Injector service done....worth it!!
Old Jun 26, 2010 | 05:54 PM
99CEEFOURTHREE's Avatar
99 c43,90 mustang gt supercharged convertible,07 acura tl type s, Hummer H3t pickup
My C43 went in for a Mobil 1 service and a/c recharge today.While at my foriegn car mechanics garage he suggested changing the air filters and performe an injector/fuel system servicing.This guy is good and well respected so I said do it.Well im very happy as the car is more responsive and that off the line hesitation is reduced to nil.I guess my injectors were somewhat clogged as the car is much smoother and responsive.This serviced costs $139.00.Good money spent.My car is religiously maintained and has 136k on the clock.
Old Jun 26, 2010 | 06:20 PM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
This might be my next investment as I do have a hesitation off the line. Thanks for the input
Old Jun 26, 2010 | 06:49 PM
If your car has high mileage like mine, any cleaning/servicing of any type is beneficial....LOL!!!!!!
Old Jun 26, 2010 | 10:44 PM
TVT_DESIGN's Avatar
Former Vendor of MBWorld
Chrysler Crossfire
Greatly beneficial, especially for the price. Injector cleaning is a great mod to get back lost HP!
Old Jun 27, 2010 | 03:28 AM
BenzMaster19's Avatar
C36 AMG
Your injectors should not be clogging up at all if your using high grade premium fuel with cleaning additives.
Old Jun 27, 2010 | 05:05 AM
All I run is chevron supreme.... but who knows what the person before me ran.
Old Jun 27, 2010 | 05:16 AM
C43AMG's Avatar
Veteran: Army
98 Black C43 , 12’ ML 350 Blutec
Or you can upgrade to the W210 E55 injectors!
Old Jun 27, 2010 | 05:22 AM
DRBC43AMG's Avatar
Ahhh, interesting and what gains does this upgrade give?
Old Jun 27, 2010 | 05:37 AM
C43AMG's Avatar
Veteran: Army
Here's the entire thread on whay was done to my car : https://mbworld.org/forums/c36-amg-c...oject-c43.html
Old Jun 27, 2010 | 01:04 PM
AMS Performance's Avatar
AMG
It really does make a huge difference and is highly recommended on any car with over 50k miles on it. Helps restore the car to full power and is many times stronger than normal seafoam in the gas tank (although seafoam is the best of all the over the counter injector cleaners, this is just many times stronger).
ALL AMG owners should do it on their AMGs
Old Jun 27, 2010 | 01:09 PM
I swear by redline injector cleaner..... good stuff. I am going to get an injector cleaning done as it can't hurt all it can do is help.
Old Jul 21, 2010 | 09:15 PM
johnhef's Avatar
83 500SEC, 87 300D, 02 C32(x2), 02 C320T (x2), 03 C320T4, 03 C320T, 03 E55, 05 E320CDI, 06 E320CDI
I'll do a BG fuel rail service to my 36 on friday and see how much it helps.
Old Jul 22, 2010 | 12:56 AM
KJWHIT's Avatar
1998 C43 AMG
whered u get that done in nj interested now
Old Jul 22, 2010 | 01:01 AM
AMG
Yes, BG is one of the best products on the market for direct fuel rail service. highly recommended
Old Jul 23, 2010 | 10:08 PM
KJWIT Had it done at a private shop where i live in Clifton.This guy is great with foriegn cars and he is top notch.Trust my vehicles to knowone else
Old Jul 24, 2010 | 03:38 AM
KJWHIT's Avatar
1998 C43 AMG
o ok im only about and hour and 20 min. from there im from right outside trenton lol dont wana say trenton cuz its not the greatest of areas ....bout how long did it take for him to do? if you could pm the address and name of place please thanks
Old Jul 24, 2010 | 02:27 PM
Exactly....stronger than WHAT YOU CAN BUY AT THE AUTOPARTS STORE....Hey I feel a difference and my car is getting 2-3 mpg better on the highway.What i noticed most is no more hesitation off the line when acceleratingIf you have a highmileage car THIS WILL HELP.My car is running perfect.
Old Sep 13, 2013 | 06:31 PM
tbone006's Avatar
E320
I have co-worker who is a muscle car guy. Very knowledgable mechanic does drag/race car projects. He used seafoam in his oil/gas/injectors...he said once he did the injectors he was able to get his car sideways , as to before he could not. He said he found his vacum intake and added seafoam in small amounts and let it sit for awhile 1hr? and after that a huge significant difference.
I am going to try on SAT ....i'll post after i complete
Old Sep 14, 2013 | 08:49 AM
Sulaco's Avatar
1999 C43 AMG, 2005 E55 Wagon
I've read several threads where feeding seafoam into your vacuum line while your engine idles is a fantastic way to clean injectors, valves, but it also really fouls your spark plugs. I imagine you should be prepared to do a plug job after you do the proper seafoam treatment
Old Sep 14, 2013 | 09:47 AM
KJI3jflarryfe93's Avatar
what is seafoam, is it a wichbrew?
is that something you put in your gastank as an injector cleaner?
who sells these liquid clensing products?
Old Sep 14, 2013 | 03:24 PM
Sulaco's Avatar
it's a very old product, like WD40.
http://seafoamsales.com/
People pour it in their gas tanks to clean injectors. People pour it in their engine and drive a few miles before they change their oil (to break up sludge and other things). People do the same in their transmission.
The most effective way, or so I've read, is to feed it into your intake via the vacuum line on the brake booster. Engine running, remove vacuum line from brake booster, have a small bowl or cup full of seafoam. Let vacuum line slowly take in the seafoam while the engine idles. It could choke your engine out if idle drops too low, so some people have someone sit in the car and rev it up to 2,000 RPM's. It enters combustion chamber and does thorough cleaning of carbon buildup on injectors, valves, cylinder heads, pistons, etc. But, I've also read that this treatment can ruin your spark plugs and perhaps O2 sensors. I've always wanted to try it, but do not currently have what I need to replace spark plugs or O2 sensors.
Old Sep 14, 2013 | 05:24 PM
I would steer clear of anything like Seafoam.There are many stories out there of seizes engines, blown motors etc with the use of seafoam,,,I don't care if it's been around for 100 years.If you run super in your AMG and mobil one the buildup is minimal if any.My car was a little sluggish...my indy suggested the F.I.SERVICE.He was so right.Also laughed when I mentioned seafoam.
Old Sep 15, 2013 | 05:54 AM
yeah wichbrewery can be risky?!
it's like putting STP Injection cleaner in the gastank, it will clean the injectors.
this is a known product and will not harm your car.
long time ago there was something named Slick50, a teflon based miracle brew.
engine would have run smoother and better with Slick50, it was a very expensive product to buy back in the 90's where I live.
adverts said there were all kinds of benefits using Slicky50.
I never tried it though so I can't say if adverts were right or BS
