C43 '55' swap thread
http://www.automotix.net/usedengines...8ee9&seq_num=6
when i hit the page it was engine 5
I see some posts say you can run the C43 ecu on the 5.4 displacement without problems? in my limited experience with tuning i dont see how that would work correctly as WOT must still run on maps,i guess knock control could be retarding timing enough to cope with the increased displacement but it would be far from ideal,has anyone actually run the 5.4 on a dyno to check AFR's??
If there was an opportunity to install the E55 ECU,TCU and security module what would stop them from functioning correctly in the C43?
cheers
309.90 torque
284.66 rwhp
Running stock C43 ecu
A/F runs rich, then levels out and only goes lean around redline.
I think there is more power to be gained if the C43 ecu can be reflashed with a E55 performance tune.
Short youtube video here
http://www.youtube.com/watch?v=CU1prT1a2zg
309.90 torque
284.66 rwhp
Looks like you guys had quite the crowd watching the dyno
WOW... almost 70 ft/lbs and almost 45 HP more at the rear wheel, IMPRESSIVE. More and more I am thinking about canning the W210 idea and dumping the $$$ into the 55 swap...
P.S. I found this vid:
http://www.youtube.com/watch?v=yKgRC...eature=related
NICE 500E
NICE 500E
Group dyno event for the BMW CCA guys, so lots of people around.
I have a few vids of my cars on youtube, nothing special, mainly slideshows of pictures (which are all on my web site.)
309.90 torque
284.66 rwhp
Other than the exh mani's one of the biggest restritions with the w208 CLK55,W210 E55 and C43 is the way they designed the air intakes by the front grill. Just horrible. Very very restrictive. Find a way to get around that and you'll definitely free up some topend hp. They did it right with the N/A SL55,S55 and CL55.
I did like Mbenzman and put in the entire CL320 intake and built a ram air intake by losing the passenger side foglight where the space is much bigger and where you'll get tons of air rammed into the intake.
What are your numbers now???
Shouldn't take much convincing, $400 for even 20 HP is WELL worth it... I would spend $800 for 20 HP RIGHT NOW!!!
Anyone know if the w211 E55 motor (M113) will fit--supercharger and all? Would it be too much power for the 722.6 trans (better question---does it have the 722.6 transmission?)?
https://mbworld.org/forums/c36-amg-c...-you-cant.html
It's doable (he's done it!), and there are probably a few other swaps out there (including at least one in Germany) but there's not a lot of info on it out there.
I recall Money-One posting about his difficulties with the engine management, and how the stock ECU is at its limits to tune the supercharged engine. The alternative is stand alone engine management, but the next issue there is that most aftermarket stand alone systems don't typically have the capability to handle twin spark heads. If the heads were normal, I suspect Money-One would have gone down that route, and happily running the car, long ago.
I'd be keen to see what the German swap(s) have done in this regard. It could potentially involve the entire drivetrain and electronics swap from a 55K car? Sounds like fun, but I'm sure its a huge pile of work too!
I'm certain he would know something as I can image that AMG special projects department (I'm sure that exists....) would have done that kind of conversion. A pity as it seems he just disappeared
I hope we didn't frighten him away with all our questions
By the way i bought a m113.980 (E55 W210) engine today for about 1000$... will start a project thread when i get it on friday
how many miles on that engine?
1000 buxx must be a high mileage engine or what?
then you need a 300 speedo
Its about 12500miles on the engine..
I am going to do a total renovation of the engine. will replace all gaskets and send the heads to the pressure test, check the crankshaft bearings, replace the water pump, etc., etc. paint engine in light gray/white as the M156 engine..
