C43 '55' swap thread
Old Nov 16, 2014 | 03:30 PM
  #301
PJmak's Avatar
No mods of any kind?
Old Nov 17, 2014 | 10:03 AM
  #302
KJI3jflarryfe93's Avatar
Is this correct that these c43 parts fits the e55 engine, they all share the same partsnumber?
water pump
belt tensioner Litens
belt idler pulley INA
thermostat Wahler
oil cooler gasket kit
valve cover gaskets
MAF Bosch
ignition coils Bosch
wires for sparkplugs Bosch
sparkplugs NGK PFR5R-11 Laser Platinum = these plugs fits both engines?
belt Contitech 6PK2390
engine chain IWIS
Is it true the only part that is not the same between both engines is the harmonic balancer because the e55 engine has a larger displacent than c43 engine?
harmonic balancer made by Corteco
Old Nov 30, 2014 | 12:35 PM
  #303
PJmak's Avatar
Finally dropped off my car on friday. Im more excited by the day plus we picked up my friends 97 c36 that just got converted to a six speed manual. Riding back in it got me really inpatient
Old Dec 13, 2014 | 06:06 PM
  #304
PJmak's Avatar
My friend is making progress on my swap. Just a few pics so far of the ml55 m113
Attached Thumbnails C43 '55' swap thread-img_2904.jpg   C43 '55' swap thread-img_4845.jpg
Old Dec 14, 2014 | 09:32 PM
  #305
svt ricco's Avatar
1999 C43 AMG
^^^rkd just sent me this picture today!
Old Dec 16, 2014 | 03:43 AM
  #306
DRBC43AMG's Avatar
Looks nice and clean in the engine. That's a compliment for the use of Mobil1 I imagine...
Old Dec 16, 2014 | 04:01 AM
  #307
don't fogget to drive your car with stock ECU for some months to see how your car copes with the new engine, I wanna know about = gasmileage/HP/torque/vehicle speed after your modification is done
i'm curious about this info about 5.4L engine and stock ECU performance
Old Dec 16, 2014 | 11:13 AM
  #308
PJmak's Avatar
Im having mine flashed to the 5.4 spec before the engine is even in
Old Dec 16, 2014 | 11:53 AM
  #309
si ti LUD covece?!
why don't u test with stock ecu and new engine first then do the flash after a month or so to compare?
Old Dec 16, 2014 | 12:07 PM
  #310
PJmak's Avatar
Originally Posted by kowalski
si ti LUD covece?!
Hehe i could do that but i had a few very reliable sources tell me that the car runs better on a 5.4 flash.
If there is difference in power its not gonna be huge. Its not worth it if my car will run super rich or stuff like that
Old Dec 16, 2014 | 12:40 PM
  #311
what company are you using to tune your ECU?
how much is it to reflash?
Old Dec 16, 2014 | 12:52 PM
  #312
PJmak's Avatar
Its only $115 at my friends shop
Old Dec 16, 2014 | 01:18 PM
  #313
is he reliable?
does he offer srpski popust?
Old Dec 16, 2014 | 01:41 PM
  #314
PJmak's Avatar
is he reliable?
Yep hes MB certified and hes doing my swap.
Dobar mi je ortak tako da uvjek napravimo neki deal
Old Dec 16, 2014 | 01:47 PM
  #315
Pitaj tvoj ortak if my Swiss ecu (goes like clockwork) and the US ecu has the same specs then it will be no prob for re-flashing?
Old Dec 18, 2014 | 11:03 AM
  #316
PJmak's Avatar
I will but i doubt he would know something like that
  #317
PJmak's Avatar
Anyone know if clk430 headers are the same as c43 ones?
Old Dec 18, 2014 | 11:09 AM
  #318
i have the euro ecu programming, equivalent to Swiss quality clock mechanism
Old Dec 18, 2014 | 11:32 AM
  #319
cm60k's Avatar
As i know; CLK430/55 sharing the same Exhaust set-up with C43..
ZAYED,,
Old Dec 19, 2014 | 12:21 PM
  #320
PJmak's Avatar
Thanks. I had to pick up a drivers side header because mine was cracked and it was the cause of the ticking noise.
Got these cleaned and they are ready to go on the 5.4
Old Dec 19, 2014 | 01:17 PM
  #321
Pagz's Avatar
C43 w/clk55 Organs
Pjmak,
Where abouts did your header crack?,under what conditions did you notice the ticking?.
Tripple check that rear crank seal housing, wis spec's replacing it with the seal, the magniusium becomes porous around the sealant path which could leak on reseal.
Sounds like the porsche racing mb guru has your project under control
cheers,
Old Dec 19, 2014 | 01:49 PM
  #322
PJmak's Avatar
Oh yea he does lol
The header cracked right by where it connects to the block and then it expanded I guess. You could stick your finger in there almost. It was drivers side all the way in the back btw. It was cracked in a way that couldnt be welded so i had to get another one. I picked up a good condition one for $60 so wer good to go.
I started noticing ticking noise right before my last oil change. I changed the oil but it didnt quiet it down at all. Since then it only got worse. I had multiple people tell me its lifters but then a few suggested its the exhaust. I do scrape with my exhaust when i go over bumps. Its painful but i have to deal with it lol. Im guessing that initiated the crack which probably expanded from heat eventually.
Inside the header is a metal pipe that was loose which was making a clicking sound that one could easily mistake for a lifter noise.
But anyway all this was a reason to swap the motor and i didnt care wether it was the lifter or the exhaust. It turns out the motor is still in good shape after my friend took it apart. Sadly its not worth much. I think itll end up as a coffee table in his house.
Also all seals are getting replaced plus the unexpecred $300 tranny reseal and flush :/
Edit: the ticking noise was only there under acceleration btw
Old Dec 19, 2014 | 03:07 PM
  #323
Pagz's Avatar
C43 w/clk55 Organs
Good info thanks!
Was there still some ticking in higher rpm when you took foot off excellerator?
Im was thinking of making mine into a coffee table also
Old Dec 19, 2014 | 04:02 PM
  #324
cm60k's Avatar
Good idea Paul, with Pancake of course..
ZAYED,,
Old Dec 19, 2014 | 04:14 PM
  #325
PJmak's Avatar
I wish i had a place to keep it. Id experiment and try to learn on it or something
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
