Traction Control acting odd
Old Jul 13, 2010 | 11:10 PM
Jasssc's Avatar
1996 Mercedes C36 AMG
alright so i bought some new tires for my C36 and put on monoblocks rather than clk style amg wheels
my problem is: the traction control comes on and cuts my power at the strangest times and it is really annoying. it comes on in wide turns at a normal speed ( not like im taking it wildly) , when the road becomes a little rough, and the oddest is when i am on the onramp leading to the freeway and it comes on between 55-65 mph ( sometimes it wont let me go any faster to get past the 55-65 speed so i will have to take my foot off the gas turn traction off then on again then i have to get past 65 mph)
the tire pressure is perfect and the tires are fitted correctly
so is there anything i can do?
Old Jul 14, 2010 | 01:22 AM
PJmak's Avatar
Tires are either really bad or you need alignment and check your suspension. I had it happen to me a few times.
Maybe u just ran over some oil or something too
Old Jul 14, 2010 | 12:41 PM
appatula's Avatar
95' AMG SeeThreeSix
Could also be the electronic throttle actuator acting funky. The wiring on these also seemed to be subject to the common engine wiring harness degration.
Old Jul 14, 2010 | 03:49 PM
Jasssc's Avatar
thanks guys!
ill get an alignment and check the wiring
im getting new suspension soon anyway. need to drop it!
Old Jul 15, 2010 | 12:45 AM
MarcusF's Avatar
2002 CLK430
Are the tires staggered? C36s have ASR, right?
Old Jul 15, 2010 | 09:09 AM
appatula's Avatar
95' AMG SeeThreeSix
My 1995 C36 has the "Disco Light"
Old Jul 15, 2010 | 12:49 PM
Jasssc's Avatar
the tires are not staggered and yes there is ASR
haha whats the "disco light"?
Old Jul 15, 2010 | 03:11 PM
appatula's Avatar
95' AMG SeeThreeSix
The ASR light in the middle of the speedo. When you have wheel slip it blinks and cuts power, mine blinks like a disco light
Old Jul 15, 2010 | 04:05 PM
jayrasheed's Avatar
1995 C 36 AMG; 1992 W124 300E (M103 Ex Mosselman TT KIT) was 320hp @10psi now stock :(
in the c36 the ASR is setup for front tires having slightly larger diameter than the rear, so if ur not running the propper sizes / ratio it might be the cause.
Old Jul 15, 2010 | 04:12 PM
DRBC43AMG's Avatar
Guess you have soap on your tyres
Old Jul 15, 2010 | 04:40 PM
Jasssc's Avatar
its getting worse
today it came on blinking when i was on the onramp at about 55 and i couldnt get passed it. it wont let me turn on the cruise control and wouldnt let me get up to speed
i really dont know whats going on
Old Jul 15, 2010 | 05:06 PM
DRBC43AMG's Avatar
have you tried disconnecting the battery for a couple of hours? Could refresh ECU
Old Jul 15, 2010 | 07:54 PM
Jasssc's Avatar
nopee havent tried that one
Old Jul 16, 2010 | 01:19 AM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
It sounds like you need to check the harness to you ETA.....
Old Jul 16, 2010 | 05:31 AM
DRBC43AMG's Avatar
+1 and could be spaghetti time https://mbworld.org/forums/c36-amg-c...sengaging.html
Old Jul 16, 2010 | 07:04 PM
jayrasheed's Avatar
i still say tire sizes are way offf or u have a speed sen giving wrong reading
Old Jul 16, 2010 | 08:22 PM
PJmak's Avatar
Ill still bet anything your alignment is messed up
Just recently my car started doing this on freeway on ramps. Normally I like to rail those but lately I cant coz if I push it even slightly my front starts understeering pretty bad and the light starts blinking on me crazy
Did you do alignment after installing new tires?
Old Jul 17, 2010 | 05:08 PM
Jasssc's Avatar
yes i got an alignment but i bet its about time for another
i will definitely go and get one soon!
Old Jul 20, 2010 | 04:22 PM
Jasssc's Avatar
okay so i reset my ecu maybe thinking that had something to do with it and it stopped! but not for long haha it does still come on but not as often and not as long (at least thats what it seems)
i will go ahead and get an alignment and see if that does it
thanks for the help!
Old Jul 20, 2010 | 04:28 PM
DRBC43AMG's Avatar
Keep us posted on the results
Old Jul 21, 2010 | 08:31 PM
johnhef's Avatar
83 500SEC, 87 300D, 02 C32(x2), 02 C320T (x2), 03 C320T4, 03 C320T, 03 E55, 05 E320CDI, 06 E320CDI
what are the wheel sizes and tire sizes front and rear??
Old Jul 21, 2010 | 08:35 PM
Jasssc's Avatar
17" Monos on front and rear
tires are:
front: 225/45ZR17
rear: 245/40ZR17
Falken FK452
Old Jul 21, 2010 | 10:09 PM
johnhef's Avatar
Maybe the falkens are waaay off, not all manufactures tires are same as the rest of the industry. I dunno, could be some electrical gremlin but if this happened right after putting the tires on id be inclined to suspect them. anyone else close by you can swap wheels with to test it out?
Old Jul 22, 2010 | 12:14 AM
Jasssc's Avatar
yeahh im definitely suspect of the wheels and tires
hope its just an alignment
Old Jul 23, 2010 | 01:58 AM
Jovsky's Avatar
2000 C230 Kompressor Sport
Before you get the alignment and start spending, why not put back the set of old wheels you were using before the ASR light started blinking, and test it on the ramp and see if the ASR blinks? If not, it's the new set of wheels (Monos) that is the problem.
