C43 '55' swap thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old 08-30-2015, 04:46 PM
  #476
bgalakazam's Avatar
1999 SL500
Hi gurus , anybody who did this at a shop, how many hours of labor / cost are we looking at for a swap? I went through the instructions and given enough time and the right tools along with patience it's possible to do this at home. Problem is I don't have a garage so it's out of the question at this time for me.
Old 08-30-2015, 10:01 PM
  #477
nkctb7's Avatar
2006 E55 AMG/1996 C36 AMG/1999 C43/55 AMG
The price would depend on the quality of shop you choose. Personally I don't have a garage either but I'm doing it all myself. I have the 5.4 completely disassembled and just about ready to paint the block. It is enjoyable performing and completing the work on these cars. The finished product will be worth the time. Good luck!
Old 09-16-2015, 01:17 PM
  #478
DRBC43AMG's Avatar
Location: Land of mountains, cheese, chocolate and watches
12' W204 C63 AMG coupe "T-Rex", 12' W451 Smart Fortwo Pulse (99' W202 C43 AMG sold)
I came across this thread on one of the UK MB forums. Interesting dyno results for a 55 engine. Approx 400hp is pretty serious numbers IMO
http://www.mbclub.co.uk/forums/perfo...fications.html
Old 10-02-2015, 01:28 AM
  #479
amer-abdulla_87's Avatar
C43 ///AMG
Talking Engine Swap Time !
it's happening!!
Your valuable tips and advises prior the installation will be greatly appreciated..
Old 10-02-2015, 11:19 AM
  #480
DRBC43AMG's Avatar
Great news Before getting the engine in the 43, do everything that is needed because things will be easy with the engine out: sparkplugs, valve cover gaskets, waterpump perhaps?, crankshaft oil seal, etc., etc.
Old 10-02-2015, 01:33 PM
  #481
cm60k's Avatar
00 C200 & 00 C55 & 06 SLK55
^^Agree with Daniel^^
ZAYED,,
Old 10-02-2015, 04:56 PM
  #482
C43 ///AMG
Thank you for your feedback.
Am planning to replace most of the items you mentioned above, adding to that the Air filters and the timing belt as they are already in bad condition.
I'll try my best to photograph and document each step of the engine fix/swap.
Old 10-02-2015, 04:59 PM
  #483
blackbenzz's Avatar
haters crazy
There is no timing belt
Old 10-02-2015, 05:06 PM
  #484
DRBC43AMG's Avatar
Timing belt?
You mean the ancillaries drive belt up front for the fan, water pump, alternator, A/C compressor, etc.
Old 10-02-2015, 05:13 PM
  #485
C43 ///AMG
Sorry, I meant the drive belt which is placed between the Idler pulleys.
Old 10-08-2015, 04:12 PM
  #486
C43 ///AMG
Gents,
Excuse my lack of experience in this field but currently i seek your advise. The engine oil filter of the 5.5 noted to be in horrible condition, does this seem to be problem in future?
Also, am having hard time to remov the tranny cooler pipe which is stuck to the back side of the 43 engine. Is there any special tool which used to remove it?
This issue might be discussed previously but am not able to trace it.
Regards,
Old 10-08-2015, 04:20 PM
  #487
Pagz's Avatar
C43 w/clk55 Organs
This filter has not aged well!
I know AMG strongly specify the use of specific high grade filter for the high flow pumps in these engines,I would imagine its easy for indy's to chuck any old filter in there?
Old 10-11-2015, 05:32 AM
  #488
DutchC54's Avatar
1998 W202 C43 ///AMG 5.4
u need to order that pipe .. partsnumber is 112 990 03 78
u want to be sure its leakproof when installing it in the 5.5.one which has been used will fit less good. the cost is like $/€2.-
Old 10-11-2015, 02:12 PM
  #489
Pagz's Avatar
C43 w/clk55 Organs
Agree with Dutch you should order a new nipple, they are cheap.
The original is glued in and I would do the same again. It is very easy to damage the mating surface when removing so do carefully, iirc I ended up punching mine in a little which collapses the seal,you can then pull out.
Also, always replace the seals on EGR pipes to manifold when disturbed!
