Suspension for C43
I've only checked the front box but it says its for both W202 and W208.
Hope I answered your question!! good luck!!
http://mbspecialist.com/mercedes_web...0/2103503406O/
this arm is the one behind the dustshield ontop of all other arms
this arm is the one beind the dustshield ontop of all other arms
this kit fits all W-zwei nul zwei.
http://cgi.ebay.de/FEBI-Quer-Zug-Sch...item588c9c6697
I see they are bolted by a screw and a nut.
http://uk.mbspecialist.com/mercedes_...0/1243506408O/
is it necessary to remove lots of parts on the car to access these bushings?
Can they be chiseled out or is it necessary to use a press tool machine to take them out?
are they 2 or 4 bushings on front axle?
Correct me if I'm wrong, but I don't think it's going to be that easy to do those bushings. While the bushings themselves may be cheap, I think you're going to have to drop the whole subframe off the car to replace the bushings. And doing that means removing the diff and the axles too.
The Kochtools.com tool looks like it's made to remove the diff bushings without having to drop the subframe, but you'd still need to remove the diff to get at them. And even if you can chisel out the subframe bushings, you will most likely need a press to press the new ones in. The one bolt (per bushing) holds the subframe to the chassis, it doesn't bolt the bushing into the subframe.
I'd check the WIS for instructions to be sure though.
Edit: I just checked out the Klann tools website. They make a tool - part number KL-0356-11 - which allows removal and replacement of all four subframe mount bushings, plus the diff mounting bushings too, and they say you don't need to remove the rear subframe to do it either. But the kit uses a hydraulic cylinder to do the hard work. I think they have a kit without the cylinder though. If you don't wanna buy the tool, probably best to head to a specialist who already has the tool.
Here's the Koch Tools item:
http://www.kochtools.com/index.php?p=product&id=84
Your reply was for the rear axel,
my question was for the front axle, if it's an easy change for these subframe bushes?
is it needy to remove several parts from the front axle to axess the front sub bushes?
On the front of the car, the control arms bolt to the chassis directly, as do the engine mounts.
Weird as the rear measurements says nothing for rear camber
Kowalski aka Mr.D. from the land of lots of blond hoes n fly honeys.
How you doin?
Did you ever post the test results of the 4 wheel alignment when you did all suspension parts swap?
I wanna see what kind of scores U got with MB Arts camber arms.
I can't find the link!
Can you post it if you haven't done it?
Thanx bud.
How you doin?
Thanx bud.
One thing is for sure, I was WAY off of stock specs to begin with (probably due to needing an alignment for a while combined with the 19" rims I installed). I went and had my tires balanced 4 days ago and the difference is like night and day, the ride is SOOOO smooth now. I should have balanced the tires right after the alignment.
If you like I can post my alignment specs later when I get home.
Did the stock factory specs and new specs for adjustable camber arms for the C43 show up on your sheet?
Your car was it set to stock factory numbers for your new camber arms when alignment was done?
Thanks bud
Das ist gut.
Danke dude
