drilled rotors install
Old 12-11-2010, 03:47 PM
Outlawlatemodel's Avatar
2006 c230
here are the rear rotors installed, the fitment was for a c32 i crossed oe part numbers and they are a perfect fit,
Old 12-11-2010, 06:20 PM
KJI3jflarryfe93's Avatar
did c32 have crossdrilled rotors on rear brakes?
are they 300mm or bigger,
c43 have 300mm rear rotors?
do you have the parts number for these rotors?
Old 12-11-2010, 06:55 PM
2006 c230
Hi yes exactly the same, find a c32 standard rotor and cross it to a c43 same part number, so i just used c32 rear rotors even had the emergency brake drum setup the same,,, front drilled rotors are done gotta get a picture in a minute
Old 12-11-2010, 07:07 PM
austinholloman's Avatar
W203 C55 and SAAB 9-3 2.0T
Pictures of the front and your review!!!
Old 12-11-2010, 07:32 PM
2006 c230
the place i got the rotors from sent all the same direction which is not ok but i have to put the car together and cant wait on 8 days shipping so if you can see both sides at once FU, its a street car
anyway 249 for all 4 drilled rotors 114 dollars for all four pads, wow i saved like 600 bucks
ok ok on to the rotors i measured the front anyway you can think and they are the same, in the picture the front hold down bolt is not in but it even fit, I could not ask for a better fit even if it was the amg rotors
so lets put it to rest
2005 c230 sport k 330mm work perfect i even set my old rotors on top and they are maybe 1mm bigger on each side i did say maybe
c32 rears 300mm work perfect, its snowing but im gonna go break the biathes in,,
o i bet you want pictures
Attached Thumbnails drilled rotors install-c43-rear-260.jpg   drilled rotors install-c43-rear-261.jpg   drilled rotors install-c43-rear-262.jpg
Old 12-11-2010, 07:34 PM
2006 c230
the picture of two rotors is old front and new front, man i gotta paint the calipers now
Old 12-11-2010, 08:27 PM
2006 c230
just drive a couple miles seems to be ok, on to why the abs light is on
Old 12-11-2010, 11:41 PM
eddie_b's Avatar
98 c43-sold, 05 Audi A4 avant
Just curious. I looked on a couple sites for rotors, and the 2005 c230 sport is listed as having an 11.33"/288mm front rotor? Saw that the c320 is listed as having a 330mm front rotor. What site did you use?
Old 12-12-2010, 01:03 AM
2006 c230
2005 c230 sport k
its not a c230sport the k means kompressor
Old 12-12-2010, 01:12 AM
2006 c230
that sounded kinda gruff to you, lets rephrase, you have to specifically ask them for the sport k rotors that are 330mm, i can pm you the number i bought mine from if you like
i used just standard c43 brake pad fitment
Old 12-12-2010, 10:32 PM
eddie_b's Avatar
2005 c230 sport k
Sites I went to only listed the c230 sport. Listed engine was the 1.8 kompressor. The c320 on those sites are listed with 330mm front rotors. Info on where you purchased would be appreciated. Thanks.
Looked on ATE brakes website and saw the difference with c230 and c230 sport. Don't know why the sites I looked on didn't show the difference.
Old 12-13-2010, 12:10 AM
2006 c230
the c230 sport 2003-04 is the wrong one has to be a 05-up c230 sport k earlier cars have smaller rotors
Old 12-13-2010, 12:56 AM
eddie_b's Avatar
I was searching 2005 models as stated, not earlier models.
Old 12-13-2010, 02:39 AM
ABS light is on?! Use R129 rears and 05 230K sport fronts... That's what all other clubs have said. Did you get these to work right?
Old 12-13-2010, 02:46 AM
2006 c230
the abs light was on before i started, the brakes were a perfect fit, on the r129 i dont know, i used 02 c32 rears
dont be mythed by whoever you buy brakes from up to 2004 they are smaller, not all 2005s have 330mm, i had to ask over and over, i will say that look bad azz on the car
Old 12-13-2010, 02:47 AM
2006 c230
by the way not all r129 rotors are 300 mm be careful, that is why i used a 02 c32 rear
Old 12-13-2010, 02:44 PM
VeeDubbVR6's Avatar
HPS C43 AMG, E36 M3, MK3 GTi VR6, 66 FORD F100, 85 FORD F250, 04 GSXR
hmm, good info to know!
Old 12-13-2010, 08:56 PM
2006 c230
i have a twin spoke amg wheel on the front right night as im refinishing the mono block, my buddy stops by looks down and says holy shiz that is bad azz, think im in the market to show off the rotors with some thin spoke wheels
Old 12-14-2010, 01:07 AM
Autohausaz has the cross drilled fronts for the 05 c230 sport k. Those rears I can't seem to find.
Old 01-02-2011, 03:53 PM
Are the 05 c230 front rotors vented or solid? Its about time mine were replaced. I also had a tech tell me the other day that the clk430 rotors are the same as our c43 rotors. Is this true?
Old 01-02-2011, 04:44 PM
your front rotors are stamped with the AMG logo on the upper part of the hub.
CLK430 uses smaller rotors in diameter than C43.
Maybe the rear ones are the same 300mm in diameter?
if your tech says clk uses the same front rotors as your c43,I bet he doesn't know much about MB cars?
look for other tech.
Old 01-02-2011, 05:26 PM
2006 c230
again please read the post, 2005 c230 will not fit they are 288mm, YOU HAVE TO GET 2005+C230 SPORT K rotors which are 330mm, you should actualy ask before you buy
Old 01-02-2011, 05:27 PM
2006 c230
rears are 300mm c32 rotors
Old 01-02-2011, 05:41 PM
Ive read it three times. I get they need to be sport. Are they still vented? The rotors that your using in the pictures appear to be solid. Im viewing this on a cell phone btw. I cant see the pictures very well.
Old 01-02-2011, 05:43 PM
He was talking about the rears.
Quick Reply: drilled rotors install
