Oil leak question
Old Dec 7, 2010 | 02:22 AM
DC43's Avatar
C43 AMG
Oil leak question
My mechanic found my 98 C43's oil filter housing is leaking. He quoted me about $1,000 for the replacement of gasket and sealing. Does it sound about right to you guys? Any similar experience here?
Much appreciate any inputs.
Old Dec 7, 2010 | 04:02 AM
KJI3jflarryfe93's Avatar
you can buy those gaskets for less than 20 dollars on www.autohausaz.com
# 1121849961
and if you need a new oil cooler then you also need to buy the above rubber kit
# 1121880401
he needs to remove a few parts to access the leak, but a 1000 bux sounds steep!
when he does the leaks, it's a good point checking out the H- Balancer condition, belt tensioner, belt is greased by the leaks, the upper plastic pulley, and the timing cover gasket for possible leaks?
I tried to link the parts it didn't work
Old Dec 7, 2010 | 07:41 AM
StapleGun's Avatar
1967 Morris Cooper "S", 1983 911SC, 1997 Toyota Tacoma, 1999 HD FXSTB, 1998 C43
Not a difficult job to do yourself
What a rip off - search on the forum, it is an easy do it your self project.
Old Dec 7, 2010 | 03:51 PM
DC43's Avatar
C43 AMG
Thanks for the replies. I understand that it takes some time to get to the part. But does it really require hours of labor?
Old Dec 7, 2010 | 05:33 PM
Saaboteur's Avatar
eclectic assortment of cars
Here's a link to the DIY on the oil cooler o-rings. Bloody things are expensive little basterds. Make sure you shop around and don't buy them from the dealer! As Kowalski said, autohausaz is probably the best US based source. Being Canadian, I found an alternate Canadian retailer.
https://mbworld.org/forums/c36-amg-c...il-cooler.html
You should also replace the oil pressure test port o-ring/gasket, while you're there.
I did this job in the spring and it took me a leisurely afternoon, ie. with a break half way to chill out. It helps to have the right kind of fan removal tools, ie. the specific holder and then the long, thing 32mm wrench. I have purchased both specifically for the fan removal task.
I can't remember if you need to remove the fan to get at the oil cooler, perhaps it's necessary to get at the oil pressure test port. It may not be necessary, but it does make everything substantially easier as there is a lot more room to work.
Old Dec 7, 2010 | 06:04 PM
yo bro.
what is this you describe?
Is it the rectangular squared gasket with a rectangular cover in metal sitting on front timing chain cover?
when you changed all these gaskets did you have to drain the complete engine from oil, suck it dry?
Old Dec 7, 2010 | 06:38 PM
Saaboteur's Avatar
These are the gaskets I mean. There is only one per car, but it is one of two types.
I actually went ahead and purchased both, as I wasn't sure which one I had. Thus I have an extra, for anyone who is interested. I believe I have an extra one of the later style gaskets, but I'd have to double check.
Old Dec 8, 2010 | 06:21 AM
the later style gasket doesn't fit on first old style cover?
Old Dec 8, 2010 | 01:00 PM
Saaboteur's Avatar
Yeah, that's correct - if I remember right!
If I remember right, the casting is slightly different. While you might be able to physically jam the later style gasket into the older style casting, it won't fit properly.
Old Dec 8, 2010 | 01:26 PM
what kind of seal protection does a rectangular shaped gasket provide without any centre rubber?
early c43 engines had this poor gasket and later cars had the revised gasket.
åttohausaz provides engine parts numbers for early and later edition engines, this is difficult to see which ones we have.
my car is manufactured late 98 as 99 car, do i have the crap gasket or the revised version?
Old Dec 8, 2010 | 03:04 PM
Saaboteur's Avatar
I think you need to check your VIN or engine serial number to confirm. If you punch in your VIN to that Russian site that decodes the VIN, then it also spits out your engine serial number. Then you can cross reference which seal to get (or crank position sensor - as those are engine serial number dependent too).
Old Dec 8, 2010 | 03:53 PM
my crank position sensor is # 026 1210 170
1 clip on lock.
does it mean i have an early engine?
other cps have 2 clip on lock is it the newer engine?
where's the russian site?
thanx
Old Dec 8, 2010 | 04:00 PM
Saaboteur's Avatar
Here's the link to the Russian VIN decoder, but it doesn't seem to be working at the moment:
http://www.mbclub.ru/no_vin.html/?lng=eng
Be careful on just labeling your engine early or late. The CPS variation runs to a certain engine serial number, but I believe there is some overlap with the engine numbers for the test port gasket, ie. there is probably a range of engines which use the early CPS and late test port gasket. You have to check your engine serial number range independently for the correct CPS and test port gasket.
Old Dec 8, 2010 | 04:16 PM
abooooout the CPS I have already changed it to prevent future fu-- ups when driving.
For this part I believe in safety and I wanted to avoid any problems that might occur because of a weak part.
So did I with the belt tensioner also, I had it changed when my HB fuc-ed up.
well I'll take both front port oilgaskets ps numbers and ask the stealership for correct part.
and then buy it from an internetshop 4 cheap bread.
I will do the same with upper oilcooler seal kit, buy from autohausazzzzzzzzzzzzz
this is the only way to do
Old Dec 9, 2010 | 05:32 AM
DRBC43AMG's Avatar
It hasn't been running for some time now. Looking like the dead Club202 site
