Windshield Washer Nozzle/Tubing Gurus, Help!
Old May 31, 2010 | 09:51 AM
appatula's Avatar
95' AMG SeeThreeSix
Just wondering if anyone knows whether a single pump is responsible for supplying and spraying all four nozzles. From what I can see there are tubes obviously going to the headlight nozzles and the hood nozzles. However, when I actuate the stalk to get some cleaning action going on the fluid squirts about 5 feet out of the front of the car (front drivers side headlight arm has no nozzle apparently). I'm wondering if I just plug this part of the system up will it redeem my hood nozzles so I can clean my windshield again?
Old May 31, 2010 | 10:10 AM
OzC36's Avatar
Silver 1996 C36
Perhaps just replace the headlight spray nozzle...it can't be too expensive?
Old May 31, 2010 | 10:14 AM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
Yeah, I wouldn't "plug" anything up. The hoses are meant to accept a certain amount of pressure and when you create a constriction it will increase the pressure (like putting your thumb over a garden hose) you might blow a
hose connection off or split a hose. I suggest the correct repair and get a new nozzle to avoid damaging something more expensive and time consuming to fix, I would be surprised if the nozzle was more than $25
Old May 31, 2010 | 12:10 PM
appatula's Avatar
95' AMG SeeThreeSix
True! I'll have to pick up the nozzle. I fixed the problem however. Well.....fixed might not be the right word but I figured out why the hood nozzles were not spraying. Apparently there are two seperate pumps for the headlights and windshield, I swapped the 2 pin connectors (power connector going to the headlight pump to the windshield pump) and now I have spray on the windshield. Thinking the stalk or possibly a relay may be the culprit, worst case scenario I could splice the non working connector in parallel with the one currently working is push comes to shove.
Old May 31, 2010 | 12:19 PM
Start with fuses, then switches, then relays, then wiring. I would be very careful splicing 2 into 1 as that may cause extra loads on equipment which could lead to failure. I would imagine the counter measure you are using now (switching the pumps) will work but I would be wary as the pumps might not be the same and you could be overloading it which could lead to failure. I would try not to use the counter measure unless ABSOLUTELY NEEDED and I would repair your nozzle ASAP.
Old May 31, 2010 | 12:35 PM
RANDY_P's Avatar
1996 C36 AMG, 1970 LeMans Sport, a truck
I'd be blasting pedestrians with that setup
Old May 31, 2010 | 09:30 PM
johnhef's Avatar
83 500SEC, 87 300D, 02 C32(x2), 02 C320T (x2), 03 C320T4, 03 C320T, 03 E55, 05 E320CDI, 06 E320CDI
Ben, your headlamp pump should only get power when the headlights are on... are you sure it was hooked up correctly to begin with? turn the headlights on and hit it again and see if you have power on both.
Old Jun 1, 2010 | 11:27 AM
appatula's Avatar
95' AMG SeeThreeSix
That is basically the info I was looking for! John to the rescue . I'll check that out, it is VERY possible I just corrected an old problem.
Fuses are always my first method of attack, no dice there. The only related switches are the stalk switch and headlight switch and I'm not playing with the s.column this summer! The relays are all rated for about 30A, there is no way that these little buggers pull more than 3-4 amps at the VERY most. No issues swapping connectors either as they are indeed the same part number. Needing a new nozzle isn't the end of the world for me, something I'll have to put on my list though.
Randy, funny you'd mention that! I kinda liked having the ability to shoot stuff....maybe a "Kill Switch" is in store down the road but the fluid goes fast, believe me!
