C43 front tie rod recommendation?
if you have a play, maybe it's time for the complete draglink depending how worn the old one is?
you can buy the tie rods separately, but if there's a excessive wear to your draglink buy it complete, better that way you also get the tie rod ends hooked up on the draglink.
check flea bay for those parts.
2nd best is FEBI BILSTEIN
3rd best is MEYLE HD redesigned parts for suspension.
Looks like your problems are coming up slowly on your car now, did you have a good check before you bought it?
Should I just buy the ends or the whole tie rod? Its just the front left end that showing play...
This looks like a really good price for the entire assembly. $211.82
http://www.partsgeek.com/gbproducts/...ek+Google+Base
go to pelicanparts.com
http://www.pelicanparts.com/euro/cat...SUSstr_pg1.htm
better for you to buy the complete draglink, it's no good just to replace one side and let the other side still use old parts.
on your worn bad side, how is the tire wear?
any funky wear n tear issues?
did you lift your cars front with the jack and check the wheel for excessive play?
any noise from wheel bearing when you make sharp turns?
if your wheel bearing breaks while driving that's dangerous!!
also check for bad balljoint.
if something snaps on your steering suspension then you will lose steering and you might be in a collision if you're unlucky, god forbid!
on another european forum there was a guy with a w202 he had to part out his car because he crashed it from a bad front suspension part, I think it was from a bad balljoint IIRC, I'm not sure, but he crashed the car he couldn't steer with it!
check the passengers side if the tire wear is healthy and normal?
