remove all that white stuff on your panel and drivers seat!
Can you snap a sclose up shot for me of the timing case oil cover port, it should be near the belt tensioner.
You know the cover that fits to one of those 2 different squared timing cover gaskets sold on autohausaz.
I wanna check if I have that cover on my engine.
Thanks bud
Old Jan 24, 2011 | 11:35 AM
  #162
Saaboteur's Avatar
That's winter roads for ya!
I've actually found a spray product in the shops here - 'salt remover' - just for this purpose.
Here's a pic of the small test port on the timing cover.
Old Jan 24, 2011 | 12:43 PM
  #163
gracias Mr. Amigo
Yeah I believe I have that testport.
I found out I have the crappy rectangular squared gasket with no centre rubber!
# 112 184 0161, sheize verdamt!
The revised gasket that came on later m113 engines, can it be retrofitted to an early manufactured engine instead of the old style gasket above?
What do mean about this, salt remover detergent on spray cans?
Best thing is not to drive the old rustbucket during winter!
Old Jan 24, 2011 | 12:50 PM
  #164
Saaboteur's Avatar
Unfortunately, I don't know if you can retrofit the different gasket. I didn't look closely, but it's either a change on the timing cover casting, or a change on the test port casting. Either way, I guess you could swap the pieces, but swapping the test port casting would be much easier than the timing cover.
Here is a link to the salt eraser product:
http://www.canadiantire.ca/AST/brows....jsp?locale=en
If the link doesn't work, just head to the Canadian Tire website and try punching in item number 39-0421-8. Probably they have something similar in Sweden; California, not so much....
Old Jan 24, 2011 | 01:25 PM
  #165
yeah, I could see the link, your seat and carpet on drivers side was covered with salt stains?
daem you're a slopy Joe.
About the test port metal cover, autohaus sells only 1 version of this cover, both version gaskets must fit the metal cover.
The rectangular squared gasket without centre piece rubber can't seal the oil very much?
That's why the reliesed version #2
No MB technician on this forum can chime in on this question?
Old Jan 27, 2011 | 06:41 PM
  #166
Saaboteur's Avatar
Last piece of the brake puzzle arrived via the FedEx truck just now.
Gonna try and find some time on the weekend to test fit with the 3mm spacers and both 17" and 18" Monoblocks.
Old Jan 28, 2011 | 04:51 AM
  #167
n
no fresh paint on these used calipers?
needs cleaning n peeling then a fresh paintjob.
let me know how your install went.
also check if your stock or SS braided brakelines are long enuff to fit and mount your new calipers
Old Jan 28, 2011 | 02:37 PM
  #168
Saaboteur's Avatar
I'll clean them up, but I don't think I'll paint them again. We'll see though, I might change my mind. If I paint them, that means I need to get AMG stickers too! I'm told the C43 lines should be fine. I picked up a set of Stoptech stainless lines, so it should be all good I'm hoping. I'm sure I'll have to trim the backing plate though, but that's not a big deal. I removed them entirely on my other cars when I put big brakes on them.
Old Jan 28, 2011 | 06:33 PM
  #169
what's a backing plate?
is it the rear side of the caliper bracket, you need to trim?
stock c43 brakelines are long and good enuff to use on the new calipers?
well I had my Goodridge SS lines installed last year and they were longer than stock brake lines.
The wireloom connected to the cluster for the brakepad wear sensors warning light is it adaptable to the new c32 break pad wear sensors?
Only thing to do is to buy c32 brake pad wear sensors and connect them to the c43 wireloom?
No problems there, huh?
Old Jan 28, 2011 | 06:47 PM
  #170
Saaboteur's Avatar
The backing plate is another name for the dust shield.
I have no personal experience (yet) about whether the lines will be long enough or the wear sensors will be fine - but - the Swedish dude with the C43T (S500R?) who did the swap told me it would be all good, and I just needed the 3mm spacer to clear everything.
Old Jan 28, 2011 | 07:01 PM
  #171
yeah my stupeed, backing plate = dust shield.
you say it needs some cutting or bending?
about the pad sensors, they are different between both cars, so that means that maybe the wireloom CONNECTED TO THE CLUSTER and the other end connections are different on c32 than
c43?
here is a pic of the c43 sensor
click the pic.
http://www.partsgeek.com/catalog/199...ad_sensor.html
here is the c32 sensor
http://www.partsgeek.com/catalog/200...ad_sensor.html
as you can see both sensors differ IIRC?
Old Jan 30, 2011 | 02:26 PM
  #172
Saaboteur's Avatar
Picked up a genuine Mercedes car cover for when the car is going to sit for long periods of time, ie. when I'm driving the S2000 in the summer.
It's minus friggin' cold right now, so plans for test fitting the C32 brake components are likely going to be put on hold for a little while. Bleah. I hate winter.
I dunno if it will be possible to use the C32 pad sensor harness. The guy I bought the calipers from said they were installed on a '90s E something, so I guess it's a W124. When they removed the calipers, they just cut the lines and the harness. So while I have the sensor end of the harness, it's been hacked of. I'll have to see what I can do...just need some time to mock things up.
Old Jan 30, 2011 | 03:25 PM
  #173
you going to buy a new wire harness suitable for c32 wear sensors, or you going to test and fit the c32 wear sensors to your existing c43 wire harness with somekind of home made thingie?
Old Jan 30, 2011 | 06:16 PM
  #174
Saaboteur's Avatar
I think I will try the C32 sensors in the existing harness, and see what's what.
Old Jan 31, 2011 | 04:22 AM
  #175
DRBC43AMG's Avatar
I don't see why it shouldn't work if you can get it connected correctly
You have already rated this thread Rating: Thread Rating: 9 votes, 5.00 average.
