C43 '55' swap thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old 11-12-2014, 10:52 PM
  #276
cm60k's Avatar
00 C200 & 00 C55 & 06 SLK55
Originally Posted by PJmak
Oh yea forgot to add idler pulley, the rest are fine. Timing chain im not doing. Is it recommended?
All parts are oem brands
Replace the chain rails are important during age, prefer to go with metal idler pulley instead of scary plastic...
ZAYED,,
Old 11-12-2014, 11:24 PM
  #277
e36uc's Avatar
06 E55
anyone interested in a engine PM Me
02 clk55 engine 95k miles
Old 11-12-2014, 11:57 PM
  #278
PJmak's Avatar
ZAYED,,
Whats the cost for parts when replacing the timing chain rails?
Old 11-13-2014, 04:36 AM
  #279
cm60k's Avatar
Can't tell that clearly, it's for sure depend of locally shops labor...
ZAYED,,
Old 11-14-2014, 03:28 PM
  #280
PJmak's Avatar
So how much power does this motor put out with the stock c43 ecu? Not tuned...
Old 11-14-2014, 03:51 PM
  #281
cm60k's Avatar
if it stock, should be between 345hp>>362hp, depend of Engine/gearbox health,,
it can reach 380hp>>400hp if it modified, without turbo or supercharger...
ZAYED,,
Old 11-15-2014, 03:24 PM
  #282
PJmak's Avatar
With a ML motor, should i reflash the ecu or just use it as it is. Plug it all together and turn the key over basically...
Old 11-15-2014, 03:32 PM
  #283
cm60k's Avatar
Is this Engine from early or late ML55 model...?
ZAYED,,
Old 11-15-2014, 04:28 PM
  #284
PJmak's Avatar
2002 model
Old 11-15-2014, 04:38 PM
  #285
cm60k's Avatar
You have to put C43 Engine harness/TB into ML Engine, and using C43 ECU, it will fire-up perfectly...
ZAYED,,
Old 11-15-2014, 04:43 PM
  #286
PJmak's Avatar
Great thanks
Old 11-15-2014, 04:45 PM
  #287
cm60k's Avatar
ZAYED,,
Old 11-15-2014, 05:22 PM
  #288
KJI3jflarryfe93's Avatar
ZAYED,,
hey bro
the ecu you're talking about, is it the one inside the plastic black box in the engine bay?
you don't don't touch that ecu, just leave it the way it is hooked up to the new engine?
Old 11-15-2014, 05:38 PM
  #289
cm60k's Avatar
Sure bro,
It's the main ECU/MSG, in the module CAN box,
just leave it as it is,,
of course need to reset/adapt the whole system after Engine swap...
ZAYED,,
Old 11-15-2014, 06:21 PM
  #290
PJmak's Avatar
What do you mean reset the whole system? What procedure is this?
Old 11-15-2014, 07:04 PM
  #291
sick430's Avatar
CLK Cabrio
unplug the battery for an extended amount of time 4+ hours
Old 11-16-2014, 01:10 AM
  #292
cm60k's Avatar
After swap everything, you have to use STAR/SDS and check if any fault present, reset all system to see if everything compatible,,
don't use any other device, STAR/SDS is the best to complete this job properly...
ZAYED,,
Old 11-16-2014, 06:03 AM
  #293
zayed
the intake manifold on c43 engine is it the same size and partsnumber on e55 engine?
SAABO's c43 engine transplant was not without headache when he had trouble with his e55 engine and it turned out it was the intake manifold which was faulty.
are both engine manifolds the same?
it's good to know if they can be swapped over?
Old 11-16-2014, 08:15 AM
  #294
cm60k's Avatar
Dennis,
All M113 intakes are the same, no difference,
as i remember; vince opened his intake to reseal it, then problem persists, for that he replace it...
ZAYED,,
Old 11-16-2014, 08:55 AM
  #295
Dennis,
ZAYED,,
you have always the correct answers brother, that's great
thanks bro
what kind of faulty codes could appear if ecu is not reset by star after engine being transplanted?
Old 11-16-2014, 11:31 AM
  #296
cm60k's Avatar
AnyTime bro.,
ECU may catch some faulty fuel/air mix., via E-prom/RON or via O2 sensors, and save it to the data/memory, should to see first what kind of codes will appears...
ZAYED,,
Old 11-16-2014, 01:12 PM
  #297
AnyTime bro.,
ZAYED,,
so best thing to do is: install engine, start car, connect STAR to ecu, check codes, reset possible codes and finally let ecu re-learn the new engine by driving the car for few hundred miles?
this is what to do, step by step?
Old 11-16-2014, 01:55 PM
  #298
cm60k's Avatar
Excellent, this is the CORRECT way...
ZAYED,,
Old 11-16-2014, 02:54 PM
  #299
PJmak's Avatar
Zayed have you ever dynoed your car?
Old 11-16-2014, 03:11 PM
  #300
cm60k's Avatar
Yeah, as remember; almost 4 years ago, 362hp>>371kw, hope i'm not wrong..!!
ZAYED,,
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
Quick Reply: C43 '55' swap thread
