The new project
Old Apr 18, 2011 | 04:26 AM
  #151
ARuss's Avatar
c5.8
Old Apr 18, 2011 | 04:27 AM
  #152
ARuss's Avatar
c5.8
Soon there will be still news
Old Apr 18, 2011 | 05:33 AM
  #153
DRBC43AMG's Avatar
Guess you can still squeeze inside despite the cage That is going to stiffen the chassis no end Have you an idea how much weight the cage is?? Keep up the good work
Old Apr 18, 2011 | 06:43 AM
  #154
ARuss's Avatar
c5.8
50-60 kg
I will more precisely tell later
Old Apr 18, 2011 | 06:07 PM
  #155
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
So I take it this is going to be a track car ?
Old Apr 18, 2011 | 11:30 PM
  #156
ARuss's Avatar
c5.8
drift and some track
Old Apr 19, 2011 | 12:24 AM
  #157
23K's Avatar
23K
Is the gearbox from the 203 C240/320? ,Looks the same as the one iv just bought but im still waiting on shipping...if so will be interesting to see how it holds up with the 5.4 as its also what im hoping to run.
Keep up the good work!
Paul
Old Apr 19, 2011 | 12:45 AM
  #158
hoontastic's Avatar
99 c43 / 99 ml430
i'm guessing a diesel gearbox so it can take the torque.. but with different ratios. This is such an awesome project. I can't wait to see the full widebody painted and detailed.
Old Apr 19, 2011 | 01:47 AM
  #159
svt ricco's Avatar
1999 C43 AMG
Old Apr 19, 2011 | 01:52 AM
  #160
Hands down the greatest W202 project I have ever seen Please keep us UPDATED!!! We will need videos once the project has completed
Old Apr 19, 2011 | 02:02 AM
  #161
hoontastic's Avatar
99 c43 / 99 ml430
they are artists for sure.
Old Apr 19, 2011 | 11:23 PM
  #162
23K's Avatar
23K
That would mean the gearbox would need to have come from a 2005+ W203 or similar V6 3L/3.2L diesel....didnt realise they made those in manual!.
Edit: Theres speculation on other forums regarding the torque of the V6 diesel being reduced when mated to the manual trans...wouldnt mind betting its the same trans used on the M112's,possibly with different ratios.
Old Apr 20, 2011 | 06:47 AM
  #163
popey24's Avatar
C43 AMG 5.5 - 396.4HP
How did you fix the cf roof with the cars body?
Remember for the big front wheels you want to install you will also need to cut some metal out of the wheel housing. Otherwise you will have some trouble steering...
Keep us updated!
Old Apr 20, 2011 | 10:49 AM
  #164
DRBC43AMG's Avatar
Keep us updated!
I thought they were installing front and rear sub frames from a W210... so being wider that should give perhaps some extra room
Old Apr 20, 2011 | 02:45 PM
  #165
popey24's Avatar
It is not the fender that causes problems but parts of the body/frame/internal wheel housing.
Old Apr 21, 2011 | 06:27 AM
  #166
hitch's Avatar
Mercedes-Benz W203 C230k
Well, since Alex is not entertaining you enough, let me comment the pics and try and answer your questions. We've done a rally spec rollcage to meet the fia regulations, because the car is going to take part in different events inside and outside Russia. So, at the moment the car is being resprayed. After that we'll do the wiring and begin assembling. The roof is mounted with the special glue, we borrowed from e92 m3 service manual, so we're quite sure, it will withstand everything. Speaking about the tranny, it is a petrol gearbox from w203 c240/320 with a diesel clutch and release bearing. Besides, we bought a very big rear diff and going to fit it with a quite lsd from c32. Finally, we cut unnecessary metal from the wheel arches and replaced it with light plastic covers. Thus, we solved the steering problem (wheels used to clip arches in full lock) and saved some weight. Cheers, guys! We'll keep the news coming.
Old Apr 21, 2011 | 06:30 AM
  #167
hitch's Avatar
Sorry, quaife lsd.
Old Apr 21, 2011 | 01:14 PM
  #168
ECTurboGSX's Avatar
98 C43, 15 Alfa 4C LE, 18 Tesla Model 3 DM Perf, 08 Duc S1000, 02 Duc 998, 98 Duc 748, 01 Miata
Did the manual transmission bolt up? It doesn't look like you have an adapter plate.
Old Apr 21, 2011 | 04:04 PM
  #169
hitch's Avatar
it didn't bolt up without any problems - the "bell" is slightly modified. Still the conclusion we can draw is that both petrol and diesel gearboxes can fit if needed.
Besides, I want to mention that alongside the w210 subframes the car got the w210 amg steering rack instead of that old piece of **** whatever it is called. And our cf roof has already been tested by the leader of our team ( almost 200lb )
Attached Thumbnails The new project-365.jpg   The new project-469.jpg   The new project-470.jpg   The new project-694.jpg
Old Apr 21, 2011 | 04:05 PM
  #170
Motorsport3's Avatar
Dynocomped C43K, 08 X5
Yes please give us more insight on the manual swap:thumbs:
Hope to see your project goes well!!!
Old Apr 21, 2011 | 04:15 PM
  #171
hitch's Avatar
ok, we'll tell more about it a bit later!)
Old Apr 21, 2011 | 06:07 PM
  #172
hoontastic's Avatar
99 c43 / 99 ml430
i know you guys are doing all the work and it takes time to do it right but the slow motion reveal is SUCH A TEASE!
Old Apr 21, 2011 | 10:16 PM
  #173
ll1l2l1l2lll's Avatar
w202
PROPS.
Old Apr 22, 2011 | 03:16 AM
  #174
hitch's Avatar
nope.. the thread is totaly up to date..
Old Apr 22, 2011 | 03:49 AM
  #175
hoontastic's Avatar
99 c43 / 99 ml430
i know its just so entertaining to watch it develop that we are all holding our breath