Old 10-12-2015, 12:11 AM
  #490
C43 ///AMG
Thanks Dutch and Pagz for the info, I've ordered for new pipe and it seems it would take more then 2 weeks to reach as its not available in stock.. so some how i managed to remove it with creating any damage or deformation
The Propshaft or Crankshaft mountings observed to be in bad condition, so i had to replace them. My C43 use to have harmonic vibration in whole body (not only in the steering) spicially at high speed, could this be the reason?
90% of the job is complete.. we'll update once the engine is in.
Old 10-12-2015, 03:53 AM
  #491
Pagz's Avatar
C43 w/clk55 Organs
Good work you are indeed pro nipple remover!
While you have the prop shaft out check all parts of the shafts for wear check locating bushes oval at diff, spline dry/worn, notchy/dry universal, dry/worn hanger or bearing play
The donuts are in very bad shape this would not help at all with vibration!
Old 10-21-2015, 10:27 AM
  #492
C43 ///AMG
Finally, the engine swap was successfully done. I had some issues in the beginning which it was not related to the engine, but all solved now.. the engine effectively operate.
So i took the car for speed & acceleration test, i honestly haven't expect much from this 5.5 engine, but WOW ! the car become massively powerful & felt way smooth and faster then the 4.3 engine..
Am using the C43 ECU & transmission, and everything until now response well to the engine..
I am happy with the current gained power and i don't think i would tend to modify further..
I've put some effort & $$$ to make this successfully work & definitely i don't regret this swapping project at any point, thanks to ZAYED and his monster C55 for creating the motivation to do so
While testing the car, i had chance to do some drag racing from rolling start, one of the victims was the new A45 ///AMG, which ultimatily lost .. right now i'll be hunting the new VW Gulf VII-R and V8's american muscules .. lets see if this engine will impress me more
Old 10-21-2015, 10:37 AM
  #493
cm60k's Avatar
Good Joob Bro., more more victims you will eat for sure..
ZAYED,,
Old 10-21-2015, 05:25 PM
  #494
PJmak's Avatar
Ive pulled on some interesting cars but lately my car has been strugling against cars that i know i should blow out the park.
A45 is not slow...especially from zero to sixty. Do you think the 5.4 swapped c43 would beat it in a quarter mile?
Old 10-22-2015, 06:48 AM
  #495
ProjectC55's Avatar
C43/55,2k11 Volvo S60 T6AWD,2k Audi B5 S4,95 Eagle Talon Tsi AWD 500+awhp
maybe not. The C43 was not built for the quarter mile. But past the quarter mile you will eat any A45 amg's lunch!! I have done that to many an S4 and RS4 Audi which is faster than the 4 cylinder AMG.
A modded old V6 TT S4 can be a serious challenge though ,they are very fast stage 3 and up .
Old 10-22-2015, 06:51 AM
  #496
ProjectC55's Avatar
The more you drive her the more you'll appreciate the new found heart transplant!!
Old 10-22-2015, 08:09 AM
  #497
KJI3jflarryfe93's Avatar
it's happening!!
congrats on your new heart transplant
you must now have a much wilder car to drive?
what year is the new engine and how many km's did this engine cover?
your c43 how many km's did it cover until now?
Old 10-22-2015, 08:29 AM
  #498
cm60k's Avatar
+1,
Carl, my C55 is much monster from dig to about 95 mph, then starting to slowing down,,
i think C55 with 2.82 will be better after quarter/mph, but stock 3.07 is more better from digging..!!
ZAYED,,
Old 10-22-2015, 04:22 PM
  #499
PJmak's Avatar
When using a transmission from a different car(for example a 2001 e55)....is it normally just plug and play type of deal or is there anything that needs to be done to the ecu or trany?
What would be the proper procedure when doing a trany transplant from a newer model amg?
Old 10-27-2015, 01:35 PM
  #500
Alex33's Avatar
W202 w/ a 5.4L V8
Hi PJ, my guy cleared any codes and did a full TCU reset before I got the car back. The shifts are firm and crisp and I'm very happy. What's your location? I may have a guy for you to see if you're close enough.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
Quick Reply: C43 '55' swap thread
