drilled rotors
Old Dec 1, 2010 | 01:47 PM
Outlawlatemodel's Avatar
2006 c230
drilled rotors
I found a place cross referenced the rotors to the 04 c230sport and they are sending front and rear drilled rotors for 249 shipped, we will see what they look like when i get them,
Old Dec 1, 2010 | 02:01 PM
austinholloman's Avatar
W203 C55 and SAAB 9-3 2.0T
The rears wont fit, IIRC. You need to find yourself the cross-drilled r129 rears but the fronts will, $249 is still a great price for all four. Sell there rears and you have you self some super cheap rotors! Who made them, btw?
$175.36 shipped for front set here:
http://www.autohausaz.com/search/pro.../Brake%20Rotor
Old Dec 1, 2010 | 02:28 PM
2006 c230
the rears will fit as they sold me c43 rear drilled rotors which are the same as c32, regardless it beats the fuch out of 250 a front rotor
Old Dec 1, 2010 | 09:05 PM
Hm let us know how they work out. Who's makes these?
Old Dec 2, 2010 | 03:23 AM
DRBC43AMG's Avatar
Just to get things in perspective, C43 front rotors are 334mm and rears 330mm
Old Dec 2, 2010 | 08:20 AM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
Are your sure??? I thought they were:
Four channel 320 mm ventilated disc brake at the front
Four channel 300 mm ventilated disc brake in the rear
Old Dec 2, 2010 | 08:23 AM
Saaboteur's Avatar
eclectic assortment of cars
I believe the rears are actually 300mm. Looks to be the same as a C32/C55.
Old Dec 2, 2010 | 09:15 AM
DRBC43AMG's Avatar
As always, thanks MarcusF
http://marcusfitzhugh.com/CLK/W2024355.html
Old Dec 2, 2010 | 10:04 AM
As I said, w203 230k sport fronts and r129 rears will work. Not the rears from C32.
Old Dec 2, 2010 | 11:04 AM
Saaboteur's Avatar
Are you sure about that? I cross referenced rear brakes between C43 and C32/55 on bimmerspecialist.com, and they come up with the same part numbers. Maybe not cross drilled, but I believe dimensionally they will be fine.
Old Dec 2, 2010 | 12:26 PM
2006 c230
the rear brakes are the same as a c32/c43 and several other cars, i didnt feel like spending another 500 on front rotors that seem to worp easy so on another thread a guy put c230k sport rotors on the front, c43 rotors are 334 and c230 are 330. 4 mm is so small i am not going to worry about it
also be cautioned that you have to have 2004 up c230k sport rotors because up to 2003 they are 288mm/300mm
if you look the r129 rotors are probably the same as the c43/c32 rotor. I had a terrible time finding an exact year on the r129 rotors because they to come in different sizes. Then i found that a 2002 c32 rotor is the same part number as a c43 although some people say they are different but are the exact same number, we will see next week when i get them.
Old Dec 2, 2010 | 04:12 PM
DRBC43AMG's Avatar
Now that is super interesting. What about the price difference?
Old Dec 2, 2010 | 04:16 PM
ohlord's Avatar
Won't matter anyway
since they offer no improvement over full plate rotors and as always will crack at the holes on the down side.
When will they ever learn?
Old Dec 2, 2010 | 08:36 PM
2006 c230
Its not so much the price its no one wanting to cross reference like gm or ford does, most people actually told me that iwas wrong I did not have a 98 c43 that i had to have a 99 as there books say there is no 98
on drilled rotor cracks whats the difference the amg c43 rotors warp and drilled crack at least its 700 dollars cheaper to replace when they are bad
Old Dec 3, 2010 | 01:13 AM
You can buy the 2004 C230k Sport rotors Autohaus AZ that are missing the cross drilled holes. They are still a quarter of the price and don't crack.... If you like the look of cross drilled (as do I) then you just have to clean the holes out as often as you can, the build up and heat change is what causes them to split.
