H&R problem
the problem is on the website:
it says C36...94-95
C43...96-00
i have a 96 C36 so can someone go on http://hrsprings.com/scripts/appguid...ind3&MakeID=25
and look at what im talking about and help me on choosing which i need because there is a difference in sizes
also should i get the sway bar as well?
it says C36...94-95
C43...96-00
sway bar is only 1mm thicker at least on my car is was, 27 vs 28mm, not worth it imho.
its just a footnote saying "Mercedes-Benz cars ride height may vary due to vehicle options and Mercedes-Benz factory ride height adjustment shims. This original-MB-Part is a rubber shim perch, which is located on the top of the spring. These shims vary in thickness from 8 to 23mm."
